Just installed 885s and Bilsteins
Old 05-01-2011, 06:09 PM   #1
michaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant futuremichaelg589 has a brilliant future
michaelg589's Avatar
michaelg589's Tacoma Gallery
Hey guys, just thought i'd post up some before and after pics of my truck.
Unfortunately I didnt think about taking before and after measurements. So what you see is what you get, haha.
Stock, the day after i bought it:
Toytec AAL only:
885s and Bilstein 5100s up front:
I also replaced the rear shocks with Bilstein 5100s
Old 05-01-2011, 06:17 PM   #3
Thanks... but now I need wheels and tires! lol
Old 05-01-2011, 08:00 PM   #4
wolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shed
wolfdog2314's Tacoma Gallery
Looks great.
What's your plans for tires and wheels?
Old 05-05-2011, 06:26 PM   #5
Im thinking some sort of 16x8 with 0 offset and Goodyear Wrangler Duratracs
Old 05-06-2011, 01:28 AM   #6
Eman5pt0 has a spectacular aura aboutEman5pt0 has a spectacular aura about
Eman5pt0's Tacoma Gallery
how much of a lift with the 885's and bilsteins
Old 05-06-2011, 02:42 PM   #7
Failure is the result of letting setbacks stop you
MedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shedMedlinAround is one of the sharper tools in the shed
MedlinAround's Avatar
MedlinAround's Tacoma Gallery
Read
He just said he didn't take measurements.. Looks like a little over 2" or so.
Old 05-06-2011, 08:15 PM   #8
Yea sorry. No measurements. Easily 2 inches. It was probably almost 3 right after the install. By now it has settled a little. Probably sittin around 2.5 higher than stock. Perfect for me.
I did not use any additional spacers anywhere. I do have the slight "taco lean" I think. It may have just been my driveway.
I love the ride. And I love bein up a little higher
Old 05-06-2011, 08:57 PM   #9
mikeyp6679 is on a distinguished road
mikeyp6679's Tacoma Gallery
are you running stock UCA?
Old 05-06-2011, 09:17 PM   #10
moulin6801 is just really nicemoulin6801 is just really nicemoulin6801 is just really nicemoulin6801 is just really nice
moulin6801's Tacoma Gallery
Hey what set did you put your Bilsteins? 2.5"?
Did you notice any decrease on fuel economy since the lift?? Any vibrations that they are famous for???
David
Old 05-08-2011, 05:54 PM   #11
I still have stock UCAs. My camber is at 0.7 degrees positive right now. I had to go back for an alignment a second time to have them try and get it as low as possible and 0.7 is what i got which is still within spec. However, I'd like it to be zero, so aftermarket UCAs might be in the future.
The bilsteins are set at zero. I dont believe in lifting or lowering with shocks or with spacers. RIDE HEIGHT SHOULD DEPEND ON THE SPRINGS ALONE.
I'm sure fuel economy has gotten slightly worse. So, its gone from pretty bad, to bad. Its a 4x4 truck. I knew what I was getting into when I bought it. I don't bother checking my mileage anymore. It will only piss me off. lol
Old 05-08-2011, 06:02 PM   #12
Oh, and i did get some new vibes. After my AAL install I got some driveshaft vibes. Now after the front lift, I've got some noises from, what sounds like, the front diff. I DID install the front diff. drop kit from Toytec. However, it seems as though the infamous bearing inside that diff. may have been disturbed and now makes growling noises and vibrations when in two wheel drive. Pop her in four high, and it goes away.
Old 05-08-2011, 06:08 PM   #13
chris4x4's Avatar
chris4x4's Tacoma Gallery
Originally Posted by yfzdrag3 View Post
Read
Looks to be about 3" or so. Measure teh center of the axel to the bottom of the fender.
Old 05-08-2011, 06:11 PM   #14
If I remember, I will tomorrow.
Old 05-16-2011, 03:53 PM   #15
The 885s have settled some. I think Theyre right about where theyre going to be now. Its looks level, but if anything, it might still be a bit higher in the rear.
I'll go take measurements right now...
Old 05-16-2011, 08:46 PM   #16
TRDSPORTtaco is a name known to allTRDSPORTtaco is a name known to allTRDSPORTtaco is a name known to allTRDSPORTtaco is a name known to allTRDSPORTtaco is a name known to allTRDSPORTtaco is a name known to all
TRDSPORTtaco's Avatar
TRDSPORTtaco's Tacoma Gallery
We have the same setup (except I have TC UCA's) and I heart it!
Rear Bilsteins installed Test ride! MedlinAround 2nd Gen. Tacomas 2 03-27-2011 10:17 AM
Bilsteins installed. F yea! BDP 1st Gen. Tacomas 31 10-23-2010 01:40 AM
Installed 5 leaf pack and bilsteins blitz10 1st Gen. Tacomas 3 06-12-2010 08:51 PM
Rear Bilsteins installed wrong? Nick_Taco Suspension 3 06-07-2010 05:53 PM
Installed eibachs on TRD bilsteins.... sincitytaco Suspension 20 01-28-2010 12:24 AM
