5100 questions?
Old 01-23-2011, 08:25 PM   #1
krisjw101 [OP] krisjw101 is offline
krisjw101 is a glorious beacon of lightkrisjw101 is a glorious beacon of lightkrisjw101 is a glorious beacon of lightkrisjw101 is a glorious beacon of lightkrisjw101 is a glorious beacon of light
krisjw101's Tacoma Gallery
5100 questions?
I know that the 5100's are the way to go for a less expensive way to go to level out the truck but what I dont understand is why the ride is so much better than a spacer lift? both are preloading the spring, right?
Old 01-23-2011, 08:28 PM   #2
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
Billys are designed not to bottom out. They do not over extend the strut assembly like spacers do.
Old 01-23-2011, 08:29 PM   #3
sg4506 is on a distinguished road
sg4506's Tacoma Gallery
Would having both a level kit and the 5100's be any big deal?
Old 01-23-2011, 08:31 PM   #4
arent there 2 different kind of spacers, a top plate spacer and a coil spacer?
Old 01-23-2011, 08:32 PM   #5
Almost there
08pretaco's Avatar
Why waste your money on both when 1 item does the job?
Old 01-24-2011, 06:51 AM   #6
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
The 5100's are valved to dampen the stiffer spring rate.
It would be redundant. You can't run any sizable spacers unless the billy are set at zero. And what would be the point of that?
Correct. Both are garbage for different reasons.
5100'S questions takamineman 1st Gen. Tacomas 21 01-21-2012 10:05 AM
more 5100 questions 928puddles 1st Gen. Tacomas 4 06-02-2011 01:08 AM
a few questions about 5100's tacosupreme54 Suspension 24 10-26-2010 12:07 AM
5100 questions garrettski 2nd Gen. Tacomas 7 03-24-2009 09:55 PM
5100 questions.... garrettski 2nd Gen. Tacomas 21 02-03-2009 04:20 PM
