Tacoma World Forums GreySky72's 2008 Tacoma TRD Sport 4x4, covered in mud and PackerfanXD's 2007 Tacoma TRD at the Phoenix Meetup
Register Site Information Glossary Calendar Search Today's Posts Mark Forums Read
3" Suspension tire size
Old 10-05-2008, 11:31 PM   #1
Rookie Member
BGreene will become famous soon enoughBGreene will become famous soon enough
BGreene's Avatar
BGreene's Tacoma Gallery Send a message via AIM to BGreene
Hello everyone,
I am new to the forum, so I hope this is appropriate area. I am interested in getting a 3" suspension lift on my 08 Tacoma Prerunner. I've got prices from numerous places as well as prices on tires but not sure what size tire to use.
I'm not looking for a monster truck off-road look, but just a decent lift with decent sized tires. I will not off road with the truck, but just want the bigger a little more aggressive look.
A guy from a local tire company recomended 265 size tires for a 3" inch lift, but I'm not sure how they will look with it. Will that give me a noticable difference?
Thanks for everything- look forward to more posts in the future.
Old 10-05-2008, 11:34 PM   #2
(Custom User Title)
05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future05TacoTRD has a brilliant future
05TacoTRD's Avatar
05TacoTRD's Tacoma Gallery
I'm going with a 265/75/16 tire with a 3" Suspension lift. You can run a 285 tire (33") and it will look great, but you will have to do some trimming. I personally don't want to trim anything nor do I want to buy aftermarket wheels or wheel spacers to make the 33"s fit.
Check out my sticky (link in sig) on lifts, it'll give you a lot of info.
__________________
Old 10-06-2008, 04:57 AM   #4
PM me for ToyTec Discounts!
Neubs is a jewel in the roughNeubs is a jewel in the roughNeubs is a jewel in the rough
Neubs's Avatar
Neubs's Tacoma Gallery
How much were you looking to spend? Adjustable coilovers are the best but they can be expensive, you also get what you pay for....check this out:
http://www.toyteclifts.com/index.php
Here is another site to check out:
http://www.wheelersoffroad.com/tacoma.htm
__________________
ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | Custom AAL | Rear TSB | Light Racing UCAs | American Racing 17" ATX Wheels | Goodyear 275/70/17 MTR | Hi-Lift Jack | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Super White Bulbs | Bed Mat |Vinyl Black Lip & Graphics
-Doomsday Squad-
Old 10-06-2008, 06:41 PM   #5
Off-road enthusiast S.W.region
timmer is just really nicetimmer is just really nicetimmer is just really nicetimmer is just really nice
timmer's Tacoma Gallery
Originally Posted by BGreene View Post
Hello everyone,
Most lifts on tacos run in the 2.5 to 3" range Many coil overs and coil jobs come preset or measured out to give you a 2.5" lift. adjustable coil overs can give you up to 3.5" in some cases and coils such as the OME 885's can be shimmed up the extra 10mm to get you to 3". the difference between 2.5 and 3 although noticeable really amounts to no big deal performance wise. Personally mine is set at 2.75"
its really not the lift size that provides the "either or" line to running 285/75r16's but rather rub issues. Potential areas of offense are the flaps, pinchweld, fender flairs, plastic inner fender skirts, UCA's, Spindles, body mounts, ect. you can correct many of these issues by switching to a wheel with a lesser backspace. 4.5 is common 4.75 is likely better but MUCH more expensive. you also want to make sure you buy wheels that dont rub the brake calipers. Many more issues can be solved by judicious pounding, grinding and trimming of offending areas. the body mounts are the least affected but are the hardest to correct. Going to a lesser backspace in not without ramifications as well but these are minimal and many only exaserbate existing issues by a small amount.
as an aside there are not many trails where 32's vs 33's will make a difference that driving skills can not overcome
other issues have to do with being on the edge or your stock gearing ratios esp with manuals which essentially have a 3.73 geared diffs (IF I'm Not mistaked the Autos run a bit higher but Im not sure how much higher)
all this is a bunch to work through just to gain another 3/8 of minimum ground clearance over a tall 265/75r16 (ie 32") and another 3/4" of width.
the upside of doing these corrective measures (including regearing) is that if it is done in totality you can run up to a 34.5" tire with out MANY further issues provided you have a full 3" lift compatability. But be aware the upper tire size realm has a complete different set of issues which center mostly around the drivelines
IF you have your heart set on slapping some 33" meaties under your taco by all means do so and enjoy them. My intention is to give you an idea of what the issues that you will have to deal with are in exchange for another inch of tire .
__________________
Smokey Bear sez, Hear it again here Kids !!! http://www.vom.com/wesford/SBHA/SONG...ySONG_ga.shtml
I give my pledge as an American to save and faithfully to defend from waste the natural resources of my country - its soil and minerals, its wildlands, waters and wildlife.
Old 10-07-2008, 01:15 PM   #6
Neubs's Avatar
Great post!!! Lots of good info!
__________________
-Doomsday Squad-
Old 10-07-2008, 01:17 PM   #7
Neubs's Avatar
Here is another great link that talks about everything that is involved with lifting a Tacoma. It covers all of the basic terminology and describes all of your lift options.
http://www.toyotanation.com/forum/t189215.html
__________________
-Doomsday Squad-
Display Modes
TIRE SIZE with SUSPENSION TSB 1BADTOY 2nd Gen. Tacomas 67 11-07-2008 11:49 PM
Tire size x1bowhunter55 Wheels & Tires 5 04-24-2008 08:36 AM
what size tires and rims with 2.5" suspension for 01 tacoma???? Taco01 Wheels & Tires 1 03-12-2008 07:14 PM
Widest tire size on stock 15"s? david04 Wheels & Tires 1 07-01-2007 01:55 PM
Tire size. codered Wheels & Tires 7 05-07-2007 07:21 AM
Copyright © 2008 Tacoma Forum
