883 or eibach coils
Discussion in 'Suspension' started by cantac09, Feb 15, 2011.
  1. Feb 15, 2011 at 5:19 PM
    cantac09
    cantac09 [OP] Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    would the 883 or eibach coils get rid of the taco lean, or atleast make it less than 1/2 inch?
  2. Feb 15, 2011 at 5:24 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    I think if you put a sportster in the back of the truck, no one would notice the lean....
  3. Feb 15, 2011 at 5:26 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    do you mean the rake or the drivers side lean? because for the drivers side lean you can buy a 1/4"(?) spacer i believe, which would fix it
    EDIT: here is a link for the driver side lean fix as for the rake, they are about the same and i dont think they would level the truck on its own
  4. Feb 15, 2011 at 5:28 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    drivers side lean. ya i know about the 1/4 inch spacer but i also want to lift the front of my truck about 1 to 1 1/2 inches because the rcd sits ass high especially with the canadian leaf pack.
  5. Feb 15, 2011 at 6:51 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
  6. May 16, 2014 at 8:49 PM
    Bear Jew
    Bear Jew Member
    Brennan
    Addis
    2014 dcsb TRD off road
    I just purchased the billys and 883 coils, according to my research, that should level our trucks out pretty good! Gonna get them installed soon so I should have some concrete answers soon.
  7. Jun 28, 2014 at 8:12 PM
    TacomaJay09
    TacomaJay09 Well-Known Member
    Central MA
    09 TRD Sport Dbl Cab
    None Yet
    So what's the report?
  8. Jun 29, 2014 at 8:11 AM
    Bear Jew
    Bear Jew Member
    Brennan
    Addis
    With the Billy's and the 883 coils and driver side top plate spacer, I'm under a quarter of an inch lower in the front than in the back on driver and passenger side. I find the ride to be way more "grounded" than before......a lot less jumpy while making highway maneuvers. Very happy with the look.
  9. Jun 30, 2014 at 5:59 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    What kind of wheeling do you do with your truck? True, you can run a really stiff spring, like the 883, and it will help with some of your lean. But, it won't flex at all off road and will be stiff on the road. Really, you want to bump up only one side of your rig. The best way to do that is with a coilover, so you can continually adjust it, as your springs break in. If you don't want to spend that kind of money, I'd just get a spring with a spring rate appropriate for the weight of your truck and run the 1/4 inch spacer.
    Just my 2 cents.
  10. Jun 30, 2014 at 8:17 AM
    TacomaJay09
    Central MA
    None Yet
    Were you able to get a good alignment with them? What were your alignment numbers? Did you also install UCA's? Thanks
