Using a spring compressor (Eibachs)
Discussion in 'Suspension' started by KingMoo, Oct 2, 2011.
  1. Oct 2, 2011 at 9:21 AM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    I'm planning to install my 5100s w/ Eibachs set at 0. Yesterday I picked up the spring compressors from a shop but I'm not sure if they're up to the job.
    Do these look OK for my needs? I'm guessing they don't have to be compressed too much since I'm setting the billys at 0...
    EDIT: does anyone know a link toa thread containing jack and jackstand positions with pics?
  2. Oct 2, 2011 at 9:22 AM
    jandrews
    '09 FourDubDee TRD OR
    You are going to die.
    Edit:
    Something like this is best:
    TWO of these will work in a pinch (two shown). Note the much beefier construction:
  3. Oct 2, 2011 at 9:22 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    why arent there 2 units, one for each side of the srpring
  4. Oct 2, 2011 at 9:25 AM
    Iakopa84
    Iakopa84 Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    Agreed. DO NOT try and compress it with that little dinky thing!
  5. Oct 2, 2011 at 9:39 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    there are 2. I just took a pic of one to show how it looks on the spring
  6. Oct 2, 2011 at 9:41 AM
    jandrews
    There are two WAY TOO SMALL compressors.
    Look at the size of those u-bolts holding the compressor to the spring. Whne one of those shears and the spring send a metal fragment flying at the speed of a bullet, I hope it does not hit you in the eye.
    What I'm trying to say is please don't use those shitty little compressors. Go find another set that's actually built for the job. Those things in your picture look like they're made for lawnmower or ATV repair, not motor vehicle.
  7. Oct 2, 2011 at 9:51 AM
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    I was just about to post a spring compressor thread...anyone know of a compressor that could be used WITHOUT taking the C/O off the truck? I only need to compress them a tiny bit so I can adjust the collar to change the height.... Not trying to thread jack but figured while we were on the subject and you already got your answer.
  8. Oct 2, 2011 at 9:55 AM
    jandrews
    ... If you compress the spring while it's on the truck and the truck is on the ground, the truck will just lean as you compress the spring and no slack will be created that will allow you to move the collar.
    Step 1 for you is jack the truck up until the front suspension is fully drooped, then secure it there. At that point you *might* be able to use a small compressor set to compress the spring and adjust the collar.
    Honestly, taking the coilovers off these trucks does not take that long, and for safety's sake I'd rather do it right.
