6" lift problems
Discussion in 'Suspension' started by arrowthrower, Dec 21, 2010.
  1. Dec 21, 2010 at 12:35 PM
    arrowthrower
    arrowthrower [OP] Well-Known Member
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    I have a 2011 DC TRD and love the look of the 3" lift. But seems like too many problems with them. I don't see any problems with the 6" lift. Anyone have the vibration problems or anything negative to say about 6". I would rather pay the extra money for something that will be as realible as the truck.
    And why is so many people down on the spacer? I had one in my 2004 f-150 and couldn't tell any difference in the ride.
  2. Dec 21, 2010 at 12:41 PM
    TBK224
    TBK224 ~THE LIGHT GUY~ Vendor
    Tim
    Phoenix, AZ
    BADASS TACO
    6" Pro Comp Stage One Lift Kit and 35" Toyo Open Country M/T's riding on 18" XD Addict Wheels
    I love my 6" Pro Comp lift. I would recommend new UCAs though to correct your alignment after you lift it. Worth the money if you do a lot of off roading and need the bigger tires and extra ground clearance.
  3. Dec 21, 2010 at 12:43 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    there shouldnt be any probs with a 3" lift if you do it right. 6" on a small truck like a tacoma is overkill IMO
  4. Dec 21, 2010 at 12:44 PM
    Manwithoutaplan
    ID
    yes i have the vibration problem with the 6 inch lift. I where you i would go with the All pro Long travel kit that is the best bang for your buck. Check out Mxpatriot he got the setup. That is more usefull than the 6 inch lift.
  5. Dec 21, 2010 at 1:16 PM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    Do you have a 3" lift? I would rather do one, but I just shelled out $30000 for a new truck. Not excited about messing it up. How much are cv joints? Not much of an offroader either. Just camp, hunt, and mainly street drive. All for looks. Just want a bad ass truck that is also great shape.
  6. Dec 21, 2010 at 1:20 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Unfortunately, vibrations are something to be expected when lifting your truck. By lifting the front end of the truck you are thereby lifting the engine, the transmission, and changing the angle of the driveline. Changing this angle is what causes many people's vibrations. However there are different ways, for both 3" and 6" lifts, to help remedy the vibrations. Such as shims, carrier bearing drops and new driveshafts at the proper length. Just more for you to think about. IMO go with what ever lift your going to like and be happy with. So do research, ask questions, pm guys and get responses to determine what route you would like to go. Do it right the first time. It costs too much money to be impatient.
  7. Dec 21, 2010 at 1:24 PM
    TexasTacoma37
    OP: Preunner or 4x4?
  8. Dec 21, 2010 at 1:55 PM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    4X4. What about just leveling the front with a spacer. does that mess anything up?
  9. Dec 21, 2010 at 1:59 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Bilstein 5100 ..no spacers
  10. Dec 21, 2010 at 2:23 PM
    TexasTacoma37
    This sums it up best, from Camburg's website:
    We get asked this question all the time. “Why are most spacer lifts be bad”? Well spacer lifts can cause a few problems and cost you big dollars to fix. First there are a few different kinds of spacer lifts, there is the kind that just bolts on the top of the existing shock that spaces it down to give lift. The problem that can come from running this kind of spacer is the shock will now be allowed to droop to far downward causing binding and damage to ball joints, 4×4 axle cv’s, and steering joints. The other issue you might have is since the shock is now just pushed down when you bottom out the suspension on or off-road instead of hitting the bumpstops you will just bottom out the shock. This can lead to some hefty damage. The next kind of spacer lift available are the preload spacers. These will usually cause the coil springs to be preloaded to give lift. The side effect to this type of lift is the shock valving is not designed for the extra preload of the spring giving the ride a bad bouncy feel that sometimes feels uncontrolled. And in some cases we have seen the spring coilbind causing damage to the shock and the frame. This is because the spring is designed to move about 1/2 its total length so when you pre-load them they are now compressed to much so near bottom out they will bind before you hit the bumpstops.
  11. Dec 22, 2010 at 8:42 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
  12. Dec 22, 2010 at 8:55 PM
    kinkrider101
    santa barbara
    wheels and tires
    I sure wish I did 6" I can't tell my truck is even lifted..
  13. Dec 23, 2010 at 7:26 AM
    Cr250jumper
    The moon
    50 shades of tan©
    I just disagree with the lifts that are for "looking" cool. If your not doing any major off roading or rock crawling your stock suspension does fine. I just dont see the use of an off road kit that is meant for street driving. Unless your a mud bogger there is no benifit to "lift" your truck. Look at real trophy trucks. They are not "lifted". They may sit a little higher due to 37" tires but overall they are not lifted. Even for a rock crawler the key to suspension is articulation. How much travel do you gain with a 6" Fabtech lift? None. What happens if you were to slide sideways on the road in your 6" lift? Roll over special. People "lift" their trucks so they can be higher than everyone and try and catch attention. So if your goal is to "look" cool then I guess Fabtech does its job. Seems like a waste of money to me to buy a lift kit that is good for "Just hunting and street driving"
  14. Dec 23, 2010 at 9:08 AM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    Thanks for all the post. I believe i will do a 6". Does anyone know any good places in the Western KY area to install? Thanks.
  15. Dec 23, 2010 at 9:23 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Who cares if a lift is "just for looking cool"? Lifted truck DO look cool.
    OP- I think you are on the right track if you are looking to get a 6" lift. I lifted mine 2.5" and I wouldn't consider it a "lifted" truck. It more or less looks the way that it should look from the factory. Nice and level and slightly more room in the wheel wells. Anyone that doesn't know I lifted it wouldn't think that it is. If you want your truck to look cool and lifted, definitely go for something more than 3".
    Just my opinion.
  16. Dec 23, 2010 at 10:42 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Or you could split the difference and go with the 4.5" drop bracket RCD lift.
  17. Dec 23, 2010 at 10:47 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Well I guess if you care that much about what other people think of you then go for it. Maybe im just a desert rat but I could care less what others think my truck "looks" like. Im all about the "actual" performance
  18. Dec 23, 2010 at 7:06 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    This is the fastest truck on earth, and on 39's it's lower than my taco in the background on 33's. IMG_0052_a5ef6f154a883a6d7a41d40784a159c37d22d560.jpg
    There is nothing wrong with a 3" lift done right with coilovers and deavers, and any 6" will be fine for most street/show guys just keep in mind it will be more expensive in the long run for maintenance and you won't get as much resale out of a 6" lifted truck.
  19. Dec 23, 2010 at 7:10 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    SICK! Ft. Irwin?
  20. Dec 23, 2010 at 8:09 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yeah he stopped by and took some soldiers for a ride around the tank test track. Didn't get much vid, I was driving most of the time.
    http://www.youtube.com/watch?v=69yKAo98HAA
