DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Dec 13, 2013 at 6:04 AM
    #321
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Very likely a stupid question, but...
    If we all are unable to replace the grease on a maintenance interval througha zerk fitting why not coat with a quality Anti-Seize compound instead ofgrease?
  2. Dec 13, 2013 at 8:09 AM
    #322
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I will be using anti-seize, it only makes sense to me but i'll see how it holds up throughout the winter.
  3. Dec 13, 2013 at 8:28 AM
    #323
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    I use a slurry of red n tacky and anti sieze
  4. Dec 13, 2013 at 9:16 AM
    #324
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    there are no zerks
  5. Dec 13, 2013 at 9:55 AM
    #325
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    It's an interesting question. I read the MSDS for anti-sieze. From the look of it, it's 40-60% grease, 15-25% Calcium oxide, less than 10% graphite, and less than 10% aluminum oxide. Seems to me where that stuff shines is for threaded fasteners.
    For this application I think it's hard to beat a quality wheel bearing grease.
  6. Dec 13, 2013 at 9:56 AM
    #326
    XXXX
    sKiP
    05 Prius
    I'm going marine grease next time.
    Because my trucks a submarine :D
  7. Dec 13, 2013 at 9:59 AM
    #327
    Crom
    Nick
    San Diego, CA
    Millions
    lol :laugh: I remember way back when, when you submarined your truck and had to take out the interior to dry it out!
  8. Dec 13, 2013 at 10:20 AM
    #328
    XXXX
    sKiP
    05 Prius
    that was last week :(
    again
    JK
  9. Jan 2, 2014 at 4:32 PM
    #329
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Just bought a set of these for my LT kit, hopefully these should work...
  10. Jan 2, 2014 at 9:49 PM
    #330
    nj636
    Kev
    Jersey
    Being a victim of the seized LCA bolts/cams, I took on the job of cutting the LCA's out of my truck and replacing the bushings. A while back Boyd had mentioned the Whiteline bushings (P/N: W53312) as a possible alternative to the Toyota or Moog parts, but with no history of anyone installing them it was not confirmed they would work.
    I found that Energy Suspension sells the bushings. They do not list the 05 up Tacoma but according to their site, the bushings fit the 03-12 4Runner & 07+ FJ Cruiser http://www.energysuspensionparts.com/alsofoundin.asp?partid=W53312
    A little research shows that the Toyota & Moog part numbers are the same for the 4Runner, FJ & Tacoma bushings, all interchangeable. I decided to give the Whitelines a try.
    Visually the bushings look great & appear to be a match to the Moog’s
    Hardware fits
    So far it looks as if they are going to work :woot:
    Until I went to install the bushings :( The Toyota & Moog’s go in ¾ of the way by hand & need to be pressed in the rest of the way. The Whitelines wouldn’t go in by hand at all. Figuring they are just a tight fit, I tried using a ball joint press, still no good. I compared the O.D. of the Whitelines & Moog’s.
    Moog large bushing
    2.173
    Whiteline large bushing
    2.224 - .051 larger than the Moog’s :(
    Moog small bushing
    1.861
    Whiteline small bushing
    1.905 - .044 larger :(
    They also have P/N: W53393 which is listed for the Toyota Hilux. When I called for the return, a rep confirmed they had notes in their system that these would not work on the Tacoma.
    I was hoping this would be a viable alternative to the OEM's or Moog's but it's safe to say Whiteline is out :eek:
    Crom likes this.
  11. Jan 2, 2014 at 10:12 PM
    #331
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Good looking out Kevin. :thumbsup:
  12. Jan 3, 2014 at 12:08 AM
    #332
    brutalguyracing
    F.U> GUYZ
    broken mods
    welcome to my world......
    sucks being the gunnie pig
  13. Jan 3, 2014 at 2:18 PM
    #333
    nj636
    Kev
    Jersey
    I don't mind. I got all the parts together including moogs for that reason & energy suspension took them back without a problem.
    besides it's nice having a second vehicle for times like these :D
  14. Jan 3, 2014 at 2:52 PM
    #334
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Glad they took em back. Someone needs to come up with a complete solution for us. No second vehicle is always my problem.
  15. Jan 6, 2014 at 10:50 AM
    #335
    nj636
    Kev
    Jersey
    :thumbsup:
    I sure was hoping they would work. Those bushings were a bitch to get out, I was able to press 2 of the 4 out. The other two came out with an air chisel.
    I suppose if we add greasing the bolts and sleeves to our yearly maintenance this can be avoided.
    Anyone hear back from Moog?
  16. Jan 6, 2014 at 11:23 AM
    #336
    brutalguyracing
    F.U> GUYZ
    broken mods
    F MOOG
    HOW HARD IS IT TO MEASURE ONE OF THEIR OWN BUSHINGS
    NO CUSTOMER SERVICE....
    WILL NOT BE GETTING ANY MORE OF MY BUSINESS
    RAYBESTOS HERE I COME
  17. Jan 6, 2014 at 1:43 PM
    #337
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Hey Kevin,
    I installed the Whiteline polyurethane bushings into my LCAs when I rebuilt the front end. I didn't/haven't had any issues with the bushings. :confused:
    Crom likes this.
  18. Jan 6, 2014 at 3:18 PM
    #338
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Would you happen to have the part numbers for your's?
  19. Jan 6, 2014 at 3:59 PM
    #339
    XXXX
    sKiP
    05 Prius
    :spy: the first pic
    he posted it - same part number Kevin had issues with
  20. Jan 6, 2014 at 5:16 PM
    #340
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Maybe Kev just got a bad set??? :confused:
