In need of some TW knowledge...
Old 08-12-2011, 03:30 PM   #1
Ride that dank
colliNoverton is on a distinguished road
colliNoverton's Avatar
colliNoverton's Tacoma Gallery
currently I have stock suspension with a spacer giving me about 2"
I have been saving up money for a couple months and am in need of some advice. I will be purchasing some billy 5100 all around soon and am wondering if i should replace my aal aswell? Also i need to figure out what length shocks to get???
Left
Right
also what coils and shock setttings would be the best to preserve my current lift because I have no intention of going over 2"
ANY feedback would be greatly appreciated
this is my first truck and TW has some great members so speak up!
Old 08-12-2011, 03:37 PM   #2
Ride that dank
bump
Old 08-12-2011, 03:55 PM   #3
TMW TMW is offline
TMW is a jewel in the roughTMW is a jewel in the roughTMW is a jewel in the rough
TMW's Tacoma Gallery
Other than installing the shocks you don't need to do anything else. The 5100 for the front allows you to remove the spacer on top of the coil. Leave the AAL as is. I suggest you jack up the rear using the frame and with the rear shocks disconnected on the bottom see if they still fit or are they too short. If too short measure the length from the top and bottom mounts, that will give you the extended length needed, add 1/2 to 1 inch extra. Measure the collapsed length and add the difference between the shock when extended and bottom mount. Bilstein has a 5125 series that will work. Remember the stock rear shocks are different lengths. The RR is 13-20.5 inches and the LR is an inch shorter on an 04 4x4. A Bilstein 5125 series F4-BE5-6253-H5 is 14.06 collapsed and 22.5 extended. A Bilstein 5125 series F4-BE5-A463-H5 is 15.11 collapsed and 24.35 extended.
Old 08-12-2011, 11:21 PM   #4
Ride that dank
whew thank you kind sir
knowledge needed english redneck Wheels & Tires 11 01-18-2011 06:42 AM
Knowledge of AS9100B OR C? jblaze805 Off-Topic Discussion 0 10-22-2010 01:08 PM
Where do you get your Tacoma knowledge? Karo 2nd Gen. Tacomas 26 05-25-2010 08:55 AM
Knowledge For Me kingN8 Suspension 92 03-23-2009 01:11 PM
Help *** Noob Needs Knowledge *** SUNDOWN 2nd Gen. Tacomas 30 12-05-2007 06:11 PM
