| Register | Search For Products | FAQ | Members List | Glossary | Calendar | Search | Today's Posts | Mark Forums Read |
#1 |
My mom dubbed me tacoboy
What does everyone think about the 2.5" Toytect Pro Basic Kit?
Lift height?
Look good? Ride quality? Can I fit bigger tires than 265's? Thanks |
#2 | |
Off-road enthusiast S.W.region
of course you could get the suspension TSB done (if not already and still under warrantee ) and consentrate your funds on the front for now. try touching base w/ Chris4x4 he is a wealth of info on these OME type lift kits a 265/70r17 32" tire is a pretty good all around tire for our trucks FWIW 265 is a description of tire Width the 70 is the ration of height to width. the formula to convert to inches is basically (265 x .70)2 /25.4) + 17 for height and 265/25.4 for width. best of luck with you lift buddy and dont worry your taco will look Sweeeeeeeeet!! ![]() timmer
__________________
Smokey Bear sez, Hear it again here Kids !!! http://www.vom.com/wesford/SBHA/SONG...ySONG_ga.shtmlI give my pledge as an American to save and faithfully to defend from waste the natural resources of my country - its soil and minerals, its wildlands, waters and wildlife. |
#3 |
Western Alliance: no longer dead.
agree with Timmer. Ask your self what you need the lift for? Spend a little more for the springs.
Timmer, +1 on the tire formula!
__________________
The simplest solutions are often the most clever..............they are also usually wrong. |
#4 |
thanks bud
![]() timmer
__________________
#5 | |
I did this lift. The Medium springs, and add a leafs and am very happy. I went with the 265/75/16 Bridgestone Revo's and am very pleased. The look and ride are perfect. This is one of the most dramatic things you can do for the truck besides tints to change the look entirely. About $330 for the kit $300 to install and balance and align. And $1000 for tires. Greatest mod I've done. Just do it, and trust me that you'll be very pleased. |
#6 | |
What are the differences between the OME 884/885/886 coils? What are each one used for? I don't plan on adding an aftermarket bumper; will the 884 coil be enough? |
#7 |
OME-884 coils are recommended for 2" of lift on stock applications with no additional weight, and OME-885 coils are recommended for 2.5" of lift on medium load applications with 70 - 180lbs additional weight over stock (either a bull bar w/ no winch, or a winch w/o a bull bar).
__________________
2007 Tacoma TRD Off Road 4x4, Leather
OME 886/140, OME Dakars/182, TC UCA, TW CV DS, 285 Destination MT, Spidertrax, Goodridge SS lines Rocktec & AllPro bumpers, Shrockworks sliders, Grillcraft struts, AllPro & BudBuilt skids, PIAA 510's, HID's, Warn M8000, MP Superline Oasis On-board Air, Dual Batteries, A-pillar pod w/ Autometer, ScanGauge II, Midland CB w/FireFly, Alpine/MB Quart/ID |
#8 | |
Also, what happened in that avatar of yours? |
#9 | |
Drama? What drama?
__________________
I guess I can go anywhere I want. If only I knew where to go. - Layne Staley R.I.P. |
#10 | |
nothing... just climbing and someone took a pic.
__________________
#11 | |
...I need some sleep.
#12 |
Get the 885's. Good to know the front can take a bumper
#13 |
been reading a lot of forums.. I think I have it narrowed down. I have a PreRunner, DC with the TSB back end. I measured yesterday, and I have quite a bit of front rake. I think I will probably just buy the coils for the front. Question is which coil to buy, 884, or 885? I will keep the Factory Bilsteins up front.. (tire 265/75/16) Suggestions?
This is obviously the first step of many.. ![]() -Sam
__________________
Sam, Bianca, Matthew 8, Ethan 4 07 Tacoma, DC, SR5, Susp. TSB http://littlehartsfields.blogspot.com/ |
#14 | |
__________________
#15 |
Dude if your going to upgrade the coils up grade the shocks too.
put the old ones on the shelf . then if something bad ever happens you got the OEM's right there to go to in the interum.
__________________
#16 |
I had been looking at the 2.5" lift kit from Toytec but went with Bilstein 5100s set at 1.75" and AALs in the rear.
Very pleased. |
#17 | |
Shocks and springs up front, and I am at the 500+ mark.. Is my ride going to suck that bad with the stock Bilsteins? When someone says they have the 5100's set to 1.75" up front.. I understand that is preloading the stock springs, but is that a 1.75" lift in front? I do not want a crappy ride, and I am not replacing the uca's. I would like my Alignment to stay in spec too. In time, I will buy another Tacoma 4wd TRD that I will go all out on.. I guess for now, I want a enough lift so it does NOT look stock.. make sense? -Sam PS- sorry for all the questions, I think you guys are great to help people like me out with this.
__________________
#18 | |
I've never measured the ride before and after, but it is indeed higher. Before: ![]() After:
#19 |
Nice, Thanks for the pictures.. looks like it needs bigger tires..
That is basically all I am looking for.. Now if I can confirm the AAL works with the TSB springs in back, I am good to go. Your 5100's are set to 1.75 and go up to 2.5...?I am guessing you do NOT have the TSB back end? -Sam
__________________
#20 | |
I don't think the TSB will work with the Alcan AAL from Toytec.com. The TSB is basically that: an additional leaf spring. I had to go the AAL route because I bought my truck used and without a warranty. It it had been under warranty I would have just gotten the TSB done and bought only the Bilstein 5100s. 5100s are good for 0.00" 0.85" 1.75" 2.5." So NO, I did not have the TSB performed on the back end of my truck. |
