Front 5100's and OME 884's installed
Old 08-06-2011, 03:48 PM   #1
MJF [OP] MJF is offline
VSC blows
MJF will become famous soon enoughMJF will become famous soon enough
MJF's Avatar
Army: 82nd Airborne
MJF's Tacoma Gallery
I just installed my Bilstein 5100 front shocks and OME 884 springs today. I made pretty good time at two hours start to finish. The dealer wanted six hours labor My impact gun was to hot to touch compressing the springs. I am getting the TSB done Monday morning and I thing the truck should be level.
I have not decided what shocks I will run on the rear, the stock Bilsteins are to soft. Once I measure the compression and droop I'll pick the suitable shock. Being 2wd, having both tires planted to the ground is especially important to me. Here is a pic. A little nose high, but the TSB should correct that. I do need a bigger jack and higher jack stands now.
Old 08-07-2011, 12:09 PM   #2
mgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant futuremgiguere20 has a brilliant future
mgiguere20's Avatar
mgiguere20's Tacoma Gallery
what notch did you place the front at, 1.85 or 2.5?
Old 08-07-2011, 01:51 PM   #3
VSC blows
MJF's Avatar
Army: 82nd Airborne
They are on the 0 setting. The 2" lift is from the OME springs.
Old 08-11-2011, 05:40 PM   #4
mgiguere20's Avatar
cool, thanks! Looks good btw!
Old 08-12-2011, 02:52 PM   #5
Don't ask questions you don't want the answer to..
chadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shed
chadderkdawg's Avatar
chadderkdawg's Tacoma Gallery
Looks level to me! Very nice
Old 08-12-2011, 02:54 PM   #6
Lieutenant Dan.
DeeKay21's Avatar
Firefighter: Lieutenant
DeeKay21's Tacoma Gallery
Looks good! I'm assuming you didnt want to go the full 3"s up front?
Old 08-12-2011, 03:03 PM   #7
jdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shedjdmdcfan is one of the sharper tools in the shed
jdmdcfan's Avatar
jdmdcfan's Tacoma Gallery
nope. definitely nose high
Old 08-12-2011, 04:33 PM   #8
VSC blows
MJF's Avatar
Army: 82nd Airborne
It's nose high by almost an inch. I like the amount of lift in the front, over 2". I am going to install a set of Icon three leaf aal's to raise the rear up a bit. The ride is much better than stock.
Old 08-17-2011, 08:57 AM   #9
scotch is on a distinguished road
scotch's Avatar
scotch's Tacoma Gallery
Originally Posted by MJF View Post
... I am getting the TSB done Monday morning and
Do you have any post tsb pictures? I'm thinking of getting 5100s and 884's, but I already have the tsb... Can you measure from the center of the front hub to the fender with the 884/5100 combo?
Here's my stock before tsb and after tsb measurements:
Before TSB
LF 20" RF 20.25"
LR 21.75" RR 22"
After tsb:
LF 20" RF 20.25"
RF 22.5" RR 22.75"
So tsb raised my 09 dc trd offroad .75 in the rear...
Old 08-17-2011, 12:56 PM   #10
VSC blows
MJF's Avatar
Army: 82nd Airborne
The pic is with 5100's set at 0 and 884's, with the TSB springs. I live at the beach which is hilly and I cannot find a totally flat piece of ground anywhere. I get an average height of
Front 22 5/8" and Rear 22 1/8" The 884's gave me about 2 5/8" of lift. I got less lift in the rear than you but I have a LB with a hi-lift, soft top, and some extraction gear in the back.
Maybe 75lbs + the long bed.
I have the Wheelers progressive 3 leaf aal that I will install Thursday of Friday. That should be perfect.
Old 08-17-2011, 02:16 PM   #11
scotch's Avatar
From what I was told from dsm, the 884's are good for 1" lift, and the 885's are 2"ish. That's odd you got 2 5/8" from the 884s at 0 on the bilsteins.
I just ordered to 884s and 5100s, so I should be able to install them next week. I'll post what I get.
Your truck's looking sweet!
Old 08-17-2011, 04:39 PM   #12
VSC blows
MJF's Avatar
Army: 82nd Airborne
I had always heard that the 884's were good for 2" on a prerunner.
Old 08-17-2011, 04:45 PM   #13
2006TRDSPORT
2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of2006TRDSPORT has much to be proud of
2006TRDSPORT's Avatar
2006TRDSPORT's Tacoma Gallery
Looks good, I would suggest OME rear N182 shocks only because I just put them on my own truck in the last week with a 2" AAL & it rides great. I think it would compliment the TSB very well.
Old 08-17-2011, 04:46 PM   #14
scotch's Avatar
Well the front 2" 884 will be nicely paired with a 1.5" aal + the tsb overload for the back that i was thinking about.
Old 08-17-2011, 05:54 PM   #15
Very Nice !
packfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud of
packfan88's Avatar
packfan88's Tacoma Gallery
Nice im gearing up for mine. Any tips? Im going with the 885 tho. You gettign bigger tires? if so, What size?
got a before and after?
im going to do mine this weekend. Before i do Im goign to put my truck in a certain spot and take a fe pics. Then once Im done im goign to put it back in that smae spot and take some more pics from the same angles. That way there will be documented views of what a real before and after looks like. A pay it foward for all the help i got, maybe it will help someone else deside.
Old 08-17-2011, 05:56 PM   #16
Very Nice !
packfan88's Avatar
have you had the 5100s in the back before?
Old 08-17-2011, 06:05 PM   #17
willimatic is a splendid one to beholdwillimatic is a splendid one to beholdwillimatic is a splendid one to beholdwillimatic is a splendid one to beholdwillimatic is a splendid one to beholdwillimatic is a splendid one to beholdwillimatic is a splendid one to beholdwillimatic is a splendid one to behold
willimatic's Avatar
willimatic's Tacoma Gallery
I installed 5100s/884 about 2 months ago, I got about 2 3/4" up front. I have a 06 4x4 AC, I think all tacoma's vary a bit, and the provided numbers are just a general ball park.
Old 08-17-2011, 06:35 PM   #18
Very Nice !
packfan88's Avatar
im wondering if that the height you got right after you installed it or now after two months of settling?
Old 08-17-2011, 07:33 PM   #19
VSC blows
MJF's Avatar
Army: 82nd Airborne
That sounds good. I can never remember to take pics of my installs. I'll have a pic tomorrow with the 3 leaf aal. I will be changing tires to a 265/70/17, either the new Kumho kl61 or the Yokahama Geolander.
Old 08-18-2011, 10:22 AM   #20
willimatic's Avatar
They really didn't settle that much, but I went out and measured again and I'd say I got a final life of 2 5/8. So settle about an 1/8 of an inch.
I was surprised how much lift I got, I thought I'd get around 21/4-21/2 max.
Setting for 5100 + OME 884 oneshot808 Suspension 17 04-10-2012 09:53 AM
WTB : TRD Off Road front Springs / OME 884, etc. Fortech 2nd Gen Tacoma Marketplace 4 08-25-2011 07:50 AM
WTB: OME 884 Springs, Rear 5100's, Front Skid Plate slimcubby Buy / Sell / Trade 10 10-15-2008 02:31 AM
Anybody selling OME 884 front coils? slimcubby 2nd Gen. Tacomas 0 10-13-2008 11:53 PM
JUST INSTALLED 3"TOYTEC OME 884's Toycoma06 Suspension 1 02-19-2008 01:33 PM
