Got my OME kit today - Few questions
Discussion in 'Suspension' started by cmf21, Jun 10, 2011.
  1. Jun 10, 2011 at 3:41 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Received my OME kit for my 04 TRD 4wd. Everything looks great and very heavy. It looks like I forgot to order the diff drop or they forgot. Rear shocks haven't came in. Have Bilsteins 5125's on the back for now. Anyways I have a few questions that I hope someone could answer.
    1. Where does the extra leaf go? Third row down? Why no squeak / friction pad? What kind of grease do I need? Is it alright to use the same grease as the driveline? Why is the center part of the extra leafs flat looking, not curved. What should that center pin be torqued to?
    2. What side of the truck does the leafs go?
    3. Where does that 5mm trim packer go? Is it even needed?
    4. Looks like the 10mm lift enhance kit sits on top of the strut assembly. I'm I correct? This should level out the truck, right?
    5. I need to to grease the bushings when installing in the leafs and shackles and then afterwards? Is it alright to use the same grease that I have for the driveline?
    6. What amount of for the front diff. I see 3/4 & 1". I should probably just get the one from Wheelers.
  2. Jun 11, 2011 at 12:57 AM
    Scott78
    Scott78 Well-Known Member
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    Just box your kit back up and mail it to me.
    Sorry I couldn't help with your questions. I'm watching for answers though so I can learn as well.
  3. Jun 11, 2011 at 12:58 AM
    Scott78
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    Where did you get the kit by the way? And if you don't mind, what did you pay for it?
  4. Jun 11, 2011 at 1:07 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Also would like to know
  5. Jun 11, 2011 at 5:30 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    The aal goes in where it fits in length longest to shortest the pre installed bushing goes toward front of truck witch side? U will have to look up. The aal does not mater not side specific. The 5mm goes on driver's side to level the truck not sure how it goes in. 10mm goes on top of struts before install. Grease some guys say there is chassis spec grease but semi's use reg grease all around and they run thousands of miles. I like the lucus red and tacky. Hope this helps happy wheeling and post pics.
  6. Jun 11, 2011 at 5:45 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The 5mm trim packer goes on the driver side to compensate for "taco lean"
  7. Jun 11, 2011 at 6:04 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    The trim packer is what corrects the lean. It goes in between the coil and the top plate (need spring compressor to take this apart)
    The 10mm lift enhancer kit does sit on the top of the strut and it gives you additional lift. It does not correct lean.
  8. Jun 11, 2011 at 8:24 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Unless for some reason the first gen shocks are set up different than the 2nd gen 90000's , the OME trim packer ring goes on the drivers side shock at the bottom , below the spring perch .
  9. Jun 11, 2011 at 9:00 AM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Got everything from Wheelers. I would have thought they would have installed that trim packer but I guess they don't. I've figured out where it goes so I'll have to do it myself. The other day, I bought some Royal Purple Ultra Performance Grease for my driveline. Haven't used it yet. Is this safe to use for the bushing, etc? The shape of the extra leafs have me a little concerned. They just don't look right not being fully curved but rather flat in the middle. From how long they are, and not having those friction pads, it look like it's going to be the thrid one down since the top two don't have the fiction pads eigher. I going to be calling Wheelers on Monday to find out.
  10. Jun 11, 2011 at 9:12 AM
    OZ-T
    Peter North
    British Columbia
    OP , when you are talking about the trim packer , do you mean the OME one that is in the bag in your picture in the first post ?
  11. Jun 11, 2011 at 9:21 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    why does the old man emu kit come with extended brake lines and the other three inch kits don't? my procomp 3 inch has no need for the extended brake and fuel lines.
  12. Jun 11, 2011 at 9:33 AM
    OZ-T
    Peter North
    British Columbia
    OP ,
    The OME trim packer kit , which is in the bag in your photo , is to compensate for drivers side lean .
    It installs on the BOTTOM of the drivers side shock , below the spring perch , and in your picture looks like there already is a brass coloured ring below the spring perch on the upper shock in your picture , is that the case ?
  13. Jun 11, 2011 at 9:39 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    when i get my kit installed in the next few weeks i'm going to have them do stainless extended brake lines any way and any other line that may need it the next few weeks are going to be cool. all pro skids coming in and 33 inch tires with a fresh lift are going on! good luck with the instal bud i would absolutely listen to oz and psu guy they have alot of info on this stuff. take your time have an extra pair of hands to help out and make sure to check to make sure all bolt are tightened to spec! the manual can assist with all this.
  14. Jun 11, 2011 at 9:40 AM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Thanks OZ-T. The ring was already installed. I never noticed it. One less thing to worry about. Anyone have any tips on how to install the extended brake line?
  15. Jun 11, 2011 at 3:21 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    Ok so doesn't ur u joint have rubber seals so wouldn't driveline grease.be safe for rubber? Unless ur using full synthetic all grease starts with petroleum. I think this whole rubber friendly grease for spring bushings is a bit of a myth. Bearings have rubber seals to. BTW I'm sure royal purple is synthetic.
  16. Jun 11, 2011 at 3:27 PM
    OZ-T
    Peter North
    British Columbia
    Buy some rubber friendly grease or use vasoline
  17. Aug 26, 2011 at 3:58 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Got my ome kit today only waiting for the D6XL (thanks Box Rocket for your knowledge!)to come in.
    Got it from OUIPAC ..ARB Canada...(thanks OZ-T)...great prices and service.
    A couple ? for the OP
    Where does the D6XL go...3rd from top or 3rd from bottom?
    Also what type of grease did you use for the shackles?
  18. Aug 26, 2011 at 7:30 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    The answer to ur ? Has already been posted in this thread. Come on and you have even started another thread asking the same .?
  19. Aug 26, 2011 at 7:57 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    hey..sorry...did not mean to offend.....do not have the aal in hand so it was hard to figure it out and your repy to the op makes sense...I missed it
  20. Aug 26, 2011 at 8:27 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    No prob and just think they build the spring longest to shortest so the aal is just another spring in the pack. I'm sure u read about the grease good luck on that one. Lol as previously stated I think any will work. But napa sells chassis grease in a tub I slather everything in it.
