HELP!!! COILOVER ISSUE (PHOTO INCLUDED)
Old 07-16-2011, 06:54 AM   #1
g35man [OP] g35man is offline
g35man has much to be proud ofg35man has much to be proud ofg35man has much to be proud ofg35man has much to be proud ofg35man has much to be proud ofg35man has much to be proud ofg35man has much to be proud ofg35man has much to be proud ofg35man has much to be proud of
g35man's Avatar
g35man's Tacoma Gallery
Some fellow Tacomaworld help is needed! I had a offroad store in town put my toytec coil over's onto my 5100's yesterday and this was the end result. Why are my shocks not seated properly? Place does not open till 10am central time to show them whats wrong. I took them the the orginal shock and spring in hand to assemble the ciol over setup. This sucks for now so please help me understand whats my problem.
Old 07-16-2011, 07:09 AM   #2
Max's Canadian Twin
theduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shed
theduck911's Avatar
theduck911's Tacoma Gallery
Looks like you're missing the top spacer, I just uploaded a shot of mine to the live thread for you to compare!
Old 07-16-2011, 07:27 AM   #3
chris4x4's Avatar
chris4x4's Tacoma Gallery
they didnt install the lower washer, and it looks like the spring is upside down.
Old 07-16-2011, 07:32 AM   #4
g35man's Avatar
Ok thanks. This blows my mind that they are supposed to be professionals!
Old 07-16-2011, 07:34 AM   #5
g35man's Avatar
Spring is upright but im guessing its alignment is off. Will take it back to them as soon as they open. Thanks for the help!
Old 07-16-2011, 07:40 AM   #6
"the soulless ginger"
PAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shedPAlittlematty is one of the sharper tools in the shed
PAlittlematty's Avatar
PAlittlematty's Tacoma Gallery
the top of the spring really doesnt have an alignment like the bottom. the washer under the top plate is missing though. thats why the shock shaft is driven therough the bushing and out the top of the top plate. id make sure they put a new bushing under the top plate before they reassemble it. incompitent asses
Old 07-16-2011, 07:41 AM   #7
chris4x4's Avatar
There shouldnt be any spacer. Unless youre using a spacer for more lift. The shock shaft has a washer, then the top plate, then another bushing, and washer. Then the nut. The washers, and bushing hold the assembly to the top plate. In the OP's case, the lower washer was left off.
Old 07-16-2011, 07:42 AM   #8
+1 i just did an OME lift lastnight so the assembly process is still fresh in my mind
Old 07-16-2011, 07:43 AM   #9
and make sure you drive slow and avoid bumps cause essentially that shock could drive up through the fenderwell. correct chris?
Old 07-16-2011, 07:43 AM   #10
chris4x4's Avatar
The lower diagram has an exploded view of the parts, and how they go together
http://ncttora.com/fsm/05+/data/ilea...a/03900510.pdf
Old 07-16-2011, 07:44 AM   #11
chris4x4's Avatar
Depending on the size if the bump, maybe.
Old 07-16-2011, 07:46 AM   #12
Max's Canadian Twin
theduck911's Avatar
Chris,
I uploaded a photo of mine to the TW Live thread not to long ago, but there's a silver metal top plate that says toytec on mine, came assembled that way!
Old 07-16-2011, 07:51 AM   #13
g35man's Avatar
The truck is not moving till I can get back to there shop! would have done it all myself if it weren't for me not having a spring compressor. I have installed struts and springs on my G35 but did not want too mess with this big ass truck spring.
Old 07-16-2011, 07:58 AM   #14
chris4x4's Avatar
Chris,
The ones that come pre assembled are different.
Old 07-16-2011, 07:59 AM   #15
Max's Canadian Twin
theduck911's Avatar
Oh okay, didn't know that!
Old 07-16-2011, 08:01 AM   #16
g35man's Avatar
Thats correct.
Old 07-16-2011, 08:01 AM   #17
chris4x4's Avatar
You can drive it like that, just take it easy. As long as the top nut is on there, it wont come off.
Old 07-16-2011, 08:04 AM   #18
g35man's Avatar
Pisses me off! I should be at the beach right now with fellow Tacomaworld guys enjoying fishing, relaxing and drinking beer! No my ass is at home doing nothing!!!!!
Old 07-16-2011, 08:04 AM   #19
chris4x4's Avatar
I hear that man.
Old 07-16-2011, 11:27 AM   #20
Get it fixed?
Anyone ever spill anything here? [Pic included] Large 2nd Gen. Tacomas 41 10-13-2011 05:31 AM
Included Maint. raswank 2nd Gen. Tacomas 0 09-30-2011 12:22 PM
Rotor issue or tie rod issue HeadlampRevamp 1st Gen. Tacomas 37 05-16-2010 09:32 AM
My first mods done! A few pics included s2studio 2nd Gen. Tacomas 29 04-19-2010 09:31 AM
TRD coilover Vs. sr5 coilover MikeyD Suspension 9 10-14-2009 02:27 PM
