Bilstein 5100s at 1.75!
Discussion in 'Suspension' started by Jareds Toyota, Sep 27, 2011.
  1. Sep 27, 2011 at 6:41 PM
    Jareds Toyota
    Jareds Toyota [OP] Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    Can you do this set up with stock coils? How does the truck ride?
  2. Sep 27, 2011 at 6:42 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Yes. And probably just about the same as stock.
  3. Sep 27, 2011 at 6:50 PM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    for a leveled look
    w/ no tsb rear leafs = set @ .85
    w/ tsb rear leafs = set @ 1.75
  4. Sep 28, 2011 at 11:05 AM
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    I've got 5100's all the way around. Fronts are set to 1.75, rear has TSB springs. Picked up between an inch and a half to two inches of lift all the way around and the ride is much better, especially off-road.
  5. Sep 28, 2011 at 12:29 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    So when you install Bilstein 5100's all around, and have the front set at 1.75" to level out, are the rear shocks set at 0", or are rear Bilstein's non-adjustable and are just installed?
    Thanks,
    -- Matt --
  6. Sep 28, 2011 at 12:35 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    the rear 5100's are not adjustable
  7. Sep 28, 2011 at 12:54 PM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    Here is a pic of my access cab 4x4 with the rear tsb done and 1.75 billys (stock coils) in the front to give you an idea.
  8. Sep 28, 2011 at 1:15 PM
    CanisLupus
    Stokesdale | NC
    Ok thanks guys. I am just thinking about getting Bilstein 5100's all around with the fronts set at 1.75'' to level out, and just had some clarifications.
    Thanks!
    -- Matt --
  9. Sep 30, 2011 at 7:26 PM
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    Thanks everyone for the input!
    terminus likes this.
  10. Oct 4, 2011 at 4:57 PM
    CanisLupus
    Stokesdale | NC
    Anybody else have pics of Bilstein's at 1.75'' just in front and preferably 265/70/16 tires?
    Thanks!
    -- Matt --
    bcalexander likes this.
  11. Oct 5, 2011 at 10:57 AM
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    Jared or anyone else...I keep reading that the 5100s for the rear are two long without a lift. Is this true for a 2011 DC TRD off road? I called 4Wheel Parts and they had never heard this. I am thinking the threads I read were for 1st gens.
    Can I go with the 5100s in the rear or do I need to go with 5125s?
  12. Oct 5, 2011 at 11:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For a stock (or even slightly lifted) rear, the 5100's do just fine. The issue was 5100's can be too short for a lifted rear and top out causing the shock to break.
  13. Oct 5, 2011 at 11:16 AM
    LD PRERUNNER
    LD PRERUNNER Well-Known Member
    Larry
    West Covina
    2011 PreRunner SR5
    Alpine CDA-105 CD Receiver Alpine amp Polk Audio db6501 6-1/2" Component System Polk Audio db 651s 6-1/2" Slim 2-way Speaker Polk 10" sub-woofer 17" Sport Toyota rims Billy 5100 front & back Snug top AFE PRO dry air cleaner
    IMG_0245.jpg BILLY 5100 FRONT AND BACK 1.75 FRONT/STOCK REAR
    The109 likes this.
  14. Oct 6, 2011 at 8:04 AM
    07NavyTaco
    07NavyTaco Well-Known Member
    Josh
    North Chicago
    07 SR5, short bed, 4x4, bilstein 5100s
    billy 5100s @ 1.75, black grill and lower valence, tinted windows
    if i want to set my front 5100s at 2.5 what lift would i need in the rear to level it?
  15. Oct 6, 2011 at 10:08 AM
    07NavyTaco
    Josh
    North Chicago
    From what i've read on here, anything under 3", you don't need new UCA's. correct me if i;m wrong but i thought the billy's set at 2.5 was 2.5".
  16. Oct 6, 2011 at 10:16 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    I like those WHEELS--Sharp!!! I like SHINY.
  17. Oct 6, 2011 at 12:49 PM
    07NavyTaco
    Josh
    North Chicago
    Oh ok. well i'm glad you told me baecause i was going to set them high. i'll go with 1.75 and see what it looks like, i may need AAL in the rear. are you getting new UCA's with your set up? i don't really have the $$$ for all that.
  18. Oct 6, 2011 at 1:11 PM
    07NavyTaco
    Josh
    North Chicago
    Would the weight of my DC make a difference? i just ordered Discoverer STT 265/75R16 and i want to get my truck level for a more aggressive look.
  19. Oct 6, 2011 at 1:12 PM
    07NavyTaco
    Josh
    North Chicago
    your truck looks good, btw. thanks for the advice.
  20. Oct 6, 2011 at 6:04 PM
    larry2375
    larry2375 Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    Nice looking truck. Can't tell difference between 1.75" and 2.5"
