5100 lift
Old 02-09-2011, 08:48 PM   #1
sinaloa226 [OP] sinaloa226 is offline
SIINALOA 226
sinaloa226 is on a distinguished road
sinaloa226's Avatar
sinaloa226's Tacoma Gallery
5100 lift
Thinking of going the bilsteins 5100 set at 1.75 and eibach springs to get a full 3 in of lift. Had anyone have had problems with this setup?
Old 02-09-2011, 08:49 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
That would give you over 3" lift, and kill your CV's.
Old 02-09-2011, 08:52 PM   #3
SIINALOA 226
sinaloa226's Avatar
So how would i get 3 in?
Old 02-09-2011, 08:55 PM   #4
chris4x4's Avatar
Set the 5100's at the .85" setting, and that will give 2.5", or a little more. Much better for your CV's.
Old 02-09-2011, 08:57 PM   #5
The Little Truck That Could
Yoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shed
Yoytoda's Avatar
Yoytoda's Tacoma Gallery
2.5" is probably all you want for your cvs... but people get 3" all the time with OME
Old 02-09-2011, 08:58 PM   #6
Tacomas FTMFW!!!!
sir1123 has much to be proud ofsir1123 has much to be proud ofsir1123 has much to be proud ofsir1123 has much to be proud ofsir1123 has much to be proud ofsir1123 has much to be proud ofsir1123 has much to be proud ofsir1123 has much to be proud ofsir1123 has much to be proud of
sir1123's Avatar
sir1123's Tacoma Gallery
toytec says you can set the shocks on the second c clip with the eibachs and get 3 inches an if you worried about cv boot get a diff drop kit
Old 02-09-2011, 08:59 PM   #7
SIINALOA 226
sinaloa226's Avatar
Ok thanks
Old 02-09-2011, 08:59 PM   #8
Tacomas FTMFW!!!!
sir1123's Avatar
"1.5 to 3" lift kit with Eibach front coils (3" average lift is achieved with coils and setting the shock adjustment on the second C clip setting from the bottom) DO NOT EXCEED THIS SETTING OR DAMAGE CAN OCCUR"
from toytec page
Old 02-09-2011, 09:01 PM   #9
Yoytoda's Avatar
FYI diff drops dont do anything...
Old 02-09-2011, 09:03 PM   #10
Tacomas FTMFW!!!!
sir1123's Avatar
how so?
Old 02-09-2011, 09:03 PM   #11
chris4x4's Avatar
X2.
Old 02-09-2011, 09:06 PM   #12
Tacomas FTMFW!!!!
sir1123's Avatar
so they dont help witht the angles orrr.........
Old 02-09-2011, 09:10 PM   #13
Yoytoda's Avatar
how so?
they only rotate the diff... not drop it... they go under the front mounts thus lowering the front and rotating the rear mount (which is the axle) so it doesnt actually drop the axle... so cv angles dont change.
they can actually possible do more harm because the make the diff mounts more prone to damage and the also rotate the pinion to be high and not is the oil as much. With good oil it shouldnt matter but is something to think about
Old 02-09-2011, 09:12 PM   #14
Tacomas FTMFW!!!!
sir1123's Avatar
but the front does actually drop though.?
Old 02-09-2011, 09:15 PM   #15
Yoytoda's Avatar
the front of the mount...
hold a pencil (axle mount) by the eraser in you thumb and index finger. image the eraser is the axle (perpendicular to the pencil). if you lower the tip of the pencil the eraser only pivots, it does not get lower
Old 02-09-2011, 09:15 PM   #16
chris4x4's Avatar
The front of the diff, Yes. But not the axels.....not enough to actually help the CV's.
Old 02-09-2011, 09:18 PM   #17
Tacomas FTMFW!!!!
sir1123's Avatar
well good thing i have a prerunner....no cv's.... but thanks for the new info appreciate it
Old 02-09-2011, 09:23 PM   #18
Yoytoda's Avatar
stupid illustration i made... you can see with the front bracket lower the axle stays the same height, it just rotates...
Old 02-09-2011, 09:24 PM   #19
Tacomas FTMFW!!!!
sir1123's Avatar
so why even make em?
Toytec Ultimate lift kit V.S. Bilstein Adjustable lift kit with 5100 shocks whiteboytoy05 Suspension 19 03-14-2015 05:10 PM
OME Suspension lift kit or Bilstein Adjustable lift kit with 5100 shocks Krasus22 Suspension 42 08-12-2011 08:42 AM
OME Suspension lift kit OR Bilstein Adjustable lift kit with 5100 shocks regcabtaco Suspension 20 07-04-2011 05:06 PM
Bilstein 5100 Part # for 3" of rear lift??? Longer than standard 5100 Deathbeard Suspension 3 01-24-2011 04:49 PM
3" ProComp lift kit VS. Bilstein Adjustable lift kit with 5100 shocks wangluoqis Suspension 6 01-24-2011 03:48 PM
