DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Apr 2, 2013 at 4:40 PM
    #61
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    first time was a pita. after that the other 3 got easy. with the lca and tools in front of you it should take no more then a hour per side for removal and replacement of both lca bushings following these steps. less time for the next side.
  2. Apr 2, 2013 at 4:41 PM
    #62
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    3 hours isn't bad at all... I bet I had double that and I had help. We had a hell of a time getting the bushings out of the LCA. We torched out the rubber center as our extraction method of choice. I also have 3 years of rust on you though...
  3. Apr 2, 2013 at 5:30 PM
    #63
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    he just called your MA truck a pos:eek:
    :popcorn:
  4. Apr 17, 2013 at 5:27 PM
    #64
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Did my passenger front cam n bushing yesterday, and getting it aligned tomorrow. I went through 3 recip saw blades just for one bushing. 2 Dewalts, and 1 Craftsman. The Craftsman blade held up the best, and it's still usable, go figure. Here are some fun pics. Enjoy :D
    The culprit
    The end result
  5. Apr 18, 2013 at 2:36 PM
    #65
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  6. Apr 18, 2013 at 3:03 PM
    #66
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    They would probably be the same as the toyota bushing. I've found the rear lca bushings on rockauto, but the only other place I've seen the fronts were on the O'reilly site.
  7. Apr 25, 2013 at 5:54 PM
    #67
    XXXX
    sKiP
    05 Prius
    #67
  8. Apr 25, 2013 at 6:39 PM
    #68
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Will be checking mine this weekend :eek:
    I had an alignment last year and the place never mentioned anything about the lower cams being seized... then again i've got a year of flharton goodness in there now :eek:
  9. Apr 25, 2013 at 6:47 PM
    #69
    nj636
    Kev
    Jersey
    #69
  10. Apr 26, 2013 at 4:42 AM
    #70
    nj636
    Kev
    Jersey
    thank you sir
  11. Apr 26, 2013 at 4:57 AM
    #71
    XXXX
    sKiP
    05 Prius
    Yes only because when I did mine I couldn't find any sleeved poly bushings. Screw oe rubber. The ones I just linked look muuych better
  12. Apr 26, 2013 at 5:22 AM
    #72
    nj636
    Kev
    Jersey
    I'm searching for the MOOG's, local NAPA's have one but not the other. Might try those from eBay..
    #72
  13. Apr 26, 2013 at 6:17 AM
    #73
    Pugga
    Massachusetts
    :eek:
    :pout:
  14. Apr 26, 2013 at 7:29 AM
    #74
    XXXX
    sKiP
    05 Prius
    Poly > rubber
    Do it....be the guinea pig
    You can get them cheaper than fleebay.
    Also they have washers vs flanges and that would seem superior
    #74
  15. Apr 27, 2013 at 6:44 PM
    #75
    splitbolt
    NW Arkansas
    Energy Suspension sells them too; but I thought they will not work?
    http://www.w.energysuspensionparts.com/proddetail.asp?prod=W53312#
    Says it will fit:
    Lexus GX460 2009-2010
    Lexus GX470 2003-2009
    Toyota 4Runner 4WD 2003-2012
    Toyota FJ Cruiser 2WD 2007-2012
    Toyota FJ Cruiser 4WD 2007-2012
    Toyota Landcruiser Prado 2004-2009
    Toyota part #s aren't the same...
    Toyota part # 2007 FJ Cruiser:
    48654-60030 BUSH, FRONT LOWER ARM, NO.1 LH
    48654-60030 BUSH, FRONT LOWER ARM, NO.1 RH
    48655-60030 BUSH, FRONT LOWER ARM, NO.2 LH
    48655-60030 BUSH, FRONT LOWER ARM, NO.2 RH
    48632-60020 BUSH, FRONT SUSPENSION UPPER ARM, LH
    48632-60020 BUSH, FRONT SUSPENSION UPPER ARM, RH
    Toyota part # 2007 Tacoma 4wd/Prerunner:
    48654-04040 BUSH, FRONT LOWER ARM, NO.1 LH
    48654-04040 BUSH, FRONT LOWER ARM, NO.1 RH
    48655-04020 BUSH, FRONT LOWER ARM, NO.2 LH
    48655-04020 BUSH, FRONT LOWER ARM, NO.2 RH
    48632-04020 BUSH, FRONT SUSPENSION UPPER ARM, LH
    48632-04020 BUSH, FRONT SUSPENSION UPPER ARM, RH
    #75
  16. Apr 27, 2013 at 7:39 PM
    #76
    XXXX
    sKiP
    05 Prius
    Don't you have to hollow out and reuse the old sleeve with them?
  17. Apr 27, 2013 at 7:41 PM
    #77
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  18. May 30, 2013 at 11:36 AM
    #78
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Sub'd Rep'd, damned fine thread.
  19. May 30, 2013 at 12:09 PM
    #79
    Pugga
    Massachusetts
    Damn shitty assembly prompted damn fine thread :cool:
  20. May 30, 2013 at 12:12 PM
    #80
    YOTA LOVER
    NH
    If it's broke why fix it??? I love the emperor sometimes, SMH
