Icon Add A Leaf or Skyjacker Leaf Springs?
Discussion in 'Suspension' started by trdracing5, Apr 10, 2011.
  1. Apr 10, 2011 at 5:24 PM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Ok based on the feedback I got on my previous post (http://www.tacomaworld.com/forum/1st-gen-tacomas/150223-my-rear-leafs-shot.html)I have decided that my rear leafs need some help.
    So which choice should I make?
    Option #1-GET A ADD A LEAF
    Icon Add A Leaf (approximately $180)
    Option #2-REPLACE THE LEAF SPRING
    Skyjacker Softride Lifting Leaf Springs (approximately $350 on sale from $425)
    I can get a crazy good deal on the skyjacker leaf springs. If it wasn't for the crazy good deal I would probably not even consider replacing the leaf springs.
    So any feedback on either option?
  2. Apr 10, 2011 at 6:11 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    if you can afford it, id say just replace the springs all together. youll get a better ride than adding an aal to what you have already.
  3. Apr 12, 2011 at 9:53 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I'm not familiar with the 1gen leaf pack, but it looks like yours could use replacement anyway.
    I would just make your choice on cost: want to spend it, get new leaf pack; don't want to spend it get an AAL, hell get a $50 AAL (no reason to spend $180 on an AAL, unless you're talking install too).
    You can also go to a spring shop and have your current leafs 're-arched' to factory height, then add the AAL for lift.
  4. Apr 14, 2011 at 4:43 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    I am interested in the skyjacker springs also. I think they offer 3.5 inches of lift which would be a little too much.
    Do they settle much for a level ride?
    Can you remove the overload spring for closer to 3 inches of lift?
  5. Apr 14, 2011 at 5:51 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The $180 is a 3-leaf progressive rate AAL that's supposed to ride a lot better than the cheap $50 single AAL.
    I'd go for the leaf pack if it's within your means and you plan to keep your truck for at least another 2 years. The AAL would be a temporary band-aid that would buy you some time but you'd be in the same situation in a few years. If you just need something temporary, get the cheap single AAL to get you buy for now. Kinda depends on your situation.
  6. Apr 14, 2011 at 7:25 PM
    nvdeserted
    Reno, NV
    Ah ha, I was gonna say, ICON has a hell of a scam going charging $180 for 2 leafs.
  7. May 19, 2011 at 3:31 AM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    Decided to go with the Icon Add A Leaf from downsouthmotorsports.com
    The brown truck just dropped it off and I will plan on installing this weekend.
  8. May 19, 2011 at 5:01 AM
    Pugga
    Massachusetts
    You won't be disappointed, I finally got mine installed and have been very happy with the results!
  9. Jan 30, 2012 at 8:09 PM
    stlstrs
    stlstrs Well-Known Member
    Northern California
    03 SAS DC
    Diamond SAS, AOR Front Bumper, AP Rear Bumper, BAMF Sliders, Inchworm Dual Cases
    What kind of results did you get with the AAL? How has everything held up? I have pretty flat springs and I am trying to decide if an AAL will fix it, or if I need to re-arch and AAL, or just break down and get a new pack.
  10. Jan 30, 2012 at 8:19 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    If I had to do it over again (and I had the money) I would have purchased the springs. The leafs are OK but are honestly just a temporary fix.
  11. Apr 4, 2012 at 1:16 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    What do you like and dislike about the Icon AAL?
  12. Apr 4, 2012 at 3:06 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    I think the AALs are ok. I think my leafs were beyond what a AAL could help so its nothing against the ICON AALs.
  13. Apr 4, 2012 at 3:21 PM
    Ryan07
    Ryan07 Well-Known Member
    New Brunswick
    07 TRD DC,LB Sport 4x4
    Icon Ext. Coilovers, LR UCA's, Icon AAL, Nitro 9000 Shocks, 7"Kragen HID's/Billet Grille, Extang Solid Fold Tonneau Cover, Bed Lights, Diff Breather Mod, D-Rings Mod, LED Interior Lighting/Plate Lights, LED 4X4 Switch, Viper Starter, AVH-P4200DVD, PAC Interface, OEM Backup Camera/Pop&lock, Wet Okole Seat Covers, Weathertech Mats, Husky Mud Flaps, 8000lbs Champion Winch/Winch Cradle and Quick Connect Kit, 4,500lbs Champion Winch/Front Hidden Winch Mount, OEM Painted Rims, Spidertrax 1.25, 265/70R17 BFG KO's
    Icon helped me out a lot.
    Before
    url=http://www.tacomaworld.com/gallery/showphoto.php/photo/237405/cat/500][​IMG][/url]
    After
  14. Apr 4, 2012 at 3:26 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I have the icon but if I ha the money go with all pro
  15. Apr 4, 2012 at 3:28 PM
    Ryan07
    New Brunswick
    Agreed:D
  16. Apr 4, 2012 at 3:29 PM
    BAMFTACO
    Juan
    Kings bruh
    Or deavers That be nice
