3 inch spacer lift ++++?
Discussion in 'Suspension' started by Redtaco77, Mar 15, 2011.
  1. Mar 15, 2011 at 7:50 PM
    Redtaco77
    Redtaco77 [OP] Well-Known Member
    Brandon
    Texas
    08 PreRunner
    3'' lift and striaght pipes!
    I have a 3 inch spacer suspension lift on my 08 Tacoma. I want to get 2-3 more inches of lift. I was thinking of a leaf pack with aals for the back to give me 2 more inches. Is there a way to lift up the front some more without going to a body lift? Thanks for the help!
  2. Mar 15, 2011 at 7:53 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    If you want to run 3+ you will have to buy a drop bracket lift.. or get lift spindles (didn't realize you had a PreRunner)
  3. Mar 15, 2011 at 7:53 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    spindles
  4. Mar 15, 2011 at 7:54 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    Spindles:D
  5. Mar 15, 2011 at 8:18 PM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    What brand of spindles do you suggest? I am trying to keep it reasonable
  6. Mar 15, 2011 at 10:02 PM
    TexasTacoma37
    No spindles are reasonably priced. There are none much under $1000.
    The only ways to get over 3" of lift in the front are spindles, drop bracket (which costs more than spindles), SAS, or 3" suspension +3" body.
  7. Mar 16, 2011 at 9:49 AM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    Dang even for just 2-3 inch spindles!? Sounds like I should of planned a little better
  8. Mar 16, 2011 at 9:53 AM
    TexasTacoma37
    Total Chaos makes 3.5" Spindles. All the rest are 4".
  9. Mar 20, 2011 at 6:07 PM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    So I could install a body lift for cheaper and easier? I have a 2wd and am just going for looks.
  10. Mar 20, 2011 at 6:10 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    body lifts look gay. i recommend to never get a body no matter what
  11. Mar 20, 2011 at 6:12 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    just get spindles and loose the spacers.
  12. Mar 20, 2011 at 6:19 PM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    I was just wanting 2" more lift and dont think a 2" body would be that noticeable? How hard is the install on spindles?
  13. Mar 20, 2011 at 6:29 PM
    ktmrider
    Junk
  14. Mar 20, 2011 at 7:36 PM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    Any idea how much a shop would charge for install?
  15. Mar 20, 2011 at 8:22 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    if you want 2 inches just get bilstein 5100's
  16. Mar 20, 2011 at 8:38 PM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    Will that give me an additional 2" if I have a 3" spacer already?
  17. Mar 20, 2011 at 8:40 PM
    ktmrider
    Junk
    no not without consquences.
  18. Mar 20, 2011 at 8:42 PM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    Like what?
  19. Mar 20, 2011 at 8:50 PM
    ktmrider
    Junk
    well first depending on if your spacer is top plate or preload, if you could actually jam down the lower control arm to fit in, your upper and lower ball joints will fail and you will either bottom out or over extend your shocks on bumps.
    leading to this
  20. Mar 20, 2011 at 9:29 PM
    Redtaco77
    Brandon
    Texas
    08 PreRunner
    Well I am not sure which one it is but I am assuming top plate. It is the simple spacer that just bolts on top. Would one work and the other kind fail?
