5100's @ 0 with OME 885's = Awesome!
Discussion in 'Suspension' started by TRDSPORTtaco, May 6, 2011.
  1. May 6, 2011 at 12:15 PM
    TRDSPORTtaco
    TRDSPORTtaco [OP] Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    So after getting upset about my 5100's being crap with stock coils at 2.5" I went ahead and listen to Chris4x4 and ordered the 885's. I've had them on now for like 2 weeks and they ride AWESOME! I no longer feel like my back is going to break when hitting bumps.
    I got 3" of lift with them and the spacer from Toytec.
    If anybody is considering this combo you wont regret it at all! Rides so smooth yet beefy at the same time. Totally worth the money!
  2. May 6, 2011 at 12:18 PM
    Cannonball
    Cannonball Well-Known Member
    Justin
    Phoenix
    2012 F-250 FX4 6.7 diesel / 1979 Jeep CJ-5
    I have the same setup. Feels great. Though I did notice that I have topped out the fronts going over speed humps fast. I am going to be putting on a plate bumper and winch (+886s) and am thinking I will definately need something with more rebound dampening. Till then all is good.
  3. May 6, 2011 at 12:23 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have had that same setup for about 2.5 years and its still great!
  4. May 6, 2011 at 12:27 PM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Linear vs. progressive. I'm thinkin about puttin my base model tokico linear springs on my 5100s @ 2.5 and taking the TRD progressives off. Should be same effect only still 2.5 instead of 3" but.................prerunner daily driver more than an offroad toy so procrastination & higher priority projects in control.
    Haven't checked with chris4x4 to see that's OK yet either.
  5. May 6, 2011 at 12:29 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    I love it! The TC Uppers/5100's all around/885's was totally worth the $1000 I spent on them.
  6. May 6, 2011 at 12:34 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    What size spacers did you put on with it?
  7. May 6, 2011 at 12:45 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    The Toytech top plate spacer is a half inch. I measured it before putting on.
  8. May 6, 2011 at 12:46 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    Indigo SR5 4x4
    Ok. So following the 2:1 rule, if you didnt put the spacer in you would expect 2" of lift?
  9. May 6, 2011 at 12:47 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Isn't the Toytec spacer 3/8" to deliver a 3/4" lift ?
  10. May 6, 2011 at 12:49 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    1/4 to give 1/2 lift............if you mean the taco lean spacer.
  11. May 6, 2011 at 12:51 PM
    OZ-T
    Peter North
    British Columbia
    I thought the top spacer for the full 3" lift is 3/8" , they also offer the 1/4" spacer for taco lean .
  12. May 6, 2011 at 12:54 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I have 5100's and 885's as well, but running Light Racing UCAs. I had a 1/4" top plate spacer put on the driver's side to comp for the "lean". I LOVE the ride (got rid of the Revtek spacer lift). When I had everything put on at first, I had the 5100's set at 0 (also per Chris4x4's recommendation). I recently added the All-Pro bumper and a winch so it added another 200# up front which made it sag almost a full inch, so I had the 5100's reset at .85 and it leveled out perfect and still rides just as nice as at 0.
  13. May 6, 2011 at 12:59 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    Indigo SR5 4x4
    What height were you at after the install? And after you added armor?
  14. May 6, 2011 at 1:01 PM
    OZ-T
    Peter North
    British Columbia
    I was under the impression that preloading the 885's with the billies was no bueno .
  15. May 6, 2011 at 1:02 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I was sitting at 2 7/8" of lift when set at 0, and after adding the bumper/winch/skidplate/sliders and setting at .85, I am at an exact 3" of lift.
  16. May 6, 2011 at 1:02 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    sub'd for updated photos OP (PLLEEEAASE!) i like the sound of this. hopefully i'll be able to do pretty much that in a year or two.
  17. May 6, 2011 at 1:05 PM
    OZ-T
    Peter North
    British Columbia
    But , with an inch less down travel ?
  18. May 6, 2011 at 1:08 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Well you do lose the extra travel but I'm ok with that. Not like I'm gonna be running the Baja any time soon especially with all of that weight. I just wanted the approach angles from the extra clearance as I'm more of a crawler than a runner.
  19. May 6, 2011 at 1:19 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    OP...were the TC UCA's necessary to fit the 885's?
  20. May 6, 2011 at 1:20 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    No.
