A 3" Lift That Rides Like Stock?
Discussion in 'Suspension' started by 311offroad, Sep 25, 2008.
  1. Sep 25, 2008 at 1:12 PM
    311offroad
    311offroad [OP] Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    I have been reading up on lifts for a few weeks and just wanted everyone's opinion on which kit/setup feels and rides the most like the stock TRD ride. I want to know everything from springs, to shocks, to spacers, etc... that match up for the best ride possible. Thanks
  2. Sep 25, 2008 at 1:52 PM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    bilstein 5100 replacement of the stock and give you higher 2.5" rides great
  3. Sep 25, 2008 at 3:29 PM
    DFPTaco
    DFPTaco It's TACO time!
    Josh
    Las Vegas, NV
    19 DC SB TRD OFF ROAD
    little lift, wheels and tires, prinsu rack, TRD Pro grille, some lights, and some scratches.
    i second that notion... It's how I'm rollin
  4. Sep 25, 2008 at 3:31 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    how much for a set up like that? seems like the perfect height
  5. Sep 25, 2008 at 3:31 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    you can go big money and put on a set of Sway a Way, Camburg, or IVD adjustable coilovers in the front and a custom leaf pack set from deaver or alcan and it'd ride like a brand new cadillac :D
  6. Sep 25, 2008 at 3:56 PM
    311offroad
    Milledgeville, GA
    haha appreciate the high dollar suggestion... but Im going to have to save up no matter what it costs... so Im going to go as cheap as possible without it being "ghetto"
    The bilsteins all the way around... anyone got some good comparison pics of that? i guess if I did that and the TSB I would be sitting pretty good right?
  7. Sep 25, 2008 at 4:26 PM
    311offroad
    Milledgeville, GA
    I just read that the Bilsteins on the front set at 2.5 will be substantially stiffer than stock. And that the rears are not adjustable and only lift it 1". I definatly want more than that in the back and although a little more stiffness in the front is fine... I do not want it to be too big of a difference from stock...
    Whats up with spacers and other cheap mods? Are they reliable?? Opinions plzzzzz!!!!
  8. Sep 25, 2008 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Spacers are going to affect the ride. Period. What o you want, lift or lift and ride quality.
    Lift = $
    Lift + ride quality = $$$$$$$
  9. Sep 25, 2008 at 4:42 PM
    311offroad
    Milledgeville, GA
    I know the ride quality is going to cost more. But at that I still want to spend as little as possible. So whats the best way to get 2.5" to 3" of lift with a good ride. The $300 for the shocks would have been perfectly fine... But i don't want that if it only raises the rear an inch. If I get the rear TSB and the bilstein rears will it stay lifted up a bit or are the springs going to settle like Ive heard a few people say?
  10. Sep 25, 2008 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The springs will settle in a bit. Mine settled about 1/2"
  11. Sep 25, 2008 at 6:52 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My toytec 3" lift rides better than stock imho. (a little stiffer but not much.) I have the TSB done and a 1.5" block. If you have a DC truck Toytec reccomends the 885 coils I however got the lift before they made that suggestion, I have the 884 coils. The Tsb has settled and so have the front coils, it looks level to me. The price I paid for the lift to my house was $460 and I installed it with the help of a friend. I also installed the diff drops (rear is a shim) and all other drops. You could get it cheaper and make your own hanger drop, front diff and front skid.
    Skid and front diff drop.
    Hanger bearing.
  12. Sep 26, 2008 at 10:12 AM
    311offroad
    Milledgeville, GA
    That was the lift I was kind of leaning towards. But would it be better for me since I haven't done the TSB to just AAL in the rear and not use blocks? In other words does the AAL give it the full 3" in the back? And then the front 885 coils and Bilsteins 5100s all the way around. That sound like a good plan that would be level?
