1.75" lift need advice
Old 08-07-2011, 10:58 AM   #1
mattgecko [OP] mattgecko is offline
Super Taco
mattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shed
mattgecko's Avatar
mattgecko's Tacoma Gallery
Hi TW
I have a 2011 Tacoma 4x4, I plan to off road in a few times a year. Looking to lift the truck 1.75".
Did some reading and I'm thinking 5100 front and 5150 rear (10" travel 255/70 valve). Also read I need new bump stops for the rear. What size and where do I get them?
AAL or Wheelers 3 leaf progressives? What do you guys recommend? I don't haul heavy loads.
Can I keep everything thing else stock? springs? etc?
Looking to keep the ride quality as close to stock or smoother if possible.
I am on a budge but will save for the right parts.
Old 08-07-2011, 04:11 PM   #2
wolfman00 is on a distinguished road
wolfman00's Tacoma Gallery
for the rear i would go with 170/60. I called camburg and talked to them about it. they told me that since the rears of tacomas and rangers are so light, that they found 170/60 worked the best.
Old 08-07-2011, 05:18 PM   #3
Super Taco
mattgecko's Avatar
Originally Posted by mattmxracer View Post
I went with 1.75 and no rear tsb. is perfectly level now. still have stock springs and stock leaf springs. the double cab doesnt have as much of a rake as the access cabs. I would go with .85 setting to level it out. if you get the rear tsb or aal I would go with 1.75 up front
check out my build
http://www.tacomaworld.com/forum/2nd...ere-build.html
Nice truck, love those wheels.
Thanks for tip.
Old 08-07-2011, 06:41 PM   #4
Super Taco
mattgecko's Avatar
My wife just cleared me to spend $1200. Should I get an OME complete lift kit with the 885 springs?
Old 08-07-2011, 06:43 PM   #5
attack ships on fire off the shoulder of Orion
OZ-T's Avatar
OZ-T's Tacoma Gallery
That will lift you closer to 3"
Old 08-07-2011, 07:52 PM   #6
Super Taco
mattgecko's Avatar
OK thanks. Wheeler website didn't say so I thought it was adjustable. I don't want to go that high.
Old 08-08-2011, 10:20 AM   #7
Super Taco
mattgecko's Avatar
Now I'm confused....
Called motorsport and they said I should not get an AAL only the 5100 fr / 5150 rr, to achieve the 1.5"-2.0" lift.
Does that sound correct?
Old 08-08-2011, 10:27 AM   #8
Banned
97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed
97yota4wd's Tacoma Gallery
if you lift it 2 inches in the front and leave the back stock you should have a little bro lean. (front a little nose high)
Old 08-08-2011, 11:43 AM   #9
OZ-T's Avatar
Rear shocks don't provide lift , the AAL does that
Old 08-08-2011, 11:47 AM   #10
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
The Wheeler's and Icon 3-leaf progressive AAL's are great. They claim to lift 1.5" but you can get closer to 2" of lift if you leave the factory overload leaf in place.
As OZ stated, rear shocks do not provide lift, you'd need an AAL or block for that.
Old 08-08-2011, 12:27 PM   #11
Super Taco
mattgecko's Avatar
Thats why I was confused. The Icon AAL kit ($179.00) says it lifts 1.5" but the guy I spoke with said 2.5" and I don't need it if I am only lifting 1.5".
This is what I am going to order:
Also need stem adapters for the 5150's (according to the guy I spoke with).
(1.5"-2.0" is my goal, 2.5" is ok as long as I dont have to replace anything else).
Is the valving and shock length ok?
Old 08-08-2011, 03:59 PM   #12
Downsouth Motorsport
Downsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shedDownsouth Motorsports is one of the sharper tools in the shed
Downsouth Motorsports's Avatar
Downsouth Motorsports's Tacoma Gallery
Hi Matt,
You talked to me on the phone. I think were mis-communicating a bit...
You mentioned not really wanting more than 2" of lift over all, but wanted it to be level. On a 2011, if you just set the front shocks to 1.75"...the truck will be pretty much level. No need for the rear AAL in this case. That's what I was trying explain...
Also, if you're not doing a bunch of wheeling, you don't really need 5150s in the rear. The 5100s would be fine.
We're getting more 5100s tomorrow, so you can place your order online, or over the phone anytime. Feel free to call us or PM me, if you still have any questions...
Thank you,
Marco @ DSM
Old 08-08-2011, 04:18 PM   #13
RoyR is a splendid one to beholdRoyR is a splendid one to beholdRoyR is a splendid one to beholdRoyR is a splendid one to beholdRoyR is a splendid one to beholdRoyR is a splendid one to behold
RoyR's Avatar
RoyR's Tacoma Gallery
http://www.tacomaworld.com/forum/sus...tsb-5100s.html
Old 08-08-2011, 10:04 PM   #14
Super Taco
mattgecko's Avatar
It was my confusion, sorry Marco. Thanks I'll skip the AAL and just do the shocks at 1.75. in FR.
Old 08-10-2011, 02:49 PM   #15
neoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shedneoflex is one of the sharper tools in the shed
neoflex's Tacoma Gallery
If your doing the 5100s set at 1.75 you do not need the rear AAL unless your looking to have the back higher than the front. Granted if you have the non TSB rear you may be a little high in the front which in that case I would just do the TSB as it will save you some coin and you will definitely want it if you ever haul anything in the bed. My DRZ 400 would cause my rear to drop so much that it would have the bro lean and forget when hauling mulch or anything with real weight. I just installed my 5100s today and have the rear TSB and my truck sits perfectly level now. Rides no different too which is an added bonus. Love the way the truck sits now.
pics of 1.75" lift and 265/75/16??? TRDfarmerTN 2nd Gen. Tacomas 13 07-10-2012 08:21 AM
Pic request pls -- show me ur 2nd gen with 1.75" front lift and 265/75/16 Duratracs BenWA 2nd Gen. Tacomas 19 12-17-2011 11:04 AM
Five Lug Ready Lift Spacer 2.75" lift Shemicals Buy / Sell / Trade 10 12-01-2011 10:17 AM
Rancho 2.75" lift & Skyjacker 3" leaf pack joelong0004 Suspension 4 10-02-2011 01:48 PM
ReadyLIFT 2.75"-3"F/1"R Lift Kit Byrd32 Suspension 34 06-05-2010 08:17 PM
