3" Lift
Old 01-31-2011, 06:48 PM   #1
Flmxrider [OP] Flmxrider is offline
Flmxrider is on a distinguished road
Flmxrider's Avatar
Flmxrider's Tacoma Gallery
Question 3" Lift
I have a 99' Prerunner and I'm trying to figure out what 3" lift I should get. I don't have enough to spend on coilovers, but eventually plan on upgrading to those. I've read some pretty bad things about spacer lifts so I don't know if thats a good choice, even though I don't offroad. What's the best option out there besides coilovers?
Old 01-31-2011, 07:11 PM   #2
K1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shedK1992f is one of the sharper tools in the shed
K1992f's Avatar
K1992f's Tacoma Gallery
Check toytec lift they have nice stuff also on 4wheelingonline have a procomp 3" for 467 bucks ...
Old 01-31-2011, 07:57 PM   #3
Flmxrider's Avatar
I looked at the toytec lifts and those are pretty reasonable. I'll probablly go with the spacer for now and either AALs in the back or blocks. Which is better out of those? Also do I need extended rear shocks if I do that? If anyone of you guys can help me with that, thanks.
Old 01-31-2011, 07:58 PM   #4
AzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shedAzogSS is one of the sharper tools in the shed
AzogSS's Avatar
Law Enforcement: Govenor's Twenty, Mobilization Trainer, Squad Designated Marksman, Flight Operations
AzogSS's Tacoma Gallery
Old Man Emu! High quality, and that's what I have.
Old 01-31-2011, 07:59 PM   #5
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
AAL's are a better choice than blocks. Blocks tend to promote axle wrap. I'd avoid spacers in the front also.
You won't need longer shocks in the rear.
Old 01-31-2011, 08:03 PM   #6
Flmxrider's Avatar
Yeah I'm trying to avoid getting a spacer lift. I've heard good things about OMEs but what about If I did 5100 Billies front and back with a top spacer in the front. How does that work?
Old 01-31-2011, 08:07 PM   #7
KPT KPT is offline
KPT's Avatar
Why the top plate spacer on the 5100's?
Old 02-01-2011, 05:11 AM   #8
Flmxrider's Avatar
Nevermind about the top spacer. So you can set the Bilsteins at a certain height or how does that work?
Old 02-01-2011, 06:32 AM   #9
KPT KPT is offline
KPT's Avatar
You can set them at 0.85", 1.75" or 2.5". Each setting preloads the stock springs slightly more.
Old 02-01-2011, 08:59 AM   #10
Flmxrider's Avatar
OKay cool so then should I do AALs in the back? or can you set the back?
Old 02-01-2011, 12:54 PM   #12
Flmxrider's Avatar
Thanks for the help.
Fitment: 07 with a 3" lift 33"12.5" 17" Saskyota Wheels & Tires 9 01-16-2014 12:17 PM
Let me see your DC's with 265 duratracs on 2.5" front lift with 2" rear lift BenWA 2nd Gen. Tacomas 8 11-08-2013 01:55 PM
Can I add a 2" body lift to my 3" suspension lift and not have problems with the VSC blue86gt 2nd Gen. Tacomas 17 08-10-2011 11:14 PM
Toytec 3" Spacer Lift w/ AAL or the Pro Comp 3" Suspension Lift hawaiian_fantasy Suspension 1 04-12-2010 04:30 PM
= => Will A "SPINDLE" Lift Help my Rubbing? 285/70/17 w/4.5 BS @ 2.5 Lift <= = RAD 2nd Gen. Tacomas 21 11-03-2009 11:44 PM
