ToyTec Ultimate vs Old Man Emu NitroCharger
Discussion in 'Suspension' started by DocCisco, Apr 28, 2011.
ToyTec Ultimate or NitroChargers
Poll closed May 28, 2011.
  1. ToyTec Ultimate
    34 vote(s)
    42.0%
  2. Old Man Emu NitroCharger
    47 vote(s)
    58.0%
  1. Apr 28, 2011 at 8:42 PM
    DocCisco
    DocCisco [OP] Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    So I've got the money now for a suspension system and narrowed it to two. I've read through a ton of threads and that's how I got to these two choices.
    My use is mainly daily driver, occasional trail rider and hauler.
    I'll be adding Timbrens to either setup to save the leaf pack from the heavier hauls and a 1/4" spacer for taco lean. Will need to save for LR UCAs.
    Let me know which one you guys would pick or if there are others kits in the same price range.
    1. ToyTec Ultimate $1,149 - [​IMG]
    2. OME NitroCharger $1,015 - http://www.autoanything.com/suspension-systems/73A5935A0A0.aspx or http://www.trdparts4u.com/Scripts/prodView.asp?idproduct=-8415 - Thanks mpleitez
    Personally I am leaning towards the Leaf Pack plus NitroChargers.
    Especk pointed me to similar thread. http://www.tacomaworld.com/forum/suspension/46150-ome-lift-kit-vs-toytec-ultimate-coilover-kit.html
  2. Apr 28, 2011 at 9:22 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
  3. Apr 28, 2011 at 9:25 PM
    eagle5521
    eagle5521 Member
    Scott
    Louisiana
    `11 PreRunner DCSB TX
    OME!!! I love mine!
  4. Apr 28, 2011 at 9:25 PM
    DocCisco
    David
    Utah County, UT
    LB TRD Sport 4x4
    Thanks Erik. Other thread makes it look close.
  5. Apr 28, 2011 at 9:30 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    It comes down to adjustability of toytec front coilovers vs beefier leafs & shocks with OME.
  6. Apr 28, 2011 at 9:33 PM
    DocCisco
    David
    Utah County, UT
    LB TRD Sport 4x4
    Good point Steve. I'm thinking the leaf pack is a clincher, both should put me around 2 to 2.5" I believe.
  7. Apr 28, 2011 at 9:34 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Followed your link. Trouble with the "auto anything" kit is it doesn't specify exactly what's different between "heavy" and "light" -- are they giving you 885 for heavy and 884 for light?? or 886 for heavy and 885 for light?? If you deal with Wheelers or another small shop suspension specialist, you'll get exactly what you intended.
  8. Apr 28, 2011 at 9:36 PM
    especk
    Erik
    Redding, CA
    x2
    I bought mine from wheelersoffroad.com and they were great
  9. Apr 28, 2011 at 10:02 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Another vote for ome
  10. Apr 28, 2011 at 10:05 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    OME ftw!
  11. Apr 28, 2011 at 10:42 PM
    WMDtech
    WMDtech Well-Known Member
    Nate
    TN
    2018 TRD OR 4X4, White, DCSB
    None... sigh
    Reading this has helped me out, going to go with the OME. Emailed Wheelers, had an answer 24 hours later, can't beat that.
  12. Apr 28, 2011 at 11:06 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  13. Apr 28, 2011 at 11:15 PM
    o2begrn
    o2begrn Active Member
    Carlos
    San Jose Ca
    09 double cab Toytec Ultimate Moto Metal 957
    toytec 3" ultimate lift with aal rear tsb bed cap,Moto Metal 957 Nitto Trail Grapplers 295-70-17
    i have the toytec but mmmm it's OK plan on new uca i have the light racing and made my alignment go great and got a better ride.
  14. Apr 28, 2011 at 11:16 PM
    OZ-T
    Peter North
    British Columbia
    Same here , I like the LR UCA's as well
  15. Apr 29, 2011 at 4:37 AM
    udy2554
    udy2554 NORTHERN RED-NECK
    John
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    I went ULK with Dakars and LR UCA's and am very happy with it all. LR UCA's are a must in areas with a lot of salting or sanding going on. I would plan on it for a "perfect" alignment!
    Good luck with your choice!
  16. Apr 29, 2011 at 7:07 AM
    DocCisco
    David
    Utah County, UT
    LB TRD Sport 4x4
    Thanks everyone for the quick feedback. I'm shopping OME at Wheelers today.
    Wasn't planning on the UCAs at first but it seems like they'll be helpful to keep the stock ride. We'll be taking the truck to Moab and Cali several times a year... and if I can get it in the schedule maybe up to Yellowstone. So I want to keep it aligned and a good ride.
    Are UCAs really needed or should I wait and see first then spend the money later if needed?
  17. Apr 29, 2011 at 7:22 AM
    OZ-T
    Peter North
    British Columbia
    You need UCA's when you go over about 2 1/2" of lift up front , I would suggest you install them at the same time as the lift , you will save on labour if you are paying to get the lift installed , and it will save you a second alignment .
  18. Apr 29, 2011 at 11:28 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    If you are planning on wheeling moab and Cali a couple times a year I'd save up for a beefier set up! Stage 2 with UCA's should work!
  19. Apr 29, 2011 at 2:25 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    I originally installed without UCA's.
    After six months, I've ordered some. It's not the off-roading that drove me to make the change -- it's the highway driving with zero caster.
  20. Apr 29, 2011 at 2:36 PM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    I vote OME check here I believe it is a bit cheaper http://www.trdparts4u.com/Scripts/prodView.asp?idproduct=-8415
    talk to Jacque and see what he can do he certainly hooked me up and saved me a bit more money than the online listed price.
