OME rear shock install on 1st gen questions.
Discussion in 'Suspension' started by Matic, Aug 17, 2011.
  1. Aug 17, 2011 at 10:44 AM
    Matic
    Matic [OP] The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Couple questions if anyone can help.
    I installed my OME-90004 front shocks in my 881 coils this morning and afterwards noticed I may have gained some lift. I'm 40 in on the drivers side and 41 on the passenger side. I'm not running flares so this is a true measurement from the ground up to the center of the axel and up to the fender. (285/75/16 tires)
    Keep in mind I have been running the stock tokico shocks since the day I drove it off the lot in 2002 with 90k on them now.
    I certainly dont recall it being that tall before. I thought it was like 37.5 and 38 1/4 before. It's actually more level it seems like now because my rear springs will need replaced soon and I think the measurements are pretty close to 39in on both sides.
    PLacebo effect on the front or did I somehow gain a small amount by ditching the 90k tokicos?
    Question (2)
    The lower shock mount bolts in the front.
    I put them in backwards. The nut is now on the back side. Does it matter?
    Question (3)
    I'm going to be installing my rear OME-60062 shocks in the morning. I thought I read somewhere that they were "side specific". However after talking with Ben at toytec he says no and furthermore claims he's never heard of a "side specific" toyota at different shock lengths except in non lifted applications.
    Can anyone shed some light on this for me?
    Also since I am needing rear springs, I would like to ditch the Toytec AAL and go with a specific leaf pack that is the equivalent to my 3in 881/90004 setup in the front. Suggestions?
    Alcan? toytec? Expedition?
    And I would assume since they would be a 3 in lift spring that my OME rear 60062 shocks will still fit/be suited for this application
    Thx in advance!!
  2. Aug 17, 2011 at 10:55 AM
    scocar
    scocar hypotenoper
    De nada.
  3. Aug 17, 2011 at 10:57 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You should have the nut on the front side towards the front bumper. But your a Prerunner so It's not like it's going to damage your CV boot. but when you go to 4wd put the bolt the right way or you will rip a boot.
  4. Aug 17, 2011 at 11:01 AM
    Matic
    Tricky Dick
    Easley, SC
    I didn't think it matter but the bolt seems to be angled upwards towards the rear of the truck. Probably just go ahead and spin em around and re torque everything tommorow morn after I get the rears on.
    Tiregate yesterday. Front OME's on today. Rear OME's tommorrow and Snorkel on friday.
    Been a busy week.
  5. Aug 17, 2011 at 11:02 AM
    Matic
    Tricky Dick
    Easley, SC
    Thank you sir.
  6. Aug 17, 2011 at 11:03 AM
    JLee
    Jerry
    Benicia, CA
    Yeah that bolt will rip your CV boots I you were a 4x4 but your fine for now
  7. Aug 17, 2011 at 11:14 AM
    scocar
    scocar hypotenoper
    How is this physically possible? I can't find my picture right now or go look at my truck. Do you mean at full lock?
  8. Aug 17, 2011 at 11:28 AM
    JLee
    Jerry
    Benicia, CA
    At full compression your CV boot is really close to the lower shock bolt head and if it's put on backwards the end of the bolt will contact the boot and rip it trust me I've seen it happen.
