Um... Did I forget to order somthing?
Old 10-16-2008, 02:27 PM   #2
Founder Socaltacomas.com
SocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shed
SocalMan22's Avatar
SocalMan22's Tacoma Gallery
Yeah i believe those are spacers and you do not need them the bottom setup is all you need how much you pick them up for?
Old 10-16-2008, 02:33 PM   #3
Can you pass the bailout please?
LonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shed
LonghornTaco's Avatar
LonghornTaco's Tacoma Gallery
$429. That and the struts from DownSouth motorsports were about $200 cheaper than buying the assembled ones up top for $799.
So, if that is just the spacer that I don't need, what piece comprises the other end of the spring to keep it compressed?
Old 10-16-2008, 03:01 PM   #5
chris4x4's Avatar
chris4x4's Tacoma Gallery
You use the original top plate that is on the truck.
Old 10-16-2008, 03:04 PM   #6
SocalMan22's Avatar
Chris 4x4 is correct, the disc looking things are the c clips thats what your going to use to put it at the hieght you want you can see on the shock there are 3 lines thats where they would go.
Old 10-16-2008, 03:11 PM   #9
NorCal Rock Whore
Killer Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shedKiller Red Taco is one of the sharper tools in the shed
Killer Red Taco's Avatar
Killer Red Taco's Tacoma Gallery
No the c clip are on the shock in that pic and the round plate are what the spring sit on. If your going to use what toytec sent then you shouldn't need the bilstein plates.
Old 10-16-2008, 03:35 PM   #10
SocalMan22's Avatar
You are correct red taco i thought he was asking whats it for i miss read.
Old 10-16-2008, 04:59 PM   #11
Ridingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shedRidingontrd is one of the sharper tools in the shed
Ridingontrd's Avatar
Navy: '83-'87 Hull Tech.
Ridingontrd's Tacoma Gallery
Send a message via Yahoo to Ridingontrd
The c-clip goes on the bottom setting.You do use the plate.The ToyTec collars sit on that.In regards to the top pic,it's not a spacer.It just looks better then the stock coil assembly top.(Double check w/Neubes.)
Old 10-16-2008, 06:17 PM   #12
So, to be clear, I don't have to use the coil assembly top off my truck to assemble the new strut and coil or do I?
Old 10-16-2008, 06:22 PM   #13
You re-install the top.(I have the same coil over you have)$$ for the install is my hold up.
Old 10-16-2008, 06:25 PM   #14
chris4x4's Avatar
Install it yourself? Take the spring/shock to a place with a spring compressor and have them put it together for ya. SHould cost about $20.00 per side. Then take it home and re install.
Old 10-16-2008, 06:26 PM   #17
chris4x4's Avatar
Do you know if I can buy a new "assembly top" for the new coil and strut? I wanted to keep the factory coil and strut together if I could.
Side note - is "assembly top" the right term for it?
You can buy it from the Toyota dealer. Its a Top plate with the studs. From the dealer, its probably $50.00 per side. Not sure where else you can get them.
Old 10-16-2008, 06:29 PM   #19
chris4x4's Avatar
Wonder if I can buy the "fancier" one from ToyTec...
Good idea! Give them a call and see.
Old 10-16-2008, 06:32 PM   #20
Where i live (condo) the hoa would have my a$$.lol,I'm also waiting on funds to order the uniball for my tc's. Have this done all at once.
somthing a little different kmfarnum56 2nd Gen. Tacomas 13 04-10-2011 01:34 PM
somthing about my truck Hambone155 Off-Topic Discussion 2 02-21-2011 12:47 AM
um, hi. tacomadude18 New Members 14 09-22-2010 07:54 AM
Like Um???? nad Off-Topic Discussion 1 10-26-2009 08:49 PM
I might try somthing dangerous, installing 5100's jeremy_283 Suspension 19 01-02-2009 02:26 PM
