OME Dakar Leaf Pack install Help
Old 12-01-2010, 08:23 AM   #1
wrmathis [OP] wrmathis is offline
Dark Lord of the Sith
wrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shedwrmathis is one of the sharper tools in the shed
wrmathis's Avatar
Army: Tech Insp: 404 ASB/4th CAB
wrmathis's Tacoma Gallery
Send a message via ICQ to wrmathis Send a message via Yahoo to wrmathis
im tryin to figure out which side goes forward and which side goes aft. also, does the leaf pack with the + sign go on the drivers or passengers side?
I've searched and cant find a thread on a install write up for these
Old 12-01-2010, 08:27 AM   #2
Locked and Lifted "02" DC TRD.
Matic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shed
Matic's Avatar
Matic's Tacoma Gallery
Not certain but if it has an AAL or helper spring, the longer end goes to the rear. As far as the + for which side, I am not certain.
Old 12-01-2010, 08:30 AM   #3
wrmathis's Avatar
its a full leaf pack, not a add a leaf
Old 12-01-2010, 08:34 AM   #4
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
I documented the install pretty thoroughly in the link in my sig.
Short answer to your original question is:
1. no diff between driver and passenger on leaf pack
2. End that comes to you "open" without a bushing installed in it goes to the rear into the spring hanger bracket. Be sure and lube up the bushing and its bolt thoroughly with the provided grease. If they didn't give you any, you can use vaseline. Don't use ordinary grease, it'll deteriorate the rubber over time.
Old 12-01-2010, 09:00 AM   #6
wrmathis's Avatar
thanks guys. appreciate everything
Old 05-26-2014, 06:00 PM   #7
NLMOOmar is on a distinguished road
NLMOOmar's Tacoma Gallery
On some search I did on the TW on the Dakar packs I've seen some reference to an a or b side (driver or passenger) can someone show us where this mark exist? Or is this an urban legend.
Old 05-26-2014, 06:10 PM   #8
attack ships on fire off the shoulder of Orion
OZ-T's Avatar
OZ-T's Tacoma Gallery
2nd gen Dakars are not side specific but may have a + , 0 , or a - on them
A + indicates a pack slightly over spec
A 0 indicates a pack at spec
A - indicates a pack slightly under spec
If you get a mixed pair , put the highest spec one on the driver's side to help with Taco lean
Old 05-27-2014, 05:59 AM   #9
Thanks for clearing up the spec. riddle OZ-T.
Old 05-27-2014, 06:15 AM   #10
I'm a solid 5........at least.
User Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shedUser Name01 is one of the sharper tools in the shed
User Name01's Avatar
Name: El Chicken Little
User Name01's Tacoma Gallery
Lube them up good, real good.
OME Dakar leaf pack do i need new breakline Mr.Ed Suspension 7 06-25-2011 02:50 PM
ALLPRO expedition leaf pack vs OME Dakar leaf pack aaronpatter Suspension 14 05-05-2011 11:15 PM
OME Dakar Leaf Pack? 2KTacoPr3runn3r Suspension 27 04-26-2011 10:30 PM
OME Dakar Leaf Pack - need advice.... ACE_Taco Suspension 5 04-30-2010 10:27 PM
Radflo coilovers set to 2" with OME Dakar leaf pack meafordmike Suspension 1 03-27-2010 11:02 AM
