881 spring length as OEM
Old 07-23-2011, 03:49 PM   #1
Carito [OP] Carito is offline
Carito is on a distinguished road
Carito's Tacoma Gallery
Ok, just curious. Just finished putting in OME 881, 5100, and 1/2" spacer in one side. Definitely higher than the other. I was just curious though. When I take off the old spring and put it up against the new 881, they are the same length. Shouldnt it be longer?
I did move the 5100 clip to the lowest setting, since everything I read said that if I set the shock to add lift when using the 881, it would put too much pretension on it and make the ride too rough.
03 Prerunner TRD
Old 07-23-2011, 03:51 PM   #2
Locked and Lifted "02" DC TRD.
Matic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shed
Matic's Avatar
Matic's Tacoma Gallery
Never looked at mine. I would just assume it is a stiffer spring.
And again I will add........Why did you buy 2 lifts? Even if the 5100's are adjustible for lift, you have 2 lifts.
I would have opted for 5125 or rather ome's. nitrochargers.
Old 07-23-2011, 03:54 PM   #3
yeah maybe so even with the bilstein clip lowered and up against the old shock, the plate the spring rests on is also at the same level. So am I only getting the top place spacer height I added or are the springs the same length but stiffer.
I am guessing I am correct in lowering the 5100 so that it does not add any lift since I am using the OME 881's?
Old 07-23-2011, 03:57 PM   #4
Matic's Avatar
You are correct. 881's with 5100's set at 0.
OME 880/881 and 5100's... Which spring, which setting?! DblCabMN Suspension 4 08-16-2011 06:38 PM
Spring Preload vs Spring Length DevL Suspension 1 04-29-2011 01:44 PM
Coilover Spring length? &erson Suspension 2 04-22-2011 08:46 AM
Leaf Spring Length Questions.... Kuneff 1st Gen. Tacomas 9 08-23-2010 02:17 PM
coil spring rate/length 09silvertaco 2nd Gen. Tacomas 4 12-01-2008 05:33 PM
