6" Lift Question
Old 12-20-2010, 10:17 PM   #1
Rbohno [OP] Rbohno is offline
Rbohno is a jewel in the roughRbohno is a jewel in the roughRbohno is a jewel in the rough
Rbohno's Avatar
Rbohno's Tacoma Gallery
6" Lift Question
Why does some of the 6" lifts I have looked at say must use 17" or larger rims with 4.5" of backspacing or less. I get the backspacing requirement, I just bought new 16" x 8" rims with -0- offset which equates to 4" of backspacing so I got that part covered but whats the deal with the diameter of 17" or greater requirement.
What does the diameter of the rims have to do with the size of the tires you can install?
Old 12-20-2010, 10:19 PM   #2
kinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shed
kinkrider101's Tacoma Gallery
i think its because the kit moves the steering knukle up or it moves something up that requirs a larger rim
Old 12-21-2010, 06:48 AM   #3
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
An 8" rim with zero offset has 4.5" backspacing, not 4".
Old 12-21-2010, 09:33 AM   #4
Rbohno's Avatar
I bought the rims from Discount Tire and they list their rims by offset and when you ask them about backspacing they give you the "deer-in-the-headlights" look.
So I got the manager involved and he told me that a -0- offset equated to the mounting surface of the wheel being exactly in the center/middile of the wheel so the following wheels with a -0- offset would be :
  • 8" wide wheel - 4" backspace
  • 9" wide wheel - 4.5" backspace - So what would the back space be for this wheel *
And so on.................So I am not surpised if I was misinformed, I just took his word for the backspace amount of my new wheels and didn't measure while they were sitting there in the box.
* This is the wheel they test fitted the 285/75/16 Nitto terra grappler on my truck with and it hit pretty bad in the front.
Will the 8" wheel be better or worse with regards to fitment of a 285/75/16 on my truck?
Thanks for your input/info
Old 12-21-2010, 09:42 AM   #5
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
The centerline of the rim is based on the outside width, not the "rim width". Rim width is the inside bead. The center of the rim width and the centerline will not lie in the same place.
Old 12-21-2010, 09:43 AM   #6
KPT KPT is offline
KPT's Avatar
Here this page has lots of good info, including a chart that will help you convert width and offset to backspacing
https://www.rsracing.com/tech-wheel.html
Damnit Ben that's the second time you've beaten me today!
Old 12-21-2010, 09:43 AM   #7
Chachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shed
Chachie's Avatar
Chachie's Tacoma Gallery
The reason they say a certain rim size is because of the larger spindle.
Old 12-21-2010, 09:48 AM   #8
:POOPCORN:
98tacoma27's Avatar
Marines:
Old 12-21-2010, 10:06 AM   #9
My68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shed
My68ur8trd's Avatar
My68ur8trd's Tacoma Gallery
and the fact that the tie rod is flipped to the top of the knuckle and not from the bottom like the factory setup.
Justin
Old 12-21-2010, 10:17 AM   #10
But I think you can run spacers in the front to fit a 16" rim
Old 12-21-2010, 12:02 PM   #11
Rbohno's Avatar
Originally Posted by tacoridinhigh View Post
Yeah, you can. If you have spidertrax stacked with a wheel that has ~4.5" backspacing you can fit a 16" wheel.
Damn, never cease to amaze me with all the knowledge thats out there!!!!!
The term "stacked" when mentioning spidertrax scares me, define the amount of stacked.
Old 12-21-2010, 12:04 PM   #12
Chachie's Avatar
Im guessing here but i think he means stacked as in combined with. ....although you could run a ton of stacked spacers and be like 10ft wide in the front!!!!! hahahahahaha
6" Lift Question? xFaMouSxKill3Rx Suspension 4 08-02-2011 11:22 PM
6" lift question Freestyler Suspension 11 07-21-2011 11:42 AM
3" lift question shawnresa 2nd Gen. Tacomas 15 03-19-2010 03:19 PM
serious 3" lift question EmoSlayer Suspension 11 08-31-2009 02:42 PM
Question about 3" lift natemaker 2nd Gen. Tacomas 8 03-12-2008 08:27 PM
