2011 Taco 4x4 DC SB Sport, 5100's, Rear TSB, Alighnment Specs!
Discussion in 'Suspension' started by rp2000r, Apr 18, 2011.
  1. Apr 18, 2011 at 9:18 PM
    rp2000r
    rp2000r [OP] Well-Known Member
    2011 Tacoma DC SB TRD Sport
    Truck had 700 miles when 5100's were installed @ 1.75 which leveled the truck. TSB was done at 1000 miles. After 50 miles the rear is .8-1 inch higher and noticeably stiffer.Perfect for my needs.
    Rodlund Toyota performed the TSB Hassle Free in everett WA, No inspection required.
    Here are alighnment specs:
    Is the difference in the front left from Taco lean? or was the tech lazy?
    Thanks for any input.
    Front : Left
    Actual Before Range
    1.1 1.1 -0.3-1.2 Camber
    1.6 1.6 1.3-2.8 Caster
    0in -1/16in 0in 1/32nd Toe
    10.9 10.9 11.2-12.7 SAI
    12.0 12.0 11.0-14.0 Included Angle
    Front : Right
    Actual Before Range
    .6 .6 .03-1.2 Camber
    0in -1/32in 0in 1/32in Toe
    11.4 11.4 11.2-12.7 SAI
    Front:
    Actual Before Range
    0.5 0.5 -0.5 0.5 Cross Camber
    0.0 0.0 -0.5 0.5 Cross Caster
    -0.5 -0.5 Cross SAI
    0in -3/32nd -1/32in 3/32in Total toe
