Fox COs top plate
Discussion in 'Suspension' started by ktmrider, Oct 22, 2010.
  1. Oct 22, 2010 at 6:31 PM
    ktmrider
    ktmrider [OP] Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Is this installed right?
    I cant seem to fit it through the coil bucket to bolt it in.
    If it is installed right any tips to get it in
  2. Oct 22, 2010 at 6:36 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Upside down
  3. Oct 22, 2010 at 6:36 PM
    ktmrider
    Junk
    and im taking your word for it.
  4. Oct 22, 2010 at 6:37 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    yup...should be the other way
  5. Oct 22, 2010 at 6:37 PM
    numbah57
    kahai
    Maui, Hawaii
    sorry bad pic but you might be able to see it.
  6. Oct 22, 2010 at 6:38 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    they look upside down to me, but i dont own a pair of these so i may be wrong
  7. Oct 22, 2010 at 6:39 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    Flip them around and your good. That top spacer should be flat up top so it can fit in.
  8. Oct 22, 2010 at 6:43 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
  9. Oct 23, 2010 at 6:09 PM
    ktmrider
    Junk
    ok so I reinstalled it and got everything back together, but the weird thing is Im sitting at 5 inches of lift:eek: and spring coming contact with the UCA
    Should I take out the factory preload on the shock or is there something im missing completely. This is the correct shock for the truck right?
    passenger side CV
    UCA contact
    Shock assembly and preload
    Passenger hub to fender
    Driver hub to fender
  10. Oct 23, 2010 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dial some of that preload out of the CO.
  11. Oct 23, 2010 at 6:25 PM
    RelentlessFab
    Eric
    Sparks, NV
    daaamn those seem like too long maybe!?! Yeah definitely take out some preload from the spring and see if you can get it down. Looks like its sitting at full droop in those pics! :eek:
  12. Oct 23, 2010 at 6:31 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    i've seen coilovers cranked down a lot more that dont sit like that. did you measure that right after you took it off the jack? if so, it will sit a little high untile it settles, but i dont think it would sit THAT high. your cv's look like there sittin at a bad angle also.
  13. Oct 23, 2010 at 6:54 PM
    ktmrider
    Junk
    you would think, but no I actually drove around trying to get them to settle some. Ill take the preload out tonight, but I just dont know if they are the right coilovers. Ill call the guy I bought them from tomorrow.
  14. Oct 23, 2010 at 7:39 PM
    numbah57
    kahai
    Maui, Hawaii
    Mine were cranked more than that and the weren't that high.
  15. Oct 23, 2010 at 7:40 PM
    numbah57
    kahai
    Maui, Hawaii
    Were they hard to fit in? I would think that if they are that high they would have been a bitch to put in.
  16. Oct 23, 2010 at 7:42 PM
    Kenny650
    Kenny650 Well-Known Member
    Did the shocks come off a long traveled Toyota? They seem extended for a long travel setup.
  17. Oct 23, 2010 at 7:44 PM
    jandrews
    '09 FourDubDee TRD OR
    Something is DEFINITELY not right. Those CV angles are fucked.
    Start by double-checking the model # and make sure you have the right CO for your vehicle.
  18. Oct 23, 2010 at 8:18 PM
    ktmrider
    Junk
    I bought them from this guy
    http://cgi.ebay.com/ebaymotors/ws/e...0642885624&ssPageName=ADME:X:eRTM:MOTORS:1123
    I met him in person he is 10 minutes away from my house.
    the part numbers on the ebay say 980-99-362-A/ 980-99-361-A
    I have no idea how to get the top collar loose, its so tight the spanner wrench i ordered is the wrong size and Ive broken 2 drill bits.
    EDIT: the truck was on jack stands when I tried to get it loose.
  19. Oct 23, 2010 at 9:33 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Can you measure how much shaft is showing with the shock drooped out? If it measures 8" they are LT coilovers. Also I had fox coilovers once and they had a different top hat than those, but maybe it's different now. Do the springs have any numbers on them? Weird deal for sure.
  20. Oct 23, 2010 at 9:36 PM
    ktmrider
    Junk
    can I measure when they are off the truck cause i just took them off?
    oh and I called the guy he assured me that they are the right application straight out of the box, so like this
    Im going to meet up with him tomorrow to figure it out, but i dont see how I could fit that in without grinding out the coilbucket a little bit
