Is a "mid-travel" suspension setup for me?
Old 05-03-2011, 12:20 PM   #1
iJDub [OP] iJDub is offline
iJDub is a glorious beacon of lightiJDub is a glorious beacon of lightiJDub is a glorious beacon of lightiJDub is a glorious beacon of lightiJDub is a glorious beacon of lightiJDub is a glorious beacon of light
iJDub's Tacoma Gallery
The truck will be a daily driver and I want it to maintain stock load/towing capacity.
I want to offroad on the weekends in southern Nevada. Is a mid-travel a good compromise between a simple lift vs. a LT setup - or is it going to be neither of what I need/want?
I was thinking of going with the Icon Stage 3 kit but am open to suggestions.
Will I need fenders for a mid-travel setup like that? Thanks.
Old 05-03-2011, 12:21 PM   #2
Banned
The most important question is, what is your budget?
Old 05-03-2011, 12:39 PM   #3
My budget is flexible...I could go with a LT setup, but I think it's overkill for the type of off-roading I want to do. I'm not going to be hitting anything fast or hard - well not intentionally.
Still a noob at all this so please bear with me.
Old 05-03-2011, 12:41 PM   #4
Banned
It sounds like you would be fine with just a OME kit. I myself like a bit of overkill so that is why I'm going with a Fox or King setup all around in the future.
Old 05-03-2011, 12:45 PM   #5
McGrubber
woody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shedwoody6047 is one of the sharper tools in the shed
woody6047's Avatar
Air Force: Blacksheep of the DOD
woody6047's Tacoma Gallery
Im running Icon extended coilovers, Light racing UCA's and allpro Expo leafs with billi 5125....im not 100% sure but i think thats mid travel. I dont need fiberglass and the ride is incredible and the performs great offroad.
Hope this helps
Old 05-03-2011, 03:13 PM   #6
woody6047: Did you need spacers for the weheels? What size tires you have? I want to run some slightly bigger tires. Also, does that setup still have the same load/tow capacity/capability?
Old 05-03-2011, 11:40 PM   #7
McGrubber
woody6047's Avatar
No spacers for the wheels just make sure you get a wheel with a 4.5 backspacing (i believe CHECK THAT FIRST) im running 285/75/16's,
Im pretty positive my leafs can handle more weight than the stock leafs.... I dont know about the tow capacity, i rarely tow, but i load the shit out of the bed... two dirtbikes about 600+lbs with gear,gas, and tools. it only drops about an inch... if that. Take a look at my build tread in my signature for more pictures of the setup, if you already havent.
Old 05-04-2011, 11:14 AM   #8
Sublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shed
Sublime's Avatar
Sublime's Tacoma Gallery
Hope this helps
If budget isn't an issue, do this ^^^^^^
Old 05-04-2011, 11:25 AM   #9
Whistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shedWhistler_Steve is one of the sharper tools in the shed
Whistler_Steve's Avatar
Whistler_Steve's Tacoma Gallery
x2 Got the same front setup and couldn't be happier
Old 05-04-2011, 11:30 AM   #10
McGrubber
woody6047's Avatar
Thanks guys, i love it
Old 05-04-2011, 11:38 AM   #11
RN
BenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shedBenJammn5 is one of the sharper tools in the shed
BenJammn5's Avatar
EMS:
BenJammn5's Tacoma Gallery
Downsouth motorsports (DSM)
DSM uniball UCA, 2.5" king's w/ remote resi, add a leaf w/ 2.0 fox in the rear.
Ah so many ways to go, but that's 1 way to do a midtravel.
Icon is great too, and I'd go w/ a coilover set-up like that or similar.
Sway-a-way racerunner shocks are good for hardcore use, and of course fox and king. Really, you can't go wrong with the big coilover shock names.
When the time comes I'm going LT as my off road use gets a little wild sometimes.
Bare in mind that hard off-road use will wiggle the cambolts around a lot and throw out the alignment, so be prepared for consistent alignments if you plan on rocking the truck hard, I speak from experience on this one. When I go LT i'll gusset the bolts so they wont move.
Also if you want a bit more independence in the suspension, remove the sway bar. It'll ride a lot nicer offroad, and it's still very manageable on pavement. Okay, that's just my 2cents. Good luck!
Avoid the balljoint UCA's. Uniball is stronger, more travel. Most people around here go with Total chaos, camburg, Light Racing or DSM
Old 05-04-2011, 11:39 AM   #12
Should I get a Stage 1 like this one: http://www.toyteclifts.com/index.php...mart&Itemid=72
Old 05-04-2011, 11:47 AM   #13
McGrubber
woody6047's Avatar
You could probably get a little better deal with DSM, Icons are going to be smoother at higher speeds 45+ for the rear that is. Thats what chris4x4 gathered. Im happy with my billi 5125's but if they fail ill be going with the icons in the rear.
Old 05-04-2011, 11:54 AM   #14
OK, I think I'll do Icon Stage 1 w/ Light Racing UCA with Allpro Expedition Leaf Pack.
Old 05-04-2011, 12:09 PM   #15
McGrubber
woody6047's Avatar
Good choice brother! keep in mind you will need a rear shock too
This is how she will sit with 285/75's
EDIT: and the expos handle extra weight really well!
Awesome "Mid Travel Kit" - Downsouth Motorsports Suspension 51 09-24-2014 05:03 PM
Mid-travel setup RenoTacoma Suspension 40 01-06-2012 12:39 PM
Rcd 4.5" lift vs. Any long travel vs. Icon mid travel lepedog23 Long Travel Suspension 33 05-17-2011 07:31 AM
FS: Camburg Lift mid travel kit, 4" spindles, 2.5" coilovers, upper control arms TacomaAdam Buy / Sell / Trade 24 11-02-2010 01:40 PM
What is the deffinition of a "mid travel" suspension? DevL Suspension 0 07-02-2010 02:10 PM
