Wheelers Off-Road Bumpstops: Who's got them?
Discussion in 'Suspension' started by 08pretaco, Apr 25, 2011.
  1. Apr 25, 2011 at 10:32 PM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Timbrens are about 350-400 for the front and rear setup...
    Wheelers has a set for $175: Who has them on and has some feedback they would like to report with?
  2. Apr 25, 2011 at 10:37 PM
    Ptowntaco
    Ptowntaco Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    x2 would also like too know
  3. Apr 26, 2011 at 5:53 AM
    TexasTacoma37
  4. Apr 26, 2011 at 6:14 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    yup...they're the TITS!!!!
    from what i understand, they feel better on the truck b/c the timbren is just a huge chunk of rubber w/ no give and these superbumps actually have some give/compression to them to soak up the bumps when they are hit. i can feel my rear ones hit when carrying stuff in the bed (that's also w/ them compressing completely down), but i've never felt the front ones hit and i know they have.
    YotaDan likes this.
  5. Apr 26, 2011 at 6:34 AM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    I have them in the front and like jhodge said I know they have hit before but I never even noticed it. I will say they are very soft and way better than stock but I have never had or seen a set of timbrens so I don't know how they would compare. I would recommend them and I will be getting the rear set when I save up some more money.
    YotaDan likes this.
  6. Jul 3, 2012 at 6:49 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    just installed Wheelers Superbumps on the front. For the install the supplied allen key was too long to get it to fit between the lower arm and into the bumpstop to tighten the bolt. I cut the Allen key shorter to fit. Also use locktite on the threads to secure the bolt from loosening under vibration. Tested the bump stops after at a neighbourhood large pothole at 40km/hr. YES, much better. A hit on stock bumpstops is a sudden jarring, that makes you think you hit metal on metal. With the new Superbumps, there is no jarring at all, makes you think you didn't even bottom out.
    Dalandser, scocar, patbegley and 2 others like this.
  7. Jul 3, 2012 at 6:51 AM
    The_Hodge
    SC
    was it not an L-shaped key?
  8. Jul 3, 2012 at 2:56 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I had to do the exact same thing.
    It is, but the short end is too short and the long end is too long and causes the wrench to hit the LCA. So I cut about 1/2" off of the long end & it worked great.
    I have had these "Super Bumps for about 1 year. I really love them but after a while I noticed a problem. The bumps compress more than the stock bumps and on hard hits my UCA hits the top of the inner fender wheel well. To fix this I stacked two, 1/4" thick steel washers under the bumps.
    Here is a video I made after I first installed the bumps. When the video is playing press 9 on the keyboard to see the extreme compression.
    http://www.youtube.com/watch?feature=player_embedded&v=YRmK_NkU8Rs
    Mr. Nobody, MTopp and patbegley like this.
  9. Apr 21, 2015 at 11:50 PM
    freedomriding
    freedomriding FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    Wow nice work! We have the worst pot hole ridden roads here in Hawaii. I'll be buying those for sure
  10. Oct 31, 2015 at 8:23 PM
    Sommes
    Sommes Active Member
    Canada
    08 Mica TRD OFF-ROAD
    Cant wait to get these on. Mounted the rears to the Toytec U-bolt flip plates today via a tap & 3/8" fastener. Waiting on the Dakars to arrive now... pics of install to come.
    youngbuckcody and YotaDan like this.
  11. Nov 28, 2015 at 7:38 AM
    Sommes
    Canada
    Installed Superbumpers all the way around... Ride feels great. This is my rear setup.20151115_144534.jpg
  12. Jan 7, 2016 at 5:46 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Revival....
    I've been hunting this sound down for 6 months..... Why does the stock bump stock sound like metal on metal I wonder?
    Going to try the wheelers out right away.. In that video above they look excellent.
    YotaDan likes this.
  13. Jan 7, 2016 at 8:03 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    I highly recommend them. Softer than stock upon impact, they do compress, and they don't jarrrrr when the rear hit them. I have a front set on the rear with an all pro ubolt flip kit and wheelers 3 leaf aal.
    YotaDan likes this.
  14. Jan 7, 2016 at 8:12 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Love my Superbumps
    RogueTRD and YotaDan like this.
  15. Jan 18, 2016 at 2:47 PM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    You got any pics of your rear setup?
    I am in the process of mounting the rears and I am trying to figure out how tall of an adapter to make. I have the exact same rear configuration of ubolt flip and wheelers 3 leaf AAL. The normal wheelers mount look like it is way too tall and would unnecessarily limit travel. Any experiences you want to share would be appreciated.
    I am leaning towards a 3/4" tall puck/adapter.
    ETA: Here's my adapter, I wil install them tomorrow when my stainless fasteners show up.
    raco.the.taco and YotaDan like this.
  16. Feb 10, 2016 at 2:37 PM
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    Do you have any pics of these installed?
  17. Feb 10, 2016 at 3:05 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Where are you installing them using those adapters?
  18. Feb 10, 2016 at 3:09 PM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    Sorry for the crappy cell phone pics but here ya go; disregard how dirty my truck is, I just got back from KOH and haven't cleaned it yet.
    After the week in the dessert, I am going to have to rethink my entire rear suspension. I have 6112's (at 3rd setting) in the front with superbumps and 5160's rear with wheelers 3 leaf AAL. The front is absolutely amazing in the bumps and I couldn't be happier. The rear on the other hand still hits the bumps. FWIW, I do not blame the bumps at all, they work amazing. I think the rear springs are woefully inadequate as is the wheel travel. I have about 5" of uptravel before the superbumps are fully compressed and I was still hitting them frequently. I'm not sure where I am going to start making changes first; either new springs/shocks or hydraulic bumps.
  19. Feb 10, 2016 at 3:10 PM
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    You posted right as I was uploading pics.
    If you have any suggestions based off of what I said above about still bottoming, I am all ears.
    YotaDan[QUOTED] likes this.
  20. Feb 10, 2016 at 3:17 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    @Lostsheep did you verify that the shocks were not bottoming out?
