How Much Lift With OME Kit?
Discussion in 'Suspension' started by Sprink21, Mar 15, 2011.
  1. Mar 15, 2011 at 6:41 PM
    Sprink21
    Sprink21 [OP] Well-Known Member
    Jon
    Vancouver, WA
    2010 dbl cab 4x4
    K&N Intake, AirAid Throttle Body Spacer, Banks CatBack Exhaust
    I ordered my OME lift with 885s, dakars, and the overload leaf kit for the dakars for my dbl cab long bed. Will this setup give me 3" up front and if not what size top plate spacer will I need to get 3"? I want it to sit as level as possible with maybe the rear sitting just a little higher. Thanks.
  2. Mar 15, 2011 at 6:43 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    you should get a full 3".
    I have 885s on my prerunner and am getting a little over. Since your a little heavier in front being a 4x4 you should get right at 3
  3. Mar 15, 2011 at 6:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should get close to 3" lift. If not, measure the amount of the left, and then decide how much more you need. A 1/4" spacer yields 1/2" lift.
  4. Mar 15, 2011 at 6:44 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    U will be good without the spacer from my experience. I had to take mine off cuz I was sittin too high.
  5. Mar 15, 2011 at 6:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You have a reg. cab. He has a double cab long bed.
  6. Mar 15, 2011 at 6:49 PM
    especk
    Erik
    Redding, CA
    I know. I took that fact into my response.
  7. Mar 15, 2011 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....well, the 885's seem to give between 2.5" and 2.75" lift on the double cab 4x4's. If the OP wants an even 3", he's gonna have to see what he gets first, before getting teh spacers.
  8. Mar 15, 2011 at 6:52 PM
    crawldad
    crawldad Well-Known Member
    2016 TRD OR 4X4 Quicksand
    Did this 3 days ago on my dbl cab. I got over 3", but it should settle close to 3.
  9. Mar 15, 2011 at 6:53 PM
    especk
    Erik
    Redding, CA
    This ^^^^^^^^^^^^^^^^^^^^ :D
  10. Mar 15, 2011 at 6:53 PM
    especk
    Erik
    Redding, CA
    This ^^^^^^^^^^^^^^^ :D
  11. Mar 15, 2011 at 7:05 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Spacers or no ?
    Prerunner or 4x4 ?
  12. Mar 15, 2011 at 7:08 PM
    crawldad
    No spacers, 4x4.
  13. Mar 15, 2011 at 7:08 PM
    ColtsTRD
    Scott
    AZ
    Mines a dbl cab prerunner...my suspension has settled and i'm a smidge over 3" I just measured it...no top plates for me
  14. Mar 15, 2011 at 7:09 PM
    OZ-T
    Peter North
    British Columbia
    Sweet , thanks .
    That what I have in boxes in my shop :)
  15. Mar 15, 2011 at 7:09 PM
    OZ-T
    Peter North
    British Columbia
    Thanks , Scott
  16. Mar 15, 2011 at 7:15 PM
    Sprink21
    Jon
    Vancouver, WA
    2010 dbl cab 4x4
    Thanks for the fast response guys.
  17. Mar 15, 2011 at 7:21 PM
    ColtsTRD
    Scott
    AZ
    Pollard your actin' like a girl out there...whater you a girl or somethin'???
    Wait...where am I??
  18. Mar 15, 2011 at 7:59 PM
    B...
    B... Member
    SLC, Utah
    some of this, a little of that
    Yep. Just a hair over 2.5" of lift on my double cab 4x4 with 885s.
  19. Aug 8, 2011 at 10:32 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Nashville, TN
    2014 SSM Trd Off Road 4x4 Auto
    can someone explain to me why the Ome 885's with 5100 billies aren't yelding the 2.75 or 3 inches on a 4x4 ac when the double cab seems to weigh more. I installed mine goin frombillies set at 2.5 to omes and billies at stock but looks nothing like what people are saying
  20. Aug 8, 2011 at 10:41 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    did you add the top plate spacer? you're looking pretty stock there on your first pic. second pic looks about right
