02 Tacoma 3"
Old 10-30-2008, 11:29 AM   #1
dthiss21 [OP] dthiss21 is offline
DTHISS
dthiss21 is on a distinguished road
dthiss21's Avatar
dthiss21's Tacoma Gallery
Send a message via MSN to dthiss21
02 Tacoma 3"
Sorry guys another lift question. I got a 02 tacoma. and i want a lift that is going to keep my truck level. I really would like to run 285/75R16's. If i got 3" do i really need the transfer case drop kit?? I dont have alot of time todo it my self was going to have Les Schawb do it. I work at O'Reilly's and probley could get something cheap but then NOONE would wanna install it..... ANY THOUGHTS. Toytech? Procomp? WHAT SHOULD I DO??? I Live in MT. so our tire shops are limited lol... Sorry for long post but please help. THANKS DAN
Old 11-02-2008, 08:22 PM   #2
Tacoma02TRD is a jewel in the roughTacoma02TRD is a jewel in the roughTacoma02TRD is a jewel in the rough
Tacoma02TRD's Avatar
Tacoma02TRD's Tacoma Gallery
I have a 3" Revtech lift kit on my 02 and love it. Im able to run 33x12.5 with very little rub at all. So I would do some research on there website and see what they have, should be able to do it your self with some tools. Good luck on finding your lift.
Old 11-02-2008, 08:47 PM   #3
Carolina Alliance: Lead, follow, or get the hell outta my way
tacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shed
tacomaman06's Avatar
tacomaman06's Tacoma Gallery
you can get a toytec 3 inch kit for a real reasonable price, one with coils and aal, that will level your truck and give you a good ride. a diff drop is highly recommended cause you'll have weird angles on the cv's without it........and no need to tear them up when i diff drop kit is as inexpensive as they are and easy to install. i still think with 285's....you'll still need to remove the mud flaps and maybe do a bit of trimming.
Old 11-02-2008, 08:50 PM   #4
BECAUSE INTERNETS!!
tigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shedtigerfan00 is one of the sharper tools in the shed
tigerfan00's Avatar
Law Enforcement: beat cop...putting bad people in jail
tigerfan00's Tacoma Gallery
285s will PROBABLY need new UCAs, removal of mud flaps and hammering of the pinch weld
past that prob not much trimming
i have Sway-A-Way Racerunner adjustable coilovers and a Wheelers Offroad 3leaf Progressive AAL...when my tires are in balance etc it rides at least as good as it did stock...possibly better
i DONT have a diff drop or anything of the sort and i havent busted a CV yet...key word is YET...i've got one leaking grease but i suspect its been that way for awhile...im waiting on it to pop
Old 11-02-2008, 08:53 PM   #5
yeah, uca's will be a good idea if you want your alignment to be exactly where its supposed to be, but its not necessarily a must have. they are a good idea though. even though i dont have much of a lift on my truck....im still saving for a set of tc uca's since im an alignment perfectionist.
i still say that with a 3 inch lift on a 4x4......a diff drop is a good idea.
Old 11-02-2008, 08:58 PM   #6
BECAUSE INTERNETS!!
tigerfan00's Avatar
i dont disagree with the diff drop...i just dont have one and havent seen the need for one yet
i say UCAs because my 255/85s (same height as a 285/75) are pretty close to the current arm and id suspect itd rub if i went to the wider tire
Old 11-02-2008, 09:00 PM   #7
uca's may be needed.....i could be wrong, but greenbean had his 03 with a 3 inch lift,running 285/75/16's and im pretty sure he had stock uca's. like i said...i could be wrong, but im pretty sure.
Old 11-03-2008, 06:13 PM   #8
DTHISS
dthiss21's Avatar
Thumbs up
Okay really stupid question WAT IS A UCA??? Lol i work in a parts store and am still confused.... Another quick question do i really need a AAL??? or will a block work, the guy at my tire shop was saying if i'm not really going to be hauling anything heavy just go with the blocks... still like the idea of a AAL....SUGGESTIONS??? thanks dan
Old 11-03-2008, 06:18 PM   #9
668: The Neighbor of the Beast
Toy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shedToy4Life is one of the sharper tools in the shed
Toy4Life's Avatar
Toy4Life's Tacoma Gallery
UCA= Upper Control Arm. I would go with an AAL before blocks. If you're going to run stock wheels, You'll need 1.5" wheel spacers and you're UCAs won't be a problem.
Old 11-03-2008, 07:46 PM   #10
DREAD is on a distinguished road
DREAD's Avatar
Army: E5-13B Artillary Cannon Crewman, 1/180th 153 FA Bgd
DREAD's Tacoma Gallery
Stay away from blocks...
Damn, I guess I am in a bad mood tonight, but why the hell would you consider what size of tire you should get if your truck won't support them?!?
Here's the way I see it. Decide how you are going to use your truck as far as wheeling or DD and work from there. If you want large tires because they look cool, you're just wrong. If you want large tires, you are going to need a lift unless you want to go getto. So decide what kind of lift you can afford, consider it's affect on your truck/ride and THEN decide which tires size will work for your application. 33's or 35's are cool IF you have the proper suspension. Don't get it backwards! I ran 33x12.50's on my lats Taco, but I had plenty of lift to support them. Why would anyone want to trim etc, just to fit large tires?!?!
Research all the *many* lift options, find one you are comfortable with, or what you can afford THEN consider tire size. If you do otherwise, you're just wrong. Bottom line....
Sorry to be so bitchy. Just lost my sister to cancer, my ex is stalking me and my local bar 86'ed me for stopping a guy from roughing up a pretty young lady... Life sucks, but my Tacoma always listens and tries to do it's best to do what I ask of it...
Old 11-05-2008, 02:28 PM   #11
DTHISS
dthiss21's Avatar
Smile
my local off road shop is gunna charge me $725 (thats discounted from 850) for a 3" lift. spacers in the front, and a AAL rear, and an alignment. I after chrome rims but there still stock style... sound like a good price?? right now i had 265'75r 16's would those look too small with the lift... or step up to some 285s??? thanks Dan
Old 11-05-2008, 02:31 PM   #12
just my opinion, but you could install the lift yourself and save alotta $$$. anyway.....265/75/16's will look fine on the truck.....and you wont have to do anything special for them to fit. with 285's........you gotta do some trimming and mud flap removal so they wont rub.
Old 11-05-2008, 04:20 PM   #13
DTHISS
dthiss21's Avatar
i already have my mud flaps off because my big horns 265's are rubbing,, when i turn on bumps, mudding. ect.............. what will help, already trimmed and beat in the seam welds
Old 11-05-2008, 04:21 PM   #14
well, since you already did that...you may not need to trim anything else for the 285's to fit.
Old 11-05-2008, 08:19 PM   #15
DREAD's Avatar
The front, as far as installing a coil-over lift should take about 30 minutes each side. The rear, AAL's will take longer. Make sure you have the proper sized center pin an U bults. Other than that, installing a minor lift is no big deal.
The only reason I can see for installing 285's is that you have properly decided on a proper *susspension* lift that meets your needs - being it wheeling or DD. A body lift would to look cool, but would be a wrong move...
Did I read that you have already trimmed? I'm sorry.
Old 11-06-2008, 02:59 PM   #16
Taco Traitor!
TRD4x4858 is a splendid one to beholdTRD4x4858 is a splendid one to beholdTRD4x4858 is a splendid one to beholdTRD4x4858 is a splendid one to beholdTRD4x4858 is a splendid one to beholdTRD4x4858 is a splendid one to beholdTRD4x4858 is a splendid one to behold
TRD4x4858's Avatar
TRD4x4858's Tacoma Gallery
Send a message via AIM to TRD4x4858
I got had mine lifted 3inches with a spacer lift and with stock wheels and 285's the tire made contact with the upper arm and rear frame rail on full lock turns, you'll need at least some wheel spacers and trimming of all sorts, I would honestly go for like a metric sized 32inch tire cuz for dd its great but as soon as you hit the trail your gonna hear it rubbing all over, I switched to king coilovers and wheelers type b rims(4" backspacing) in front to solve my uca and frame contact problem
Old 11-06-2008, 08:36 PM   #17
DTHISS
dthiss21's Avatar
okay, like i said early i work at O'Reillys... anyways i found some front spacers 2.5" for like a 130$ (my cost) !! hehe.... is that gunna put my truck about level??? should i go that route? will i beable to put 285's or 32"s on the front?? or do i need 3" front spacers... the main thing i want it for is looks.. and then in the snow.. (live in MT) THANKS GUYS ALL OF YOU HAVE BEEN BIG HELP.... anyone on here live in MT. (msla)>>>>??? thanks........dan
Old 11-06-2008, 08:44 PM   #18
Taco Traitor!
TRD4x4858's Avatar
you should be good with 2.5 but with 285's with stock wheels your gonna rub the frame at full turn unless you get spacers for your wheels, your front end is gonna be alittle higher than the rear so you'll have a bit of a cali lift
Old 11-06-2008, 08:47 PM   #19
Toy4Life's Avatar
Without an AAL, 2.5" up front is going to make the front sit higher than the back. A 265/75/16 (32") tire will fit on your truck stock and won't look stupid if you lift. If you go for a 285/75/16 (33") tire, you'll need the lift, aftermarket wheels or quality wheel spacers, and remove front mud flaps + pinch weld mod. Before you ask......
http://www.customtacos.com/tech/index.php?article=9 (pinch weld mod)
Old 11-06-2008, 11:46 PM   #20
DTHISS
dthiss21's Avatar
lol i know what a pinch weld is. on the avg.... wat will a AAL add height wise?? specific brand to use??
Stock 1st gen drums 02 Tacoma to 02 Sequoia disks? Can it be done? Sheepdog 1st Gen. Tacomas 30 09-30-2014 09:53 AM
My 02' Tacoma build "yotaluv" yotaluv 1st Gen. Builds 3 09-11-2011 10:53 AM
02 Tacoma 16" Rims Sleeper01 Buy / Sell / Trade 4 02-17-2010 09:00 PM
02 failing emision test- "Cat not rdy" Mr Goodwrench 1st Gen. Tacomas 0 12-08-2009 12:51 PM
Looking for used "bull bar" to '02 tacoma 4421.frank Buy / Sell / Trade 4 11-13-2008 12:31 PM
