5100 set at 0.85 with 10 mm top spacer and Rear TSB
Old 02-06-2011, 06:10 AM   #1
5280EM! [OP] 5280EM! is offline
5280EM! is on a distinguished road
5280EM!'s Tacoma Gallery
Weird question but I thought I would throw this out.
So I have been reading tons of topics and searching for this question and couldn't find an answer. Does any body have this set up?
The reason I ask, is 5100 at 0.85 still has the factory rake and 5100 at 1.75" is either level or slightly higher than the rear. If I set the 5100 to 0.85 the shocks should still have enough travel for a smooth ride and still give me a even lift.
So with 5100's set at 0.85" along with a 10 mm top spacer. This should yield a 1.35", lift unless I am wrong. Please do not bash on me since I am a noob at doing truck lifts.
Old 11-12-2012, 08:40 PM   #3
Captain
Juggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shed
Juggernaut's Avatar
Juggernaut's Tacoma Gallery
Funny, I was thinking about this too and then I found this thread. Bump.
Old 11-12-2012, 08:44 PM   #4
aphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shedaphex is one of the sharper tools in the shed
aphex's Avatar
aphex's Tacoma Gallery
FWIW... I ended up getting Eibach coils and setting the 5100's @ 0". Lift was the advertised 1.6", my rear is only 0.5" higher w/ TSB (basically level), and I couldn't be happier.
How much lift w/ 5100 set 0 and Eibachs w/ 1/4" top plate spacer driver side Gabe911 Suspension 7 01-30-2012 07:34 PM
5100's at .85 and top spacer mako86 Suspension 0 10-01-2011 07:48 AM
5100's @ 1.75 w/ TSB & 5100's @ .85/Eibach coils w/ TSB springs and TSB AAL huntark03 Suspension 0 09-27-2011 01:50 PM
3/4 top spacer lift with 5100's set at 1 inch? tacoma02 Suspension 5 01-15-2011 07:46 AM
5100's Set to 0.85 or 1.75 with TSB?? canuck_tacoma Suspension 22 11-10-2010 06:03 PM
