3" setup suggestions
Discussion in 'Suspension' started by KMADA, Sep 22, 2008.
  1. Sep 22, 2008 at 10:35 AM
    KMADA
    KMADA [OP] Well-Known Member
    Long Beach, CA
    08 prerunner trd sport
    15% tint, 6k HIDs, K&N intake
    here's my future setup
    FRONT:
    OME COIL SET
    OME N140s SHOCKS
    REAR:
    BILLYS 5100s shocks
    Wheelers long aal
    WHEELS:
    17" alloys black power coat trd sport
    285s BFG A/T KO
    Suggestions and thoughts appreciated thanks
  2. Sep 23, 2008 at 9:08 AM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Suggestion to your setup: Use Bilstein 5125 to the rear because they offer more travel and add extended brake lines.
  3. Sep 23, 2008 at 9:15 AM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    so i might install the revtec 3" spacer because les schwab puts a warranty on it and its 500 bucks with install, does anyone have some advice on whether or not i should change shocks or just let them put the spacer on, im new to this stuff
  4. Sep 23, 2008 at 9:30 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    New shocks means better ride. If you have the $$, go for it. If not, you can always do it later.
    +1
  5. Sep 23, 2008 at 10:48 AM
    KMADA
    Long Beach, CA
    Alright. So if I go with the OME rear shocks would I need to grab the OME leaf set and bushings etc?
  6. Sep 23, 2008 at 12:06 PM
    KMADA
    Long Beach, CA
    would you rather go with the toytec 3" lift lift OME 885 or would you buy the separate parts?
  7. Sep 23, 2008 at 12:34 PM
    Delrivpilot
    Delrivpilot Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    I got the TSB done on my rear springs and then used Toytec 2" spacers on the front. It lifted my rig about 2 to 2 1/2 inches/ Rides nice too. Just a thought. Good luck
  8. Sep 23, 2008 at 1:01 PM
    KMADA
    Long Beach, CA
    I'm gonna stick to the stock bumper, if anything I might add a bull guard but nothing to serious there. Would I be fine with 884 or 885 OME's.
    Upgraded setup for now..
    Rear:
    Bilsteins 5125s or OME N120s
    Also added brake lines. Then I'm fine rght?
    Also with the wheels would I need spacers? I know I'm gonna trim with 285s
  9. Sep 23, 2008 at 3:44 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    $500 for a 3" spacer w/ install is a rip off...u can buy a 3" spacer for less than $100...then the aal or blocks for the rear...its simple stuff to do.
  10. Sep 23, 2008 at 3:57 PM
    KMADA
    Long Beach, CA
    what if I just went with the toytec 3" lift spacers w/ aal. Plus shims. How would that go quality, look?
    Just a thought on advice lol
  11. Sep 23, 2008 at 3:58 PM
    KMADA
    Long Beach, CA
    or how about 5100s all around. Front at 2.5
  12. Sep 23, 2008 at 8:14 PM
    Neubs
    Maryland
    Here is a better setup:
    Front:5100 Adjustable Coil over (if you can afford it), if not 5100s will do just fine.
    Rear: AAL if you have not had the rear TSB done with 5125s and brake lines.
  13. Sep 23, 2008 at 8:27 PM
    KMADA
    Long Beach, CA
    Do you got any pics of that setup? I don't wanna sit too low
  14. Sep 23, 2008 at 8:30 PM
    Neubs
    Maryland
    With the coil overs you will get lots of lift. I am running mine under 3" but have lots of space to move up if I so choose to. You can click my galley for pics. I think Vege-Taco is running 3" on his rig.
  15. Sep 25, 2008 at 1:40 PM
    KMADA
    Long Beach, CA
    imma go with the 5125s rears. But I'm not sure where I can get a good deal.
    Btw I can't decide if I should go with the toytec 3" that comes with the 885, aal, spacer (299.99). Or should I buy the parts separate at wheelers for the OME coil set (156), aal (77.50), and spacer? Not sure which one
  16. Sep 25, 2008 at 5:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, my 885's gave me right at 3" lift with no spacers after they settled. Im running 5100 rear shocks and seem to have no flex limitations or "topping out" of the rear shocks. Instead of getting a longer rear break line, I reworked the existing braket, and have plenty of slack at full droop. IMHO, the 5100 rear shocks are a perfect match for the OME N140S/885's up front.
  17. Sep 25, 2008 at 8:39 PM
    random hero
    random hero Active Member
    01 "pre" 4runner
    Saw's, 2.0 fox 8" travel rear shocks, downey coils
    I agree... 3" spacer is going to nothing but destroy your stock suspension compents/coilovers, and ride terrible... You can buy a set of adjustable bilstein's for the front for under 200 bux and keep factory ride, my buddy just put a set on his truck and they ride great. That big of a spacer is nothing but bad news:
    Oh, and $500 is a complete rip-off! It literally takes 30 minutes to pull your coilovers and reinstall, very simple
  18. Sep 29, 2008 at 7:57 PM
    sooner02r1
    sooner02r1 Well-Known Member
    If you pay $500 for spacers for the front, please let me know the next time you are going to buy ANYTHING, not just truck parts. I'll sell it to you for 5x the cost. I need to make a little extra cash.
  19. Sep 29, 2008 at 8:52 PM
    random hero
    01 "pre" 4runner
    dude $500 is a STEAL!!! Labor to install the front coilovers @ my local dealer is $1600, just for one side:D
