Light Racing UCA install ?
Old 02-07-2011, 09:12 PM   #21
If at first you don't succeed, don't try skydiving
colinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shed
colinb17's Avatar
colinb17's Tacoma Gallery
huh, that's odd. the part numbers match and everything. they probbaly mean the same thing. i'd bet that somewhere in your instructions it probably says that there are 2* of caster built into the arms, whereas in OZ's, it probably doesn't. just a gues
Old 02-07-2011, 09:13 PM   #22
OZ-T's Avatar
OZ-T's Tacoma Gallery
Originally Posted by brutalguyracing View Post
not the same ^^^^^
this are the specs from my lr uca's
What are you saying ? The spec sheet I posted is wrong ? Because it is the one that came with my UCA's from Toytec .
Discuss
Old 02-07-2011, 09:14 PM   #23
BIG DADDY
brutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shed
brutalguyracing's Avatar
brutalguyracing's Tacoma Gallery
as i understand it lr uca have +2* to -2* adjustment
not 4*
Old 02-07-2011, 09:14 PM   #24
BIG DADDY
Discuss
mabye you got the version
Old 02-07-2011, 09:15 PM   #25
OZ-T's Avatar
From Toytec in Colorado , USA ?
Old 02-07-2011, 09:18 PM   #26
colinb17's Avatar
haha
if i've read correctly they have +2* built in, meaning relative to stock, you can go from 0* to 4*. but that's without a lift.
i think you both probably have correct instructions, but they were rewritten (reworded and a new diagram), maybe to do away with this very confusion we're having right now
Old 02-07-2011, 09:21 PM   #27
BIG DADDY
Originally Posted by colinb17 View Post
haha
thats incorrect........
you can go to .-2 -0- +.2
i have min set at -2* to stop from rubbing on the body mounts
Old 02-07-2011, 09:21 PM   #28
OZ-T's Avatar
haha
Maybe Scott just can't read too good .
Duh , me Scott , me like NY Rangers
Old 02-07-2011, 09:23 PM   #29
OZ-T's Avatar
The diagram on mine shows 0 to 4 degrees of motion with 2 being the ' neutral' setting , so essentially it would be the same range of motion , no?
Old 02-07-2011, 09:25 PM   #30
colinb17's Avatar
is the ball joint position set at -2, or is the alignment number on your printout -2? because with two degrees of caster built in, those are two different things.
Old 02-07-2011, 09:26 PM   #31
colinb17's Avatar
that's the impression i was under. at the zero setting, you are getting 2* of caster over stock.
Old 02-07-2011, 09:27 PM   #32
BIG DADDY
thats total adjustment........
look at your numbers in the small print thats the adjustment on the ball joint itself....
those are the correct #'s
Old 02-07-2011, 09:28 PM   #33
BIG DADDY
im at -2* "ball joint towards front of truck
negative
Old 02-07-2011, 09:29 PM   #34
BIG DADDY
do any of youz guyz know or remeber the size of the lr ball joint nut???
i thinking 1 1/4"
Old 02-07-2011, 09:30 PM   #35
OZ-T's Avatar
I see what you are saying Scott , the small numbers on my diagram match the numbers on yours , right ?
Old 02-07-2011, 09:31 PM   #36
colinb17's Avatar
negative
then i'm confused.
at 2.5 inches of lift, stock UCAs, my caster was at .6 then with the LR arms set at zero (spc logo facing out), alignment was at 2.6
Old 02-07-2011, 09:32 PM   #37
OZ-T's Avatar
then i'm confused.
I was thinking the same as you Colin
Old 02-07-2011, 09:37 PM   #38
BIG DADDY
then i'm confused.
g/l
Old 02-07-2011, 09:40 PM   #39
OZ-T's Avatar
g/l
Hey don't get pouty , nobody said you were wrong . And it does seem odd that are two sets of specs for the same product . When did you buy yours ?
Old 02-07-2011, 09:42 PM   #40
colinb17's Avatar
i'll try to remember to check my sheet tomorrow and see which version i have. i want to say it's the one with the zero in the middle. i got mine about a year ago.
Light Racing UCA Install avengedkevinfold Suspension 36 02-14-2014 06:22 AM
Light Racing UCA Install chvymechanic 1st Gen. Tacomas 7 10-19-2011 08:07 AM
tires rub after light racing uca install and align 07TaCo07 2nd Gen. Tacomas 8 08-08-2011 02:06 PM
Light Racing UCA Install Help/Question?? plee33 Suspension 8 07-24-2011 01:04 AM
Light Racing UCA Camber setting install Question Dr.D Suspension 2 01-07-2011 10:04 AM
