884 for a dble cab/ install
Old 04-03-2011, 12:27 PM   #1
elwood [OP] elwood is offline
"Really, how hard can it be?" Jeremy Clarkson
elwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shedelwood is one of the sharper tools in the shed
elwood's Avatar
elwood's Tacoma Gallery
This is the follow up thread for those interested in the one i started about putting an ome 884 or 885 into a double cab. I know that many members have installed various ome products and the results seem to vary from time to time. These are my results. Everybody needs to do their own research and decide for themselves what best suits them for their purposes. I used the results from others and advice from people before making my decision. I post this in hopes it helps somebody as others have helped me.
link to the first thread http://www.tacomaworld.com/forum/sus...ouble-cab.html
I wanted to lift around 2 inches and keep some rake for when we tow. I plan on keeping stock tire diameter so my ratio while towing is not affected. I wanted to avoid uca changes , alignment problems and drive line issues if at all possible. I had the tsb completed last jan 2010 with around 58000 km (36000 miles) . Now the truck has 77000 km (47846 miles). We tow approximately 5-7000km (3-4500 miles ) per year. We have a leer 100r cap. The stock Dunlop tires are 245 75 16 and are still on. I will not be changing the tires for a couple of weeks so that a new tire feel or balancing issues wouldn’t be miss interpreted as something from the lift products. An alignment will be completed in a couple of weeks just after the new tires are installed.
Products purchased—OME 884 coils, 9000 sport/ n-182 shocks, tsb aal (deaver), 5 mm spacer, and cb drop ( to be installed if required) , new u bolts and hardware. Thanks Toytec. I had obtained a stock set of struts from a 2010 with 5000 km (3000 miles) so the top mounts could be used for the new coils (saved money here). I will keep my original struts unmolested . I have obtained a used all pro skid (good price) for the “just in case”.
I had the two new struts preassembled before starting. Installation went surprisingly well. I am not a mechanic but think of myself as pretty hands on and have been intimate more than a few times with various vehicles over the years. I had printed out the sticky’s so i had the proper torque’s for the various bolts and pictures. The front two struts where changed in about 3-4 hrs by myself. The rear took 4-5 hours the next day, again by myself. I had to remove the sway bar completely on the front to help me and i found that 2 C clamps compressing the rear pack back together with the aal inside helped keep the hole lined up better. I noticed that the aal leafs where not exactly the same. One had a ¼ inch more arch than the other. I put that one on the drivers side because of the gas tank. Really have to watch the rubber break lines to the axle. I had removed the bracket but the new center pin was so long that when the axle was lowered to re-insert the pin from underneath i noticed the lines looking tight. I gently moved the bracket away from the axle and then it went in. Could have cut the pin shorter first but didn’t want the threads to be mangled or flattened to allow proper tightening. The bottom of the ome rear shock had trouble entering the stock mount. Either the original had been over tightened or the bushing of the new one is a little longer?? Not sure but both had to be widened before the new shock would fit in, with encouragement . After the front was done and before any work was started on the rear i drove a few miles to see what it felt like. This way anything different could be identified as resulting from the fronts work and not the back. All was fine.
I have drove the truck a few times now and have not felt anything odd. The cb drop has not been installed yet. The skid plate is installed now ( apprx 40 – 50 lbs) and i have a very large piece of concrete in the rear (that i use for winter weight) to help settle everything in before the alignment and new tires in 2 weeks.
The ride is really not much firmer or harder than the stock but it does feel more “controlled”. I never actually disliked the stock ride but found it lacking in control. When driving over some larger pot holes or a set of not to friendly railway tracks it seemed to over react and seemed wild, like it was too much to handle and you should have slowed down more. The new set up handles these and seem to say is that all you can throw at me. Seems more grown up. The way it should have been from the factory IMO.
Pics of the parts and some installation are in my gallery. These two are the before and after. The after has the weight in the rear and the skid underneath. Will post measurements after the alignment.
Cheers.
884 for a dble cab/ install-stock-winter-tires-.jpg   884 for a dble cab/ install-after-lift-2-.jpg
Old 04-03-2011, 12:41 PM   #2
Goldmember
NC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shed
NC15TRD's Avatar
NC15TRD's Tacoma Gallery
Great write up! Gonna get mine soon, also what are the measurment differences?
Old 04-03-2011, 12:54 PM   #3
elwood's Avatar
Just quick is about 2 inches front and 2 1/4 rear. I am hoping the rear comes down. We have a trip planned in a few weeks with the trailer so that should help settle them. I think after the alignment the front should be about the same. Doesn't really feel that bad driving it now, no wandering and such.
Old 04-03-2011, 01:15 PM   #4
elwood's Avatar
Just want to post some acknowledgements for the help i recieved from various members. Chris4x4 is worth his weight in gold for the data, NFL for going this way first, Squad314 for the pic of his truck as the basis for what i was going for, taco4x4nc and fabulous for being as accurate as possible. Their experiences and insight helped me make my decisions.
Cheers to all you guys.
Old 04-03-2011, 02:20 PM   #6
JC47 is on a distinguished road
JC47's Tacoma Gallery
Good job, looks great. So the new tires will be the same size? I'm curious to know how much the rear end will settle.
Old 04-04-2011, 05:31 AM   #7
elwood's Avatar
The new tires will be the same diameter but i might go up in width. A 265/70/16 is the same diameter as a 245/75/16 ,just wider. Any increase in width will affect mileage , to some degree,depending on the rolling resistance to the rubber. My task now is to find which to get and what size.
I have several hundred pounds in the rear now to help it settle before alignment.
Old 04-04-2011, 05:32 AM   #8
elwood's Avatar
Thumbs up
Originally Posted by OZ-T View Post
Your truck looks great elwood
Thanks Oz
Old 04-04-2011, 07:14 AM   #9
NLF NLF is offline
NLF is on a distinguished road
NLF's Tacoma Gallery
Looks good, glad the install went smoothly. You're making me consider a topper...
Old 04-04-2011, 04:51 PM   #11
elwood's Avatar
Originally Posted by raycie View Post
You gained only 2" with the 884s?
yup, thats what i was going for.
Old 05-03-2011, 05:48 PM   #12
elwood's Avatar
It has been a couple of weeks now and I have had the alignment completed (twice) and the new tires installed. We have just returned from a week and half fishing trip while towing the trailer ,without using the weight distribution system. I was hoping the real world activities would help me give the most accurate results to the forum.
My first alignment was completed at the dealership. They had managed to get one side pretty close but the other not. Toe was 0 both sides, camber was 1.1 and .7 and caster was 1.4 and 1.6. All within the allowed ranges and all they would do. This was fine as all i wanted them to give me was a toyota sheet saying it meet their specs and thus I would have ammo in case of a warranty issue. The next alignment , at a real truck shop, was 0 toe again, .2 and .1 camber and 1.4 caster. That was all the guy could get unless i wanted to give up some camber. Had hoped for a little more but thats all she had.
The new tires are 265/70/16 michelin ltx at2's. Very impressed with them on ride and quietness.
Like I said we have towed now for 1000km and used the truck for around 3 weeks and put 2000 km on it. Have checked all torques and only 1 of the 8 u bolts took a 1/8 of a turn more before "click" at 75 lbs.
Ride height is front 22 and 1/4 and rear 24 and 1/8 hub to fender.
Have not installed the cb drop. I have had the very subtle 5 mph vibe or shimmy since new and it has not changed with the lift.
Over all impressions is an improvement in capabilities for load, on the hitch and in the back for cargo ,and smoothness on the highway which i attribute mostly to the tires. Better than stock anyways.
I had concerns with the front feeling loose on the highway with the trailer on and little caster. It was "ok" for this trip as the wind was quite calm on the days pulling. Drove normal with one hand on the wheel without the weight distribution hitch. I have NOT dismissed the possible swap of the UCA tho. Being in canada and the salt Chris has suggested the LR as it has a sealed ball joint. I will be looking into this and what it will and won't do for me and cost before our fall trips. I could be a fussy middle aged guy but for a few hundred bucks to have everything spot on is not out of the question.
Hope this helps somebody and will keep my updates and results coming, even if they are slow.
Cheers
Old 05-03-2011, 06:14 PM   #13
attack ships on fire off the shoulder of Orion
OZ-T's Avatar
OZ-T's Tacoma Gallery
I got the LR UCA's , you can't go wrong , especially here .
Old 05-03-2011, 06:21 PM   #14
elwood's Avatar
Thanks Oz. i am leaning that way now but with our son home from college and starting work priorities have shifted to a new bed new back door on the house.
Did you get yours from fat bob or ??? Noticed fabian did and the price is cheaper than the web site says???
Old 05-03-2011, 06:26 PM   #15
OZ-T's Avatar
I got mine from Toytec , but I will admit to not shopping around too long , there very well could be a cheaper alternative .
Old 05-09-2011, 08:12 AM   #16
DestinTaco is on a distinguished road
DestinTaco's Avatar
DestinTaco's Tacoma Gallery
I got 2" with my 884's as well.
Old 05-09-2011, 05:44 PM   #17
elwood's Avatar
how do you like the results?
I have 400 lbs of concrete in the back of the truck to simulate all the gear for a trip and the trailer has a tongue weight of 380 to 400 lbs.
Old 05-11-2011, 08:39 AM   #18
DestinTaco's Avatar
I'm happy with it.
Old 06-30-2012, 11:02 AM   #19
greenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shedgreenrustic is one of the sharper tools in the shed
greenrustic's Tacoma Gallery
Sweet looking rig! Thanks for putting this together. I have been looking at a similar set up but am thinking about using 5100's instead of the ome shocks because I can put it all together for a little less $$$ and I hear they will offer a little firmer ride. I do have a few questions for you. Have you had any settling of the front coils or are they holding firm at 2"? Did you use a top plate spacer or trim pack to compensate for the drivers side lean? Have you been happy with the aal and the tab pack or have you made any changes there? Did you ever get the alignment in spec? Thanks!
Old 08-31-2012, 10:21 PM   #20
froesen is on a distinguished road
froesen's Tacoma Gallery
wow, elwood, great looking rig, great write up, I'm doing research now and budgeting for my truck and this is what I would like. Thanks for posting all this.
Tires for a Prerunner Dble Cab ecr6cyl10 2nd Gen. Tacomas 11 09-01-2011 10:56 PM
**2003 EVOLUTION VIII trade for DBLE CAB taco** Sant0s Buy / Sell / Trade 52 08-30-2011 11:48 AM
FS: 2009 SR5 Dble Cab 12K miles ComaChic Buy / Sell / Trade 3 10-26-2010 04:02 PM
Ionic Railway tube steps 05+ dble cab f/s 64Wildcat Buy / Sell / Trade 8 05-04-2010 06:18 PM
Step Rails For 1st Ed Dble Cab Prerunner Toy Maker 1 Buy / Sell / Trade 0 06-22-2009 12:06 PM
