Differential question
Discussion in 'Suspension' started by LonghornTaco, Oct 24, 2008.
  1. Oct 24, 2008 at 5:44 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Jason
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Ok, so I'm a noob, but is this the differential and is this where I install the diff drop spacer?
  2. Oct 24, 2008 at 5:50 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i do believe thats the tie rod for turning....the diff spacer goes under the truck and drops the 2 diff bolts down an inch to reduce that angle
    i would post a pic, but the allpro skidplate covers it all up underneath there
  3. Oct 24, 2008 at 6:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The front diff is going to be covered by the skid plate. Find the front drive shafts, and follow them to the front dif. :)
  4. Oct 24, 2008 at 6:24 PM
    LonghornTaco
    Jason
    Minnesota
    awesome. Thanks!
  5. Oct 24, 2008 at 7:34 PM
    LonghornTaco
    Jason
    Minnesota
    Is this where I put the diff drop? it's above the skid plate...
  6. Oct 24, 2008 at 7:46 PM
    The_Hodge
    SC
    follow the differential to where it bolts to the frame. there are only 2 bolts. one on each side. thats where the 2 bolts and spacers go
  7. Oct 24, 2008 at 9:16 PM
    ricepow
    ricepow Well-Known Member
    Vegas
    08 4x4 TRD Sport
    Am I the only one that thinks if you confuse the tie rod for the differential that maybe you should have this work done by a qualified mechanic. Im all for learning, but some things should just be left to professionals. Sometimes trying to save money costs you more in the end.
  8. Oct 24, 2008 at 9:19 PM
    LonghornTaco
    Jason
    Minnesota
    This is where the spacer goes, right?
  9. Oct 24, 2008 at 9:20 PM
    LonghornTaco
    Jason
    Minnesota
    No, you probably aren't the only one........... :eek:
  10. Oct 25, 2008 at 9:47 AM
    The_Hodge
    SC
    thats it...and by ur other post, ur getting it aligned and all, so i'm guessing ur already done w/ this part...lol
  11. Oct 25, 2008 at 9:54 AM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Part of me agrees with ricepow. However, an even bigger part of me says Go For It Jason!. You have put alot of work into your truck already and it will be something to be proud of when you are done. And you can say you did it all. Luckily we have people like Hodgey and Chris who will help us along the way...
  12. Oct 25, 2008 at 12:19 PM
    LonghornTaco
    Jason
    Minnesota
    Yep, got it! Once I found this, I was 99% sure that it was right. I just posted that note and picture to get some peace of mind. But, when I didn't get a response after about 20 minutes, I just went ahead with it.
    This is exactly why I wanted to do it. I wasn't going to put a lift on at all until I started reading this forum and found out what was involved. It's really not hard at all, it just takes time. Took me and my buddy about 10 hours, but we took our time and goofed around a bit...
    I was pretty nervous about doing it simply because I never had before and the fact that the truck is brand new! I didn't want to screw it up. But, I took my time and double and triple checked everything. Torqued down everything necessary per the specs and once I got the tires on, nothing was rubbing, clicking or knocking. Well, except that an inner weight on the right front wheel would hit the sway bar when fully locked to the left. But, when I got the new tires today, I mentioned it and they put lower profile weights on, so no more problems!
    So thanks to everyone for the help! A build thread will be coming later today with pictures...
  13. Nov 7, 2008 at 4:48 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Hi all,
    I'm planning on adding a lift in the front using 5100. Do I need the 1" differential drop kit if the setting is 1.75? What about if 2.5?
    My truck is '05 DC 4x4 long bed with rear TSB springs.
    Thanks.
  14. Nov 7, 2008 at 4:51 PM
    The_Hodge
    SC
    it shouldnt be needed, but better safe than sorry. more so at 2.5 over 1.75
  15. Nov 7, 2008 at 4:54 PM
    LonghornTaco
    Jason
    Minnesota
    x2.
    The diff drop is like $20 from ToyTec and takes 5 minutes to install.
  16. Nov 7, 2008 at 4:54 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    As long as you're making sure you're doing the right thing by posting pics like you did up there and getting feedback from experienced ones--- I think you could tackle pretty much anything :)
    well except maybe a tranny rebuild... those are tricky
  17. Nov 7, 2008 at 7:40 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Thanks Jhodge83 and Jason.
    Does anyone here use the 1.75" and added 1" diff drop?
