ome 884 or 885?
Old 10-21-2008, 03:41 PM   #1
09silvertaco is on a distinguished road
09silvertaco's Tacoma Gallery
ome 884 or 885?
v6 access cab, manual tranny...no added weight up front...should i go 884 or 885? only reason i ask is b/c i've heard of the 884's sagging on tacos with time, where as the 885 and/or 886 hold their own? i also plan on putting a replacement alcan or deaver progressive leaf pack in the rear for roughly a 1-1/2" lift? im looking for 2 1/2 to 3, closer to 3" in the front.
Old 10-21-2008, 03:43 PM   #2
Piss off
jhodge83's Avatar
jhodge83's Tacoma Gallery
i'd go w/ the 885's to be on the safe side. it might ride a tad stiffer in the front w/o the extra weight, but u also shouldnt have the sagging issue
Old 10-21-2008, 03:47 PM   #3
i know chris would def have the answer...but do you think id get over 3" of lift b/c of the access cab?
Old 10-21-2008, 04:54 PM   #4
chris4x4's Avatar
chris4x4's Tacoma Gallery
I think the 884's are the way to go. OME had some sagging issues accross the board a while back. Last time I have talked to them, they assured me they had things straightened out. I ordered my 885's and they have only saged 1/4". They gave 3" after settleing. Give the 884's a try. If they sag too much OME will replace them.
FWIW, the 885'sa re longer and should be used with a OME shock and Aftermarket UCA, IMHO.
Old 10-23-2008, 04:46 PM   #5
Toycoma06 will become famous soon enoughToycoma06 will become famous soon enough
Toycoma06's Avatar
Toycoma06's Tacoma Gallery
Go with the 885's !!!!!!!! I wish i did.
Old 10-23-2008, 05:04 PM   #7
IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
TacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shedTacoNut is one of the sharper tools in the shed
TacoNut's Avatar
TacoNut's Tacoma Gallery
I'm gunna say that bigger is always better... then again thats gotten me in trouble before
Old 10-25-2008, 08:20 AM   #8
thanks for the replies guys. do you recommend the diff drop if i go 2 1/2" or so w/the 884? also, i know aftermarket uca's will help, but are they necc?
Old 10-25-2008, 08:46 AM   #9
Poodoo
luk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shed
luk8272's Avatar
luk8272's Tacoma Gallery
I went 3" and to save trouble I purchased the diff drops and installed them. There are a few guys on here that don't have them and are pushing their trucks to the limits and aren't experiencing any troubles. They are cheap and easy to install you could always go without and if you start to experience any trouble get them. Here is a pic of mine not as high tech as you would think. Some people are just using washers to achieve the same affect.
Front diff
Hanger bearing
Rear shims under block
I don't have the UCA's and am experiencing no troubles.
Old 10-25-2008, 08:56 AM   #10
thanks for the info!
WTB OME coils 884/885 650H1 2nd Gen Tacoma Marketplace 8 09-27-2011 02:08 PM
WTB: OME 884 or 885 coils GA_TACO4x4 2nd Gen Tacoma Marketplace 14 05-13-2011 09:20 PM
Are 884's enough? or 885's or 886's? Hunter'06FLKY 2nd Gen. Tacomas 8 12-27-2010 06:51 PM
884 or 885 coils? jdkeller Suspension 28 09-21-2009 08:32 AM
WTB: USED OME / Toytec 884 or 885 Coils asudevil Buy / Sell / Trade 2 08-23-2009 03:35 PM
