Rear lift options, help!
Discussion in 'Suspension' started by LV taco, May 5, 2011.
  1. May 5, 2011 at 9:53 AM
    LV taco
    LV taco [OP] Member
    las vegas
    99 TRD SR5 4x4
    I have a 99 extra cab 6cyl. I just ordered 5100's from DSM. I need about 1.75 to level the front out. I plan on setting them to 2.5 to clear new 31in tires. So my question is what are my options to level the rear out with the front? I do some off roading, but nothing to fast or crazy. It's either washy soft stuff or really rouch rocky terrain.(not rock crawling) I was thinking about getting rear AAL and new shocks, but I dont usually have a load in the back. Will the AAL be to stiff? What about just getting rear shackels? If im lifting the back only about 3/4-1 inch will i still need new shocks? What shocks are good to run for this set up? Thanks in advance, this is my first truck that Im moding instead of buying it alerady done.
  2. May 5, 2011 at 10:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Get the rear 5100's, and a shackle, if you dont want much lift. IIRC, they make a 1" lift rear shackle.
  3. May 5, 2011 at 10:01 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    shocks don't lift the rear, leaf springs do...I recommend a "add a leaf" (AAL) if you do some off roading! And you don't need to be set at 2.5 up front to run 31s....you can do that with no lift...Cmack on here is running em. 32s would look great though.
  4. May 5, 2011 at 10:14 AM
    ColtsTRD
    Scott
    AZ
  5. May 5, 2011 at 12:07 PM
    LV taco
    LV taco [OP] Member
    las vegas
    99 TRD SR5 4x4
    I talked to a guy at DSM, I think im going to go with the rear shakles and new shocks. you guys like the 5100's in the rear also? or is there any other brand similar in price that would be better? also whats IIRC?
  6. May 5, 2011 at 12:10 PM
    LV taco
    LV taco [OP] Member
    las vegas
    99 TRD SR5 4x4
    NVM about the IIRC, Clicked on the link lol.
  7. May 5, 2011 at 12:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "IIRC" = If I Remember Correclty
  8. May 5, 2011 at 12:20 PM
    LV taco
    LV taco [OP] Member
    las vegas
    99 TRD SR5 4x4
    __________________
    He is running 31's on stock ride height? do you know if he had rubbing or had to do some trimming? If i can set the front to just 1.75 and clear the 31's I'd rather do that to save the money on the shakels.
  9. May 5, 2011 at 8:15 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Most people can fit up to a 265/75/16 at stock height. That's about a 31.6" tall tire so you should be fine with 31"s. A slight lift wouldnt be bad though, just 5100s set at 1.75" and a 1" shackle in your case. How does your leaf pack look?
  10. May 6, 2011 at 10:11 AM
    LV taco
    LV taco [OP] Member
    las vegas
    99 TRD SR5 4x4
    As it sits right now I would need the 1.75 just to level it out. My leaf pack looks a little sad. It doesnt have much arch to it. The truck has almost 150k on it and those are orgional leafs. It doesnt ride bad in the rear at all though. Ill see if I can post a Pic real quick.
  11. May 6, 2011 at 10:13 AM
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    Springs Shocks
  12. May 6, 2011 at 1:44 PM
    LV taco
    LV taco [OP] Member
    las vegas
    99 TRD SR5 4x4
    A couple pics of my truck as it sits right now and my leafs.
  13. May 6, 2011 at 4:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You can run 32"'s w/stock susp. but if you go up any amount in rear you'll need shock upgrade.. mine with 3" lift & 5100 series (5125's)
