3/4 top spacer lift with 5100's set at 1 inch?
Old 01-14-2011, 02:30 PM   #1
tacoma02 [OP] tacoma02 is offline
tacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shedtacoma02 is one of the sharper tools in the shed
tacoma02's Tacoma Gallery
I have a 2002 4x4 and i just got the bilstein 5100's and i want to raise the front about 2". The 1st gen bilsteins only have three settings and i dont want to go all the way to 2.5". I want to have a good ride so instead im thinking on putting a 3/4 top plate spacer lift from toytec on the bilsteins set at 1". I know the problems with spacers but im just wondering if such a small spacer is alright or should i just do the 1/4 spacers to give me 1/2 more lift?
Old 01-14-2011, 03:15 PM   #2
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
I wouldn't worry about a spacer that small as long as you keep the total lift under 3"
Old 01-14-2011, 03:27 PM   #3
yeah Im just planning on 1 3/4 front lift with a 1.5 fabtech aal in the back i just want a little extra lift, thats another thing, do you think i should do the 1.5 aal or a 2" i just dont know what the 5100s in the back can handle and if i got to extend my brake line or not
Old 01-14-2011, 07:31 PM   #4
KPT KPT is offline
KPT's Avatar
The 5100's can accommodate up to 2" of lift in the back I believe.
Old 01-14-2011, 08:23 PM   #5
Rich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shedRich Beauregard is one of the sharper tools in the shed
Navy:
Rich Beauregard's Tacoma Gallery
I have these toytec spacers (P/N 25912) I no longer need. $20 plus shipping if your interested. My zip: 15905 I could send in priority envelope for about $5 anywhere in US. They could use some buffing if you like them to shine. They are 1/2" thick designed to lift 3/4" These will fit a 2002 Tacoma.
Old 01-15-2011, 07:46 AM   #6
yeah im intrested how do you want to share our sending info, through email?
5100 set at 0.85 with 10 mm top spacer and Rear TSB 5280EM! Suspension 3 11-12-2012 08:44 PM
How much lift w/ 5100 set 0 and Eibachs w/ 1/4" top plate spacer driver side Gabe911 Suspension 7 01-30-2012 07:34 PM
Bilstein 5100's set to the middle setting with 3 inch lift springs ffr3064k 1st Gen. Tacomas 7 10-16-2010 11:27 AM
2.5 in. Spacer on top of 6 inch suspension? caleb337 Suspension 21 02-24-2009 04:04 PM
Spacer on top of bilstein 5100's lift caliKxracer Suspension 0 08-01-2008 12:34 AM
