tried and true lift???
Discussion in 'Suspension' started by boxxed, Jan 10, 2011.
  1. Jan 10, 2011 at 9:42 AM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    I have an 09 dlb cab off road taco. I am interested in getting a lift. The problem is that I don’t know a damn thing about it. I have searched and read a lot of different things about them but it seems like there is just so much to know.
    I am interested in the Pro Comp stage 1 6" lift. But I don’t know if it’s really what I need. From what I read it sounds like it might be. However I am not opposed to the stage 2. I don’t really plan on doing any off roading but that doesn’t mean that it won’t change.. I like the look of a lifed truck but still would like a great set up. I dont really want to half ass it.
    I just would like to get a tried and true life so I don’t continue to have issues...
    Then after this gets worked out I will need to consider wheel and tires. I will be living in Colorado by the time I get this done so it will have to be something that accommodates that great state.
    One more thing, why do most people seem to go with 3" lifts as opposed to 6 or higher. Is there a law about lift height?
  2. Jan 10, 2011 at 9:50 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    Guys on this site go with 3" lifts over 6" on this site for 2 main reasons well that was mine. The 3" lift is cheaper so you can get better shocks and springs without breaking the bank and the drop bracket lifts give you less ground clearance and most of the guys here take there truck off road and ground clearance is key. and really with a 6" lift 35's is about max for the tire size unless you do major modifications. I ideal lift on IFS in my eyes would be a 3" with modified fenders to except 35" tires.
  3. Jan 10, 2011 at 9:59 AM
    toddt
    toddt Well-Known Member
    todd
    Houston, TX
    2011 D-cab 4x4 TRD OffRoad
    TRD Supercharger, TRD cold air intake, TRD Sport Hood, TRD Exhaust, Pro Comp 6" lift
    I went with the stage1 procomp 6" It rides nice, looks awesome. I very happy with it.
    I used to have a 3" it wasn't enough for me. Most of the more "serious" offroad guys use coilover 3" kits due to articulation and ground clearance. Im just into looks and occasional offroad.
  4. Jan 10, 2011 at 10:04 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    if you are 2wd you can get spindles and a coilover have 6inches and still off road
  5. Jan 10, 2011 at 10:07 AM
    JLee
    Jerry
    Benicia, CA
    This is why I went with a 3" lift. 14 1/2 inches of ground clearance from skid plate to the ground.
    I like to look of 6" lifts but me personally would never do a drop bracket lift. If I were to lift my truck any higher Solid axle swap would be the route I would go
  6. Jan 10, 2011 at 10:10 AM
    boxxed
    Denver, CO
    09 Off Road
    Is this the kit you had installed? http://4wheelonline.com/Products.aspx?CategoryId=92434&ProductId=242044
    Do you do it or have a shop install it. If so, what did they charge to install. Being that I have the off road do I need the new shocks?
    Also what about the groung clearance?
  7. Jan 10, 2011 at 10:12 AM
    boxxed
    Denver, CO
    09 Off Road
    WOW thats a cool loking truck, do you have any side shots?
    What is a drop bracket lift.. Sorry I dont know much about lifting?
  8. Jan 10, 2011 at 10:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A "Drop Bracket" lift, is one that replaces the front crossmember with one that is lower 4.5 to 6".
  9. Jan 10, 2011 at 10:15 AM
    JLee
    Jerry
    Benicia, CA
    Thanks Checkout my build just click the picture below. A drop bracket lift is a lift that drops your front cross-member down. anything 4.5" or above is a drop bracket lift.
  10. Jan 10, 2011 at 10:16 AM
    straycat241
    paul
    those cam tabs look like there right in the way of getting smashed compared to the other taco
  11. Jan 10, 2011 at 10:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add:
    The only thing that gives a drop bracket lift its clearance, is the larger tires that people install on them. Given that most run larger tires (35" or so), and dont regear, it puts much more stress on the drive train, and the moment loding of the drop bracket lift can be bad if hitting a large impact off roading.
  12. Jan 10, 2011 at 10:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. It puts the alignment cams right in the way of getting fucked up.
  13. Jan 10, 2011 at 10:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And another thing most dont think about is center of gravity. Jacking the truck 6" up raises your CG, and you run the risk of flopping over (if you wheel it) more so than a truck with a 2.5" to 3" lift would. I see more folks with 2 to 3" lifts go way further than the 6" lifted trucks.
  14. Jan 10, 2011 at 10:29 AM
    boxxed
    Denver, CO
    09 Off Road
    Nothing like getting my head to spin..I am going kookoo for taco lifts...I would just like a lift that wont give me a pain in the ass. I wont be doing any major off roading. I just like the look of a hight lifted truck. But I dont want to put a bigger strain on my truck then need be.
    thanks
  15. Jan 10, 2011 at 10:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I guess it all depends on how you want it to look then. If you want all out height, Then consider a 6" lift. If you want more performance, look at the 3" lifts out there. FWIW, A high quality 2 to 3" lift isnt going to be that much less expensive than a 6" lift....if at all. However, you can get by with running a 32 to 33" tire, and not regear.
  16. Jan 10, 2011 at 10:46 AM
    boxxed
    Denver, CO
    09 Off Road
    Ya Iam still trying to figue it all out. I just dont want to regret what I do. I only want to do this once..
    I know some people had vibration issues and I dont want to go throught that. That is why I am looking for something that is tried and true with the truck I have. I guess it dosent have to be 6inch I just thought it might be a better way to go considering I will probably never do serios off roading. I figured It would cost around 2k or so which is fine just no regrets..
  17. Jan 10, 2011 at 11:00 AM
    JLee
    Jerry
    Benicia, CA
    vibration issues is are all over the place some guys have none and others with the same setup have vibration issues. When changing the suspension in any way you risk running into these issues. There is really no tried & true lift that will guarantee no vibs so if you really want to lift the truck you will have to just take the chance.
  18. Jan 10, 2011 at 11:10 AM
    boxxed
    Denver, CO
    09 Off Road
    I thought that might be the case.. I will take my chances. For now I'll talk with some local shops around here in Michigan, but Ill wait till I get to Colorado to have the actual work done. I have time to research.
    Thanks again
  19. Jan 10, 2011 at 11:19 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Have you thaught about the 4" RCD kit? alot guys like it....
    And you can get coilovers, and adjust your coilovers up to give you more lift and ground clearance.
  20. Jan 10, 2011 at 12:03 PM
    ETaco23
    Evan
    PNW
    I know its a DB, but he doesnt do offroading. So its basically just for looks. I personally dont like aDB lift just bc it requires cutting of the cross member.
