5100s front / 2" AAL back (couple questions)
Discussion in 'Suspension' started by KingMoo, Sep 7, 2011.
  1. Sep 7, 2011 at 10:42 AM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    Does the setup with adjustable Biltein 5100s (front) utilize the stock coils even though Toytech website states "NOT RECOMMENDED FOR USE WITH SPACERS OR COILS UNLESS LOWEST (STOCK) SETTING IS USED"
    Also, is this a relatively good setup for a cheap, small lift? Not too much offroading and certainly not any agressive offroading...
    I was previously looking at the OME kit but the local shops here want $550+ for install so that's a little out of my price range.
    I'm a pretty handy person and I have all the right tools. i just don't have too much automotive experience. Is this install for me?
  2. Sep 7, 2011 at 10:46 AM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    i dont see why the 5100 wont work with the stock coils. if u have the tools then your good just need an extra hand. there should be info on how to install somewhere in this site.
  3. Sep 7, 2011 at 12:06 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    I've heard that you need a special tool to load the coils on the shocks. Is it necessary for stock coils on 5100s?
  4. Sep 7, 2011 at 12:13 PM
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You need a spring compressor to load coils onto struts by yourself. Other than that, you just need basic hand tools although air tools will make for a much quicker and easier installation.
  5. Sep 7, 2011 at 12:18 PM
    Konaborne
    Konaborne Pineapples on pizza Hawaiian does not it make.
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    fox extended travel remote resivoir coilovers, 14" eibach 600lb coils, All Pro tubular chromoly 1" uniball upper control arms, All Pro expedition leaf packs, 10" bilstein 5150 piggyback reservoir shocks 265/75r16 Goodyear wrangler MT/R kevlars wrapped around 16" Helo 791 gloss black, Mini H1 retrofits with 6000k bulbs, 18" magnaflow w/custom exhaust reroute various decals, Sockmonkey retro hood stripes
    If you're not confidant, take it to a mod day or a reputable shop
  6. Sep 7, 2011 at 12:20 PM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    They mean not to use perch on 5100s preloaded when using lift coils, you leave it at 0 if using those coils. Using the stock coils with or without preload set with 5100s is OK......and yes, you need spring compressor no matter what setup you go with doing it yourself as was mentioned.
  7. Sep 8, 2011 at 8:19 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    5100s with stock coils in Front and 2" AALs in the Rear don't reaquire any further modification, correct? (ex. diff drop)
  8. Sep 8, 2011 at 8:38 AM
    Hopefully... anytime you lift a vehicle you run the risk of introducing vibrations because you changed the driveline geometry. You could potentially end up needing a CB drop, shims or a front diff drop. You 'shouldn't' need anything else besides 5100's and the AAL but no one can say definitively that you won't need them later to correct vibes. Not to scare you, you're better off planning for it now than figuring it out later.
  9. Sep 8, 2011 at 9:36 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
