885 w/ spacer vs 886 no spacer ?
Old 05-29-2011, 10:47 AM   #1
JGJ [OP] JGJ is offline
JGJ has much to be proud ofJGJ has much to be proud ofJGJ has much to be proud ofJGJ has much to be proud ofJGJ has much to be proud ofJGJ has much to be proud ofJGJ has much to be proud ofJGJ has much to be proud ofJGJ has much to be proud of
JGJ's Tacoma Gallery
With stock bumper would the 886 coils give you the same or similar height as the 885 with top plate spacer?
In other words... with a stock bumper which would have higher CV angles, 885 with top plate spacer or 886 w/o the top plate spacer?
thanks
Old 05-29-2011, 12:03 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
The 886's will give more height, but will ride more firm as they are a much higher spring rate. You are better off with the 885's and no spacer. That will give you between 2.5 and 3" lift.
Old 05-30-2011, 12:54 AM   #3
asphinctersayswhat?
MJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shed
MJonAgs32's Avatar
MJonAgs32's Tacoma Gallery
For the OP, I also recommend the 885s with no top plate spacer, however, I honestly don't think there's a difference in firmness between the 885s and 886s.
I went from the 884s with top plate spacer to the 886s and it all felt the same (all of this was before my AP bumper btw).
Old 05-30-2011, 02:15 AM   #4
I don't care so much about the firmness. Im really just wondering the height difference between the 885s with spacer vs. 886 without spacer. And even more - if the 886 combined with a stock bumper would ruin my CVs?
MJonAgs32, how long did u ride the 886 without the AP bumper? Did u have any CV damage?
Old 05-30-2011, 09:47 AM   #5
asphinctersayswhat?
MJonAgs32's Avatar
About 2 years. I tore my boot, but that's because I was stupid to put on the 886s + the top plate spacer. That boot tore within the first few months. I took the spacer out, and haven't had problems since
Old 05-30-2011, 10:07 AM   #6
chris4x4's Avatar
885's = 590 lbs-in.
886's = 650 lbs.-in.
Old 05-30-2011, 10:22 AM   #7
So you rode for 2 years on your stock bumper and 886 coils? Thanks
Old 05-30-2011, 06:26 PM   #8
asphinctersayswhat?
MJonAgs32's Avatar
yeah. you know what would help you out, go to a local meet (or find someone on the forum that has what you're looking for and meet up), then test it out and drive yourself. That's exactly what I did (changed my suspension 3 times) so I could get a better sense of what I was getting into before committing to purchasing.
I remember having the 884s + top plate spacer, and test drove someone's truck who had the 886s (same OME nitros as me also), and it felt the exact same as mine, except his didn't sag like how my 884s did. It was a no brainer for me.
Old 05-30-2011, 07:23 PM   #9
Thanks for your help. Like you, I also installed the 886 and top plate (learn the hard way). I still have my stock bumper on and just tore my CV boot. I ran the 886 and top plate for about 7 months without a problem until now. I didnt mind the ride/stiffness.
So now my truck is sitting in my garage with the torn CV boot. I'm asking all these questions so I can decide if I only need to take the top spacer out and be done or if I need to replace the entire coil all together (for an 885). This means-to-an-end is to not tear my CV again.
I would prefer to not have to replace the 886 coil for the 885 if I don't need to. A lot less work if I could just remove the top plate spacer and be done. I just wasn't sure if the CV would tear again if I kept the 886 on. The goal is to not tear the CV again.
Old 05-30-2011, 08:48 PM   #10
asphinctersayswhat?
MJonAgs32's Avatar
You want to cheat? take off the top plate spacer and install it on the outside of the strut. That way you don't have to compress the coil. it will decrease the lift
Old 07-07-2011, 03:03 PM   #11
Tacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shed
Tacoma831's Avatar
Tacoma831's Tacoma Gallery
I just received my 886's in the mail today along with my Nitrochargers. So....I guess I will leave the top spacer off when I install these? I have 884's installed now with the top plate spacer, they are sagging from my bullbar.
Old 07-07-2011, 03:06 PM   #12
asphinctersayswhat?
MJonAgs32's Avatar
yeah leave the top plate spacer out.
Old 07-07-2011, 03:09 PM   #13
Tacoma831's Avatar
cool thanks
Anyone running OME 886 with top spacer on Quad Cab? Kauluwela 2nd Gen. Tacomas 4 05-10-2011 01:28 PM
OME 885's 3" w/out spacer? hamNswiss on rye Suspension 21 03-26-2011 05:24 PM
Need Answers!! Bilstein 5100/OME 885/13MM Spacer mfudurich Suspension 0 09-13-2010 12:38 PM
OME 886 Idea? with top spacer? beer Suspension 2 04-13-2010 06:55 PM
885's + TC UCA + 1/2" Top Plate Spacer? c-slak 2nd Gen. Tacomas 0 11-20-2009 12:15 PM
