Weird issue (5100 at 0 lower than stock...)
Old 09-27-2011, 10:00 PM   #1
Yoytoda [OP] Yoytoda is offline
The Little Truck That Could
Yoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shedYoytoda is one of the sharper tools in the shed
Yoytoda's Avatar
Yoytoda's Tacoma Gallery
I just installed 5100s set at 0 with 885x coils and 1/4" top plate spacers and only got 2.25" lift in the front. WTF!?!?
I measured the distance between the bottom eyelet on the shock to the spring perch and the 5100 is about .5" lower than my stock shocks...
Anyone else notice this?
Old 09-27-2011, 10:06 PM   #2
Yoytoda's Avatar
Also,
my measurment from the center of the hub to fender is 22.5"
stocks are usually 20-20.5
Old 09-27-2011, 10:24 PM   #3
Yoytoda's Avatar
so i just measured again and
the stock shocks are 8.75" from the top of the spring perch to center of the shock eye.
the 5100s set at 0 are 8" from center of spring to shock eye
so i should be getting at least 3.25" of lift without the top 1/4" spacer.
Anyone have the measurement of the ome shocks?
Old 09-28-2011, 10:21 AM   #4
Yoytoda's Avatar
check out stock vs 5100 set at 0
how can they call 0 as the stock height. .85 should be the "stock setting"
Can someone measure their OME shocks?
Old 09-28-2011, 10:42 AM   #5
steveni70 is on a distinguished road
steveni70's Tacoma Gallery
Aren't the OME coils are supposed to give 1.75" of lift? Add the 0.5" for the spacer and 2.25" sounds right.
Old 09-28-2011, 10:56 AM   #6
Yoytoda's Avatar
lots of people report 3"+ with ome 885s
Weird alignment issue Toolex 2nd Gen. Tacomas 1 10-22-2011 01:12 AM
Weird starting issue, hopefully someone can help! boostfed 1st Gen. Tacomas 28 08-04-2011 01:17 PM
3" lift two days ago and weird issue today 93civEJ1 2nd Gen. Tacomas 14 06-14-2010 06:27 PM
Weird Request and issue Finding Part!...... br217398 2nd Gen. Tacomas 7 04-28-2009 08:46 PM
Weird issue nd 2nd Gen. Tacomas 13 05-01-2008 10:37 PM
