880 or 881 coils on 2.7l
Old 11-21-2010, 06:05 PM   #1
2000SIG [OP] 2000SIG is offline
2000SIG is on a distinguished road
2000SIG's Tacoma Gallery
Just got my bilstein last week and looking at the ome 880 and 881.
I have a 2004 ext cab with the 2.7l.Will the 881 be too high for my 4cyl?
I'm going to order the wheelers progressive aal at the same time so I'm trying to get some info before I get everything together.I want to leave the 5100 at zero and add the coils+ the wheelers aal(1.5" lift) and hoping tha the truck is level.
thanks
Old 11-22-2010, 09:40 AM   #2
Dan
YotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shed
YotaDan's Avatar
YotaDan's Tacoma Gallery
If you want rake, then go with the 880s, if you want the truck more likely to be level, then you would probably want to run the 881s.
Old 12-07-2010, 09:31 PM   #3
2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed2KTacoPr3runn3r is one of the sharper tools in the shed
2KTacoPr3runn3r's Tacoma Gallery
im looking to get some 880 or 881 but wont be doin an AAL in the rear. which would be best for a level/slight 'bro' lean in the front? (i have a 4cyl prerunner xtra cab)
Old 01-20-2011, 11:42 PM   #4
v1ndictiv3 is a name known to allv1ndictiv3 is a name known to allv1ndictiv3 is a name known to allv1ndictiv3 is a name known to allv1ndictiv3 is a name known to allv1ndictiv3 is a name known to all
v1ndictiv3's Tacoma Gallery
Sorry to bump, but YotaDan, if I was to purchase the wheelers 5 leaf pack for my 98 prerunner and use bilstein 5100's all around set at 0 with OME 880's, you're saying there'll be a slight rear rake? So the 881's will level it out?
Old 01-21-2011, 12:22 AM   #5
Locked and Lifted "02" DC TRD.
Matic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shed
Matic's Avatar
Matic's Tacoma Gallery
I have the 881's on my "02" dc. They provide plenty of lift and not to harsh of a ride when paired with the stock tokico shocks. I also went with the toytec aal in the rear with pro comp extended shocks.
The ride is firm and enjoyable.
I also removed my front sway bar which also adds to the ride being a bit more "plush".
I went with the 881's because I plan on adding a 70 lb winch to my alpro tube bumper which should not effect the ride much. I'm 6 ft, 200lbs and can stand on my bumper and the springs barely move.
I would highly suggest the 881's.
OME 880 or 881? (4cyl ext cab 4x4) TacomaGus 1st Gen. Tacomas 22 01-05-2015 04:25 AM
OME 880 OR 881 2000SIG 4 Cylinder 9 12-17-2012 01:22 PM
OME 880/881 and 5100's... Which spring, which setting?! DblCabMN Suspension 4 08-16-2011 05:38 PM
OME 880 or 881 2KTacoPr3runn3r Wheeler's Off-Road 5 12-08-2010 12:22 PM
OME 880's or 881's? steve o 77 Suspension 11 04-25-2010 03:43 PM
