3" coilovers and 33" grapplers?
Discussion in 'Suspension' started by jerretxx, Jan 27, 2011.
  1. Jan 27, 2011 at 3:28 PM
    jerretxx
    jerretxx [OP] Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    I am planning on putting these coils soon:
    can i fit a 33x12.50R17 nit Mud grappler, i realize ill have to trim but how much exactly? and do you have any pics of your inner fenders cut?
  2. Jan 27, 2011 at 3:32 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    You going to have to do more then trim. you will have to chop the cab mount or you will rub at full lock.
  3. Jan 27, 2011 at 3:33 PM
    jerretxx
    Jerret
    North Carolina
    would 285's fit better?
  4. Jan 27, 2011 at 3:34 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Get new UCA's with that set-up. I'm running 285/70/17 (33/11.5) and I had to trim just about everything......Cab mounts, pinch weld, fenders and inner liners. That's with 3* caster and that would not be attainable w/o aftermarket UCA's. I also took off my sway bar and feel that's what caused a lot of rubbing with the extra uptravel.
  5. Jan 27, 2011 at 3:35 PM
    jerretxx
    Jerret
    North Carolina
    okay. i may run the coilers and stick with 265's just because i don't want to trim a whole lot for resale purposes.
  6. Jan 27, 2011 at 3:50 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    An aggressive 265 would be fine for most wheeling I'd imagine.
  7. Jan 27, 2011 at 10:22 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    I must be the only person on this board running 305/70/16's with 3" of lift that does not hit the body mount, ever! and yes I do offroad but don't jump the truck or anything too nuts.
  8. Jan 27, 2011 at 10:23 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    mud grabblers rub more than other tires there size.
  9. Apr 8, 2011 at 6:19 AM
    chad68
    Chad
    OP did you get the grapplers or what? I want to get the Grapplers and new wheels so bad, I may end up not waiting till my current tires wear out, which would be a good year and a half from now.
    This jeep is running 33x12.5x17 Grapplers on 9"wide Mickey Thompson classic lock wheels (polished).
    Same wheels and tires I want but I'm trying to decide on getting that same size or 16x8 wheels with 305/70/16 Grapplers. I'm leaning more towards the 16" wheels, as I prefer more sidewall.
    The white Tacoma has 35" tires and 3" of lift.
  10. Apr 8, 2011 at 2:12 PM
    Sprink669
    Sprink669 Well-Known Member
    I hear you. I have OME 886 springs and the dakar leafs and have 285/75/16's and I am glad I went with bigger 285's over the 265/75's. I have aftermarket wheels with 4.5in bs. Do you have any pics?
  11. Apr 8, 2011 at 2:27 PM
    chad68
    Chad
    All the pics in my gallery are with my current 33" tires.
  12. Apr 8, 2011 at 2:31 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Also depends on what wheel you are going to use
  13. Apr 8, 2011 at 2:32 PM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    Your not rubbing because that tire size is not 33/11.5 it is actually 32.75x11.5x17
  14. Apr 8, 2011 at 2:40 PM
    RecklessTaco
    Topaz Lake, Nv.
    Thats cause most of the guys complaining about rubbing think they have a 3inch lift but in reality they only have a 2.5 or a 2.75 inches of lift. Been there done that. Im running a True 33x12.50x17 not a metric size a true inces size, and i had to cut and chop to make them work:D
  15. Apr 9, 2011 at 5:19 PM
    chad68
    Chad
    From what I have gathered about Mud grappler sizes, I would stand a good chance of rubbing the body mount a smidge. Will find out someday.
  16. Apr 9, 2011 at 5:25 PM
    o2begrn
    o2begrn Active Member
    Carlos
    San Jose Ca
    09 double cab Toytec Ultimate Moto Metal 957
    toytec 3" ultimate lift with aal rear tsb bed cap,Moto Metal 957 Nitto Trail Grapplers 295-70-17
    they rub a little on the body mounts ,,i mean very little,,,
  17. Apr 11, 2011 at 3:20 PM
    Scarab21
    Scarab21 Well-Known Member
    Tint, tinted tails + 3rd brake light, shaved tailgate, painted calipers. TSB Leafs+ AAL, PA/CB, 5100 Bilsteins set @ 2.5 up front. Satoshi line-x'd grill.
    ive got 285/70/17 goodyear wrangler MTR's on my billies set at 2.5 (the ones shown but without the coilover)
    and i barely rub.. its a great fit. the best fit. i think.
    i have stock rims. so i got spidertrax on all 4. you need the spidertrax.
    but looks amazing!
