3" lift options??
Old 01-31-2011, 08:14 PM   #1
adamw [OP] adamw is offline
adamw is on a distinguished road
adamw's Avatar
adamw's Tacoma Gallery
3" lift options??
I have read a bunch of posts on what peope have done and looked at thier builds, but I still have no idea what a good set up looks like for a prerunner. I want something that wont give me problems while keeping it under $500ish. anything would really help. thanks!
Old 01-31-2011, 09:29 PM   #2
wolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shed
wolfdog2314's Tacoma Gallery
Setup for a prerunner will be the same as 4x4. For the most part. Except you can do spindle lifts... That's going to be out of your price range though.
Go for bilstein 5100's all around. U can set the front to 2.5 and hey an add a leaf.
Or check out Old Man Emu lifts. You'll be able to get a full 3 inches with that lift. But might exceed your price range. Think of the possibility of getting new upper control arms when u get to 3 inches of lift.
OR... Get a 3 inch spacer lift. Cheap. Lifts your truck. You'll sacrifice some ride quality tho.
Keep searching you'll find something...
Old 01-31-2011, 11:17 PM   #3
adamw's Avatar
If I go with bilsteins all around will I need the spacers and/or ALL's and /or UCA's?
Old 01-31-2011, 11:51 PM   #4
Go for bilstein 5100's all the way around.
Set the front to 2.5.
Get a 1.5 or 2 inch AAL for the back.
U won't NEED new uca's. 1.5 inches of lift is about as high as you go before you should get new ucas. Alignment still gets in/close to spec at 2.5.
Old 01-31-2011, 11:52 PM   #5
ColtsTRD's Avatar
ColtsTRD's Tacoma Gallery
x2
Thats a good lift for starts for sure!
Old 01-31-2011, 11:53 PM   #6
2.5* inches is about as high as you wanna go before uca's
*I want edit feature from TW mobile skin* :-D
Old 02-01-2011, 07:45 PM   #7
adamw's Avatar
so new uca's for 2.5"+ lift regardless if its a spacer lift or 5100s?
Old 02-01-2011, 10:48 PM   #9
You won't get more then 2.5 inches with 5100's. You'll be fine with no new ucas at that.
I'd assume 3 inch lift is 3 inch lift, so yah new ucas are reccomended at that point. Some people do, some people don't. Depends how well u want your alignment is spec.
Old 02-01-2011, 11:04 PM   #10
adamw's Avatar
if I just did 5100s up front set at 2.5" how much lift would i need in the back?
Old 02-01-2011, 11:19 PM   #11
You can go 1.5 or 2 inch Add a leaf. Stay away from blocks.
I have about 2.5 up front and went with 2 inch AAL. I think it looks great this way. But if u want less rake and more level go with 1.5 AAL.
Old 02-01-2011, 11:21 PM   #12
Here's mine with 2 inch AAL and 2.5ish up front.
Search around to find some more pics to see what you like.
Old 02-01-2011, 11:23 PM   #13
KalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shedKalamaKid is one of the sharper tools in the shed
Navy: Electrician
KalamaKid's Tacoma Gallery
Old 02-01-2011, 11:26 PM   #14
adamw's Avatar
yeah I like that its nice and what tire size can you get in with that set up?
Old 02-01-2011, 11:33 PM   #15
If u get an aftermarket wheel with backspacing of 4.5 you can fit 285/70/17 or 285/75/16. (same size different wheel size)
Even with this you'll have to do some plastic fender and mud flap trimming. Or get wheel spacers.
Or stay with 265/75/16.
Old 02-02-2011, 12:49 AM   #16
Navy: Electrician
285/75/16 and 285/70/17 are not the same size. The 285/75 will be bigger!
Old 02-02-2011, 12:58 AM   #17
Trifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shed
Trifenix's Avatar
Trifenix's Tacoma Gallery
Save up and get allied 4 inch lift spindles and AAL in the back.
Old 02-02-2011, 08:52 AM   #18
Zombie Killer!
705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed
705 Taco's Avatar
705 Taco's Tacoma Gallery
Nothing wrong with a small block. I ran a 2 inch Deaver pack and a 1.5 inch block for 3 years on my previous truck with no problems.
Old 02-02-2011, 08:57 AM   #19
Zombie Killer!
705 Taco's Avatar
They are pretty close.
Original tire
Sidewall: 8.42 in
Radius: 16.42 in
Diameter: 32.83 in
Circumf: 103.14 in
Revs/mile: 614.31
New Tire
Sidewall: 7.85 in
Radius: 16.35 in
Diameter: 32.71 in
Circumf: 102.76 in
Revs/mile: 616.60
Speedometer reading with new tire is 0.37% too fast.
When your speedometer is reading 60mph you are actually traveling 59.78mph.
Old 02-02-2011, 10:10 PM   #20
adamw's Avatar
if i set them at 2.5 would i need spacers/coils or would i be good to go?
3" lift options CentralFlaTaco 2nd Gen. Tacomas 9 06-02-2012 11:10 AM
Questions about 3" lift options trdr6 Suspension 22 12-20-2010 09:01 PM
3" Lift Tire/Wheel lift options. dman597 Wheels & Tires 17 09-21-2010 03:14 PM
Options for 6" lift? memario1214 Suspension 5 08-22-2010 12:42 PM
2" lift options tacoman101 Suspension 3 07-24-2009 07:49 PM
