98 Tacoma Suspension Upgrade
Old 05-18-2011, 01:38 PM   #1
jamespud [OP] jamespud is offline
jamespud is on a distinguished road
jamespud's Tacoma Gallery
I just installed a set of 5100's on all 4 corners along with 1 1/2" AAL in back. I used the middle setting on the front shocks which worked great. I also replaced the rack and pinion bushings and the sway bar bushings with urethane. I am not sure if this is typical of the results that most people get, but I gained 1 1/2" in the front and almost 2" in back. Bottom line is that I couldn't be happier. It handles and drives much better, plus I can haul more without bottoming out all the time. Also, to people who are thinking about doing something similar, this took me 6 hours and I had never done one before. I did have a 2 post lift, and impact wrenches, but it was all pretty straight forward. Thanks to all here for all the info that they post. I pretty much knew what needed to be done before i started and that is a big plus.
Jim
Old 05-18-2011, 01:48 PM   #2
Dan
YotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shed
YotaDan's Avatar
YotaDan's Tacoma Gallery
Old 05-18-2011, 01:53 PM   #3
My Cat's breath Smells like Cat Food
Monkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shedMonkeysuncle is one of the sharper tools in the shed
Monkeysuncle's Avatar
Monkeysuncle's Tacoma Gallery
How bad were the leaf springs? My 99 is in need of new leafs and I cant get the $ to do it, but I NEED it.
Old 05-18-2011, 05:23 PM   #4
My truck was still sitting level but I couldn't haul anything heavy at all.
Suspension upgrade ?'s Fox2011PM Suspension 11 01-27-2012 05:19 PM
Suspension upgrade raswank Suspension 3 01-12-2011 11:08 AM
98 tacoma mass air flow sensor upgrade cat3412 Performance and Tuning 2 04-05-2010 10:05 AM
2002 TRD 4x4 Tacoma suspension upgrade Vectorit Suspension 3 02-13-2010 08:32 AM
First Suspension Upgrade -What should I do? Stock_Tacoma Suspension 13 08-30-2009 10:58 AM
