Leaf spring hitting shock?
Old 10-03-2011, 02:18 PM   #1
White Tank
SkyHighTacoma has much to be proud ofSkyHighTacoma has much to be proud ofSkyHighTacoma has much to be proud ofSkyHighTacoma has much to be proud ofSkyHighTacoma has much to be proud ofSkyHighTacoma has much to be proud ofSkyHighTacoma has much to be proud ofSkyHighTacoma has much to be proud of
SkyHighTacoma's Avatar
SkyHighTacoma's Tacoma Gallery
Well I was takeing my tire off today to repaint my rear drums black and I noticed my shock body is dented/creased in two places. From what it looks like two of my leaf spring shifted at some point and hit the shock. All the u-bolts are torqued to spec so what could cause this and has anybody else experienced this? I have a Toytec 2" rear AAL and Rough Country 8000 series hydraulic shocks.
Old 10-03-2011, 02:20 PM   #2
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
Flex your truck slowly with someone watching to see if it's possible to make the leaf spring touch the shock.
Old 10-03-2011, 02:25 PM   #3
White Tank
When I put the tire back on and lowered the truck back down it didnt look like it even came close to touching? And the suspension was at full droop. But maybe it happends when the suspension flexes IN on that side..
Old 10-03-2011, 02:29 PM   #4
Pugga's Avatar
Looks like whatever hit it did it once and it hasn't happened for a while since there's rust in the dent. I'd try flexing it out and seeing if you can replicate it. Keep in mind if you come off something tall you'll compress the suspension a lot more than just flexing the truck slow and controlled.
Broke Leaf Spring, Just add a leaf? RockLobster Suspension 20 02-11-2011 12:56 PM
Clunking noise after spacer lift, upper ball joint hitting spring 96 tacomaPtown 1st Gen. Tacomas 4 07-24-2010 11:58 AM
OME leaf pack extra spring- what shock? tomesd 2nd Gen. Tacomas 6 06-25-2010 03:37 PM
shock and spring Q GotLift37 ToyTec Lifts 4 12-17-2009 05:24 PM
Shock / Spring question jrallan26 1st Gen. Tacomas 1 04-30-2008 11:16 PM
